Old 06-27-2015, 06:27 PM   #2507
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Originally Posted by keithr View Post
That would imply, then, that the 2015 MT is somehow unique vs the 12-14?
Can @Jackson Racing or @CSG Mike comment?
Yes. Happened to me when I bought a used kit. Got the carb tune for a 2014 BRZ, wouldn't work on my 2015.
ScionOfHorus is offline   Reply With Quote
Old 06-27-2015, 06:41 PM   #2508
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
Ok, but that doesn't answer the question of _what_ is different.
Look forward to hearing from Jackson directly or CSG.
keithr is offline   Reply With Quote
Old 06-27-2015, 06:42 PM   #2509
ScionOfHorus
Minor ECU things according to Moto-East.
Old 06-28-2015, 04:23 AM   #2510
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Delicious Tuning endurance testing on a 2013 Subaru BRZ with a Jackson Racing Supercharger Kit. The vehicle is also equipped with only a Milltek cat back exhaust, Jackson Racing Oil Cooler and our wonderful California 91 Octane. The vehicle is now equipped with our Flash & Go Tune with a few small tweaks on the low end for a bit more torque and better low end drivability.
[ame]http://www.youtube.com/watch?v=kJ7q5NrNuOk[/ame]
_______________________________________
Final Numbers by Delicious Tuning (Dyno Below)
255 hp @ 7200 RPM
199 tq @ 6200 RPM
Baseline Jackson CARB Tune (Dyno Below)
239 hp @ 6600 RPM
195 tq @ 6400 RPM
Baseline Dyno - Stock BRZ (Dyno Below)
175 hp @ 7300 RPM
138 tq @ 2800 RPM
Cheers,
William Knose
Old 06-29-2015, 02:54 AM   #2511
SPCorBUST
SPCorBUST's Avatar
255 hp @ 7200 RPM
199 tq @ 6200 RPM
239 hp @ 6600 RPM
195 tq @ 6400 RPM
175 hp @ 7300 RPM
138 tq @ 2800 RPM
Cheers,
William Knose
Any numbers you can throw out for JR kit on E85?
SPCorBUST is offline   Reply With Quote
Old 06-29-2015, 03:50 AM   #2512
Originally Posted by Nick86 View Post
Hey guys,
I'm at the ECU Calibration stage of my factory tune install. My USB key with the BIN file actually contains two BINs:
ZA1JA01C-BRZ-CARB-6B29BD.BIN
ZA1JD00C-BRZ-CARB-JR-15MT-6B29BD.BIN
Can anyone advise what the difference is between them? It's Saturday and Support is closed, and I've got to get this car ready for a tire-smokin' autocross tomorrow. Any advice or hints on what the "15MT" indicates in the file name would be appreciated.
2013-2014 use the same tune
2015 uses a slightly different tune due to a slightly revised ECU.
Functionality is identical; only changes are to accommodate differences in the ECU, that do not affect performance, emissions, or driveability.
There are 4 CARB tunes in existence, and all new CARB kits come with all 4; all 4 tunes are tied to that specific Ecutek license/dongle.
- 13/14 AT
- 13/14 MT
- 15+ AT
- 15+ MT
Old 07-01-2015, 01:57 PM   #2513
Xuningshen
Drives: Subaru BRZ
my fuel trims have still been beyond funky. my MAF got dirty, cleaned it, put new maf o rings. Jackson racing told me to remove my Radium PCV catch can and that improved my fuel trims. I checked all my piping and all of my vacuum lines(including under the intake manifold. I'm reaching 7psi at red line according to my mechanical boost gauge T'd from the brakebooster as well. Using the little plastic BPV. I was using a turbosmart kompact 25mm dual port BPV/BOV but switch it back out, and it made 0 difference in fuel trims. Only have a catback exhaust. and am running a CCV radium catch can still. Thinking about removing that one and seeing if it makes a difference.
my LTFT at idle is -14 to -16. under light throttle my trims are like -9 LTFT and +9 STFT to a good -3% LTFT and +3% STFT.... when i go WOT it goes to -13%. been bugging me for a while now.
I may post a log later.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 07-01-2015, 04:27 PM   #2514
enivid
enivid's Avatar
Drives: WRB JR BRZED
Who's tune?
enivid is offline   Reply With Quote
Old 07-01-2015, 04:54 PM   #2515
Can you post a *FULL* list of modifications on your car?
Old 07-01-2015, 05:32 PM   #2516
Xuningshen
Drives: Subaru BRZ
Originally Posted by enivid View Post
Who's tune?
Carb Tune
Right now, after I removed a couple things... engine related stuff only...
Radium CCV Catch Can
Corsa Cat back exhaust
SS line to oil pressure at the plug next to the AC condensor
JR oil cooler
then just another T in the vac line from the brake booster to the BPV that goes to a mechanical boost gauge. its a T that has a reducer to the gauge line so its not taking away vac.
I think that is it....
I'm about ready to take off my CCV radium catch can and see if it does anything.
2014 WRB BRZ
Old 07-01-2015, 05:44 PM   #2517
Carb Tune
JR oil cooler
Can you post some pics of your engine bay?
Old 07-01-2015, 05:52 PM   #2518
Xuningshen
Drives: Subaru BRZ
I will once i'm off work!
2014 WRB BRZ
Old 07-01-2015, 06:28 PM   #2519
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Is this whining sound normal? It goes away above 3000rpm and sounds like the typical SC whine after that.
Consistently makes the noise below 3k regardless of condition (cold, warmed up).
It didn't make this sound until today (used to be near silent).
@CSG Mike @Jackson Racing
Also, what's the best email address for JR?
Old 07-01-2015, 06:32 PM   #2520
Support@
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
