Old 05-14-2015, 09:18 PM   #2493
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Anyone have a sewing machine type of sound coming from the overpipe area when accelerating from a stop? I only have the headers and q300.
Sent from my SCH-I545 using Tapatalk
Avo1789 is offline
Old 05-14-2015, 09:20 PM   #2494
Avo1789
Avo1789's Avatar
^Also to be clear, it is not a metal to metal contact noise. Thanks!
Avo1789 is offline
Old 05-15-2015, 01:01 PM   #2495
kodyo
Drives: Scion FR-S
How long have you owned this car? The classic "crickets" from the high pressure fuel pump sounds like a sewing machine.
kodyo is offline
Old 05-15-2015, 01:23 PM   #2496
STV3
Señor Member
STV3's Avatar
Originally Posted by DGM86 View Post
Why, hello there. Look at the many shiny things sent to me by the great god of heavenly exhaust notes:
Still waiting on the Invidia resonated front pipe. Gonna be interesting going from completely stock to a full header back exhaust overnight!
what catback is that?
STV3 is offline
Old 05-15-2015, 05:03 PM   #2497
Avo1789
Avo1789's Avatar
Over two years now. It is definately not crickets. I noticed this immediately after install. Doesn't bother me much but it is noticable when heard from the outside or sound reflections from a wall. I'm thinking its a bottleneck issue since my overpipe and frontpipe are OEM. To those who replaced the OP and FP do you still notice this fast ticking noise from the bottom of the engine bay?
Avo1789 is offline
Old 05-15-2015, 05:20 PM   #2498
brianhj
Drives: 2017 Camaro 1SS
Leak maybe? Or is it vibrating against something?
brianhj is offline
Old 05-15-2015, 05:22 PM   #2499
brianhj
Is that a SpeedFactory header? They did away with even more welds? Looks nice
brianhj is offline
Old 05-16-2015, 03:36 PM   #2500
DGM86
Drives: 15 BRZ, 07 Tacoma TRD, 01 Miata SE
That is the FT86Speedfactory resonated V1. This is the daily rage package from them (pic doesn't show the resonated front pipe)
Yes sir, its their catted UEL. Will post sound clips when I can finally get around to installing everything
DGM86 is offline
Old 05-20-2015, 07:46 PM   #2501
DGM86
So, I got my header, overpipe and catback installed today as the Invidia resonated front pipe is backordered for now. The only thing more noticeable than the sexy exhaust noises was the CEL that came on immediately. Pulled it when I got home, P0031 - HO2S heater control circuit low (Bank 1, Sensor 1) which, if I am not mistaken, is the front O2 sensor and not the rear like I had assumed at first. I removed the negative battery terminal, no change. I will take it back to the shop ASAP to have them look over the wiring for the front sensor, perhaps they messed up installing the front, but I doubt it this guy is pretty good. Dropped it maybe?
Any one have experience with this CEL? A search did not turn up much. Car seems to drive just fine, with improved butt dyno results no less. Is this going to screw with my gas mileage? Should I not be driving it with a messed up front O2 sensor?
DGM86 is offline
Old 05-21-2015, 03:37 AM   #2502
Sphirit
Drives: GT86
So if I run this headers with stock tune I will get a cel?? An O2 spacer would help??
Here in Spain it is hard to found a good tuner for this car.
My car is completly stock,only have a TRD intake and a greddy sp elite.
Sorry my bad english.
Sphirit is offline
Old 05-22-2015, 09:20 PM   #2503
kodyo
Drives: Scion FR-S
I had a Motiv over pipe, motiv catted front pipe, stock mid pipe, and greddy sp elite axleback and did not get a CEL with this header over 7,653 miles. Take that for what it's worth.
Once I installed OFT, that's when I started getting a CEL, which I force tuned out.
kodyo is offline
Old 05-26-2015, 03:46 PM   #2504
FTemplar
Drives: BRZ Sport-tech 2013
So, what's the general consensus on this header? I am looking at buying a used one from someone in my local FRS/BRZ club. I saw in this thread that there is a new version, but i'm gonna assume the one he is selling me is the first version.
Torque dip ? HP gains ? Check engine probabilities ? I have a K&N Drop-in air filter and a 'Lachute Performance' Catback.
Thanks & regards
FTemplar is offline
Old 05-26-2015, 08:30 PM   #2505
kodyo
Drives: Scion FR-S
Thanks & regards
I noticed more linear power transfer. HP gains? Maybe a few, hard to say. With your mods, I'd say probability of check engine is low. But use at your own risk. I've never knew they were making a V2, I guess I have a V1 and quite like it.
kodyo is offline
Old 05-26-2015, 08:34 PM   #2506
DGM86
Thanks & regards
You won't get the same gains as you would from a catless header and both really need a tune to unlock the gains, but I think the catted UELs sound better. Certainly easier to keep the loudness and rasp under control. I've had mine for a few weeks now and according to the butt dyno there's a slight gain in peak power, but it can't be much more than 5-10 hp. FT86SF claims 14hp and 5 lb-ft peak gain, which seems high to me but not unreasonably so. However, I am not running any intake mods as of yet, and mods are often complimentary.
I do really notice it at the bottom end. Torque dip isn't gone, but close, and there's a very noticeable improvement in power across the daily driver rpm range. I find the car is easier to drive now, even though the clutch still sucks. Not really sure why that is, but I feel it.
I'll post a video of the sound as soon as I can figure out how. It sounds fantastic.
DGM86 is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
