#15 | |
Drives: 2013 Toyota 86 (Hot Lave)
Same here. It started off only making noises over uneven terrain but now even under braking, its slight audible. I think changing any suspension component only either dampens it or aggravates it. I had my tire rods changed by some garage just after owning it, it kind of made it a little worse. Keep us posted on your progress. Here in UAE, the dealer has indirectly admitted to the problem and its a potential hazard as one can lose power steering (as per them). The only solution they are currently providing is to replace the EPS (~$1,500).
#16 | |
TRACKBREAD
Electric Power Steering (EPS) noisy
There's no chance of you losing power steering because of this noise. Dealer service counter people usually don't know very much. The system is functioning as intended. Large input forces from the road are normally transferred to the steering wheel. The EPS soaks up those inputs. A side effect is the rattling. Ideally when the EPS is tight with very little gear slop, it's inaudible. On some cars, mine included, it's quite loud. There's probably a way to fix it other than to replace the EPS or straight up delete it. Either way, it's an annoyance, not a safety issue. Last edited by Yoshoobaroo; 10-09-2018 at 10:29 AM. |
#17 |
TRACKBREAD
#18 |
Sorry, I've not had a chance to mess with it yet.
#19 |
Following
#20 |
While we wait for a fix, I recorded a few videos of my rattling EPS and just curious to know if you guys are experiencing the same rattling or less or worse:
(you can here it from 3 secs onwards) |
#21 |
Yes! Exactly that.
#22 | |
There hasn't been much talk because it is very rare so isn't much of a problem.
#23 | |
Here is some video of the system on the Corolla. As you can see it looks identical. The C200h is also the same setup. [ame]https://www.youtube.com/watch?v=iv8jRd8sads[/ame] I suspect it's more common it's just people create threads like, "Clunk in suspension" because that is what it sounds like. There is a lot more talk about it on the Corolla because they sell way more and people can get more than 80K on those before they blow up. Hahaha |
#24 |
If you mean that both are an electric motor and a set of gears then yes they are similar but so are just about every other make. If there is a problem with the EPS on some other make it does not automatically cross all makes. Search Subaru EPS issues to find out more accurate info.
#25 | |
Let's not derail another thread with arguments about how rare shit is. People in this thread all have the same problem and we should keep it productive. |
#26 |
Here is an interesting video:
[ame]https://www.youtube.com/watch?v=fsP_qDCmxQ8[/ame] |
#27 | |
I was attempting to assist by pointing out that they are not the same but if you see everything as an attack then that is fine.
#28 |
I asked you how they are different and you didn't answer. The fact is you have no clue what is inside. They have identical housings but yes the internals could be different. But you saying to research Subaru issues really discredits your argument as they aren't even made by the same company. I don't see this as an attack, I see it as you derailing another thread. Bring constructive info only.
| FS: OEM Electric Power Steering Column, with Motor and Module | MicheleAbbate | Interior Parts (Incl. Lighting) | 12 | 12-31-2018 04:47 PM |
| Recall for Electric power steering (EPS) | tm86 | AFRICA | 36 | 05-16-2017 08:04 AM |
| Electric Power Steering | ArtS | Electronics | Audio | NAV | Infotainment | 0 | 10-31-2016 09:19 AM |
| Electric Power Steering control module? | slicktop | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 11-21-2013 09:38 PM |
| Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 11:11 AM |
