Old 08-26-2015, 06:00 AM   #253
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Originally Posted by CSG David View Post
I've driven many mobile vehicles in my lifetime from Vons handicap carts to buses to 750HP C6Z06 and 800HP GTRs. The definition of slow is 55 passengers in this puppy, but I'm pretty sure most people do not have the same experiences.
For the record, the 800HP GTR felt slow, but the speeds that I saw were not slow...
You were a UCSD bus driver?!?!?! What year?
ohmai18 is offline   Reply With Quote
Old 08-26-2015, 06:05 AM   #254
He may have attempted to drift the bus...
Old 08-26-2015, 08:59 AM   #255
CSG David
CSG David's Avatar
2006-2007.
Old 08-28-2015, 01:58 PM   #256
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
2006-2007.
Ohhhh. I missed that then. I came in years later.
Old 07-20-2016, 11:40 AM   #257
Arcadien Angel
I may be an idiot
Arcadien Angel's Avatar
Drives: Winona - White 2014 Scion FR-S
For comparison purposes.... the kits are identical, and both use the same pulley. This is how dramatic the difference is with breathing mods with a supercharger. DO NOT use catless pipes with the CARB tune. The CARB tune is intended for cars with both OEM catalytic converters.
So... question. But first, info: My FRS has a custom exhaust setup. Gruppe-S UEL Uncatted headers, 2.5" OP, and then the front pipe Y's off into a dual exhaust controlled by an electronic valve, which comes back together just before the Greddy Supreme SP muffler. One side is a 2.5" straight pipe (loud side). The other side has a catalytic converter, pass-through mufflers and resonators (quiet side).
Now question: Since you say to not use catless pipes with the carb tune, obviously I cannot run my exhaust system with it. But if I were to get it custom tuned, if it's tuned for the loud side, would it not be usable with the quiet side? Or is the custom tune a little more lenient? I'd like to retain the full function of the exhaust, but I also don't want to run shitty half the time, you know? What are my options here? Any advice?
Thanks in advance,
Angel
Winona, My Wingless Angel
Edelbrock SC w/ Flex Fuel - 18x9.5 Titan 7 wheels w/ 265/35x18 Michelin PS4S - Radium Dual Catch Cans - Verus Aero - OEM Brembos - Prototype HVT 6100e Dynamic Dampening Coilovers - JDL 4-2-1 EL / OP / Dual Catted FP w/ Greddy SP Supreme Catback
Arcadien Angel is offline   Reply With Quote
Old 07-20-2016, 04:43 PM   #258
Thanks in advance,
Angel
That depends on how precise your custom tune is. Why not use map switching to have a tune for both sides?
Old 07-22-2016, 12:40 PM   #259
Arcadien Angel
I may be an idiot
That would work, but I'd like an instant response with it then. As soon as I open the valve, the map changes to accommodate. I could be wrong, but as far as my knowledge goes, there isn't a way to swap maps that quickly, especially while driving.
I appreciate the response though. I'll look into it.
Old 07-22-2016, 12:53 PM   #260
Ah, but there is with Ecutek, via the cruise control stalk. Pull it toward you and hold, and your tach will move to a number to indicate the map you're on. Press up or down to select a different map, and pull again to set.
Old 07-22-2016, 12:58 PM   #261
Arcadien Angel
I may be an idiot
Really now? That sounds like exactly what I'd need. They can be switched with the CC stalk, but can it be done while the car is running and moving?
Old 07-22-2016, 12:58 PM   #262
Yup, anytime the ignition is on.
Old 07-22-2016, 01:01 PM   #263
Arcadien Angel
I may be an idiot
Perfect. I'll look further into it. Thanks very much for the help.
Old 07-10-2017, 03:21 AM   #264
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Would running a caTless EL be more efficient for this SC than a UEL? I'd like to keep my ceramic coated Gruppe-S but won't if a good EL would be a lot more efficient
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 07-11-2017, 03:27 PM   #265
CSG David
CSG David's Avatar
Yes. When boosted, the UEL is meant for sound more so than "torque".
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) Drift-Office Forced Induction 164 06-20-2014 01:43 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
