#15 | |
Pharmasaurus Magnificus
I have an FRS and i want the subaru wing, if the trunk liner can be removed and ported would you be interested? Year: '13 Make: Scion Model: FRS Color: Whiteout Trim: N/A Location: Orange County, CA (Placentia area, can travel)
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85 2015 Nissan GTR Last edited by chate; 07-03-2012 at 08:35 PM. |
#16 | |
Mr. Sarcasm
Take pics and show them you traded rather than wrecked
#17 | |
Drives: SWP BRZ Limited MT
Can anybody also confirm this? |
#18 | |
Mr. Sarcasm
![]() They are built in the same place in Subaru's plant. It's the same white
#19 |
I usually post drunk
I believe it will definitely hurt resale value if you trade it in later, but as far as private party sales with my limited experience I have not seen anyone look for VINs on all (or any) the body panels. But then again it wasn't sports cars.
#20 |
Drives: 2013 SWP Limited BRZ - Manual
#21 |
Drives: 16 Impreza 5dr CWP
Yep, same color codes and all. The only difference is Subaru didn't use their Paprika Red Pearl to Scion/Toyotas Hot Lava.
#22 |
Drives: Porsche
#23 |
Yep, you got it:
Asphalt - 61K - Dark Gray Metallic Argento - D6S - Sterling Silver Metallic Firestorm - C7P - Lightning Red Hot Lava - H8R -Subaru didn't release Paprika Red Pearl - D2T Raven - D4S - Crystal Black Silica Ultramarine - E8H - Galaxy Blue Silica Whiteout - 37J - Satin White Pearl World Rally Blue Pearl - 02C Toyota didn't release anything comparable |
#24 |
Ok thanks guys for confirming! I just wasn't sure that's why I had asked people here.
![]() Chate PM'ed!
#25 |
PMd back...yay i cant wait to have a spoiler! And i'm never gonna sell this car (DD till death) so i dont care much about resale value
is there a DIY on trunk lid removal somewhere?
AEM CAI / Magnaflow Catback / OFT / OFH / e85 2015 Nissan GTR |
#26 |
#27 |
So here's the question folks, Essentially we want to swap, one gets a spoiler, the other gets flat trunk and I want to know the best way to do it. Both of these cars are identical besides badging and we know VINs will be different and there really are only 2 ways to make this work:
1. Remove spoiler and patch holes and install spoiler on other car 2. Swap trunk lids (will also need to swap the lock mechanism of trunk to retain keys and swap badges, must also ensure alignment of lid and vin numbers wont match) Any body shop folks want to chime in on this venture and its cost/value?
#28 |
Looking at my trunk lid (and i'm putting this here for reference in case anyone else is doing the swap) it looks pretty simple (but i'd like you guys to chime in)
Step1: Remove the lock mechanism Here you can see there a little wire that passes through the green portion and ends in a ball which is lodged between a U shaped anchoring piece, you'll need to twist this open to release the ball, which lets you pull off the lock portion Step2: Unbolt the lock from the lid- this picture shows the wire/ball thing too Step 3: Disconnect wire that powers lights, and remove rubber piece This white connector at the top of the inside of the trunk is what needs to be disconnected, once this is disconnected you should be able to pull the trunk half of the wire back up through the hole in the body where the rubber piece was Step4: Once this is done it should be a matter of unbolting the 4 bolts (2 on each side) that connect the trunk lid to the bracket (do not even undo the hydraulic things that hold it up, just lid from bracket) 2 on right: 2 on left: at this point you should have one trunk lid off one of the cars, now do the same thing to the other car, while lying the first one on a bed of silk of course, and reverse the process and swap the badges, voila, trunk swap! Ok will that work??
| Official What are you listening to thread? | TRDMAN | Off-Topic Lounge [WARNING: NO POLITICS] | 2322 | 09-15-2026 07:05 AM |
| Official San Antonio , TX Thread!! | track_warrior | Southwest | 3762 | 03-28-2019 03:03 PM |
| Trade: official FR-S cap & USB jump drive | terrypm | Exterior Parts (Aero, Lighting, Etc.) | 3 | 08-11-2012 08:30 PM |
| What's in your trunk/car thread? | S2kphile | Off-Topic Lounge [WARNING: NO POLITICS] | 40 | 02-23-2012 04:07 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
