#15 |
Drives: 2016 Subaru BRZ
I never said they were they same, nor did I ever say they were quality, in fact I think I said they were crap. But that sometimes cheap crap works, and sometimes it doesn't
#16 | |
Drives: 2015 BRZ Ltd
I am going to try the ones I purchased from The Retrofit Source and see how it goes. They are on back order though, and should ship out by Feb 28th... so I don't have an update yet on whether the bulbs are definitely the issue. |
#17 |
Drives: 2013 Subaru Brz Satin White Pearl
Which ones you ordering? The morimoto ones are pretty nice and very affordable
Sent from my SM-G900V using Tapatalk |
#18 | |
https://www.theretrofitsource.com/co...7#.Vq_krVIsA40 They only had 2 options on The Retrofit Source site when I placed my order. Morimoto wasn't one of them. And the other brand I didn't recognize lol |
#19 |
Site Moderator
Drives: Stuff
You reduced light output, not improved it and probably went from high quality OEM bulbs to Chinese stuff.
Ordering a set from an OEM brand was a good move.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#20 | |
Drives: 2013 Black BRZ Limited
![]() You have less usable light, not more. Also - did you swap out the ballasts as well when you swapped out the bulbs? The stock ballasts may not play nicely with the aftermarket bulbs due to in rush current demands. |
#21 |
What's the lumen output on factory 4300's? Secondly what is the wattage of the factory 4300's if there 35 watt like the Phillips there shouldn't be any more load than factory.
#22 |
And one more thing if they're are instant ignition like the factory there would not be a difference in startup load compared to factory either.
#23 |
Drives: '13 BRZ
I had the exact same issue and dd sent me a new pair no questions asked. I haven't installed them yet as my car is in storage for the winter... Hope they turn out good.
These are the replacement bulbs they sent me
#24 |
you can usually tell if the bulbs are either decent quality or cheap chinese crap if you look at the bulb closely. there should be a little bubble where there are salts inside. look at that bubble and if there is barely any salt in there, it is usually a sign of a lower quality bulb. take a look at both bulbs and see if the salts in each bulb are about the same amount. usually, cheaper bulbs have bad QC and the salts would differ in each bulb.
#25 | |
and no i only swapped out the bulbs. i did not touch the ballasts. |
#26 | |
Drives: '13 BRZ
#27 |
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I also had a problem with a set of DD's 6000k bulbs. The driver's side went out. I put my OEM's back in and no problems. They were about 9 months old. Did you notice any strange smells coming from the fixture when you took the bad ones out? That worried me. The connector looked kinda dirty/corroded as well.
I've had a lot of other dealings with Diode Dynamics by the way, including changing my mind on color temps and such, and they've always had great service. |
#28 | |
Sent from my VS986 using Tapatalk
| Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic | ecko04 | Electronics | Audio | NAV | Infotainment | 10 | 05-05-2018 04:47 PM |
| AT frs rpm issue | ricebox | Issues | Warranty | Recalls / TSB | 18 | 01-04-2016 02:01 AM |
| OFT IAM issue | Tectoniic | Software Tuning | 23 | 10-28-2015 06:52 PM |
| Need help with FI issue!! | Jhood | Forced Induction | 16 | 09-07-2015 11:04 PM |
| Anyone having this issue? | zoomzoomers | BRZ First-Gen (2012+) — General Topics | 11 | 08-10-2012 12:19 AM |
