Old 01-21-2016, 05:45 PM   #15
DAEMANO
Time Traveller
Originally Posted by Keenercarguy View Post
And it just fits right in to the standard tray and bracket? Sounds pretty good to me... @DAEMANO
It fits into the standard tray, but you might need a new bracket. I am using a custom hold down block from my Phantom ESC kit. A few companies (including Odyssey) make them for the PC680, Amazon has a few, even more with an internet search (Ebay, Bing, Google, etc).
http://www.ebay.com/sch/i.html?_nkw=pc680+mount
https://www.bing.com/search?q=Odysse...0A5918BDB510F9
[ame="http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Dautomotive&field-keywords=odyssey+pc680+hold+down&sprefix=odyssey+b attery%2Cautomotive%2C222"]Amazon.com: odyssey pc680 hold down: Automotive[/ame]
Old 01-21-2016, 08:18 PM   #16
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I'm a big fan of my Ballistic Evo2 battery, can't speak for daily drivability, but I can say that it's sat for up to a month in the winter without being connected to a charger and started the car right up. Plus it weighs in at 2.5 lbs...
Decay107 is offline   Reply With Quote
Old 01-21-2016, 08:34 PM   #17
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
I have this with a kill switch and it has been rock solid.
http://store.kcmachine.com/products/...ckage-preorder
mokinbird87 is offline   Reply With Quote
Old 01-21-2016, 11:05 PM   #18
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
it honestly depends how much you drive. If your commute is long enough to charge the battery then you will be fine. It if is not you will be in trouble.
If you are not familiar with creating your own battery tray, either have it professionally done or buy a ready made solution.
Do you use the PC680MJT with te SAE terminals? Do you have to run any adapters on it? And how on earth do you get away with 170CCA???
CCA is almost meaningless. It is basically just a number to advertise. It is especially worthless if the car is never in the cold.What are CCA?
Old 01-22-2016, 01:18 AM   #19
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
So has anyone used the lightweight battery kit from FT86Speedfactory with the 11lb braille?
(http://www.ft86speedfactory.com/ft-8...l#.VqG66etJqWU)
I'm considering it the most because it's by far the best option in my price range as far as I can tell, full package wise. I honestly can't really afford to drop $400 on the KCMachine because I set my price limit to ~$250+/- for this particular expenditure.
Looking for any firsthand experience with FT86Speedfactory's lightweight battery kit.
Keenercarguy is offline   Reply With Quote
Old 01-22-2016, 11:21 AM   #20
stevesnj
stevesnj's Avatar
Alot of these batteries are the same battery usually Mfg. in the same plant. Then the third party puts an $800 sticker on it.With Li-Io shop by specs needed then price.
My 2016 Build thread
Old 01-22-2016, 08:56 PM   #21
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Second this....looking for some feedback.
n8dog11914 is offline   Reply With Quote
Old 01-23-2016, 03:38 PM   #22
Keenercarguy
Mountain Runner
@n8dog11914 I talked to a random guy who had one in his daily driving build thread and he said it was running just fine for a long time, and he lives in MD if I remember correctly. I'm still looking for more reviews though.
Old 01-23-2016, 09:06 PM   #23
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
More Testing Needed
I wish there was an "Enthusiast Consumer Reports" to test all of these lithium batteries. I really think they are the future, but they need real honest testing and data to refute and/or confirm some of the claims made by the manufacturers or sellers. Also, a good manual on how to properly care for them, how to treat them in cold weather, and possible mods to the car's charging and/or starting system to better use these batteries. Automakers spend $$$$$ trying to eke out every last MPG on some cars with all kinds of goofy features and electronic gizmos, but apparently haven't yet tried to research the weight savings available in lithium starting batteries (they do in electric vehicles though, and they seem to work fine there).
Here is a company that seems a bit goofy, but may have some interesting products. They even do some rudimentary testing if you look at the gallery sections:
LithiumMoto Batteries
Here is a company focused on powersports, but has products that should work for starting our cars. This one seems to have the experience and knowledge to give some good advice:
Antigravity Batteries
This one no longer lists batteries for daily car-starting use, but used to and would probably still be able to spec one if asked. They probably also have the knowledge to give some good advice.
Lithium Pros Batteries
Old 01-23-2016, 11:41 PM   #24
why?
why?'s Avatar
Drives: series.blue
This. There is only 2 or 3 battery manufacturing plants in the USA, and all the different batteries and brands come from them. Battery brands are worse than GM at renaming crap.
Old 01-24-2016, 11:44 AM   #25
bhmax
Drives: 13 BRZ, 17 Focus RS
I ran an Antigravity 20 cell for 2 years in an Evo before I sold the car. Worked great for me, just a bit slow to start after sitting for about 3-4 days in the winter in TN (so no colder than usually 15-20F at night). I plan on one for this car with a PTuning mount.
bhmax is offline   Reply With Quote
Old 02-01-2016, 04:12 AM   #26
Nessal
Drives: Exige, Miata, Ghia
If it is a DD, I would not suggest running a small battery unless you are diligent about hooking it up to a tender. Another thing that sucks about such a tiny battery is the reserve charge. Don't expect to listen to your stereo for any extended period of time. In fact, I kill my radio as soon as the engine stops running. IMO, it's just not worth it unless it's a weekend car.
Nessal is offline   Reply With Quote
Old 02-02-2016, 11:24 PM   #27
stevo585
Drives: White 2014 BRZ
I have a PC680 as the starter battery for an ESC setup. Works fine can't even tell the difference between stock.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 08-01-2016, 01:46 PM   #28
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I am using a Yuasa 44B19L battery:
It is almost half the weight of the OEM battery and still useful in a daily driven car. It fits perfectly in the BRZ RA's battery holder (Japan spec). So, no need for custom solutions.
I replaced the following Subaru parts. Part numbers are for the new ones:
Tray-Battery
82122CA010 x 1
Rod-Battery Fix
82161AG001 x 1
Holder-Battery Fix
82182AG010 x 1
Dimensions of the battery:
Length (mm) 187
Width (mm) 127
Height (mm) 225
Any other battery with similar dimensions will work.
battery, daily driver, lightweight battery, track, weight reduction
MAW lightweight battery kit. Turn in Concepts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-24-2016 07:57 PM
*BRZ Part Out* KCMachine lightweight battery xDanger_208x Engine, Exhaust, Bolt-Ons 2 03-31-2015 02:40 AM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
OEM shorter lightweight battery bracket? fstlane Tracking / Autocross / HPDE / Drifting 1 03-08-2014 01:26 PM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Tracking / Autocross / HPDE / Drifting 5 12-07-2013 03:01 PM
