Old 07-24-2017, 08:53 PM   #15
Originally Posted by lantsalot View Post
Ohm my, why must you offer up such resistance?
You seem stressed, you might want to try some meditation for that...
Ooohhhhmmmmm
He is old and not up to current events.
Old 07-24-2017, 09:40 PM   #16
Chaetagnath
Drives: Whiteout FRS
Originally Posted by itsAlex View Post
So its been a year since I've had this problem with my dome light. I replaced it with an LED bulb, and I have this issue where when the switch is set to "DOOR", the LED will be faintly lit when the doors are closed. When I open a door, the LED will fade darker, and then become a bit brighter again when I close the door. The LED stays faintly lit no matter how long I leave the car to sit, so now I just keep the dome switch to "OFF".
I'm pretty sure I know what the problem is, there's a blown MOSFET in the BIU under the driver's side and the component that needs to be replaced is an "a1764" MOSFET. I found this info from an older post:
http://www.ft86club.com/forums/showp...39&postcount=8
My question is, if I open up the BIU to perform any sort of work, am I voiding any significant warranty? I have the standard 3 year warranty that Toyota Canada offers on a new vehicle and I'm not too sure if replacing the BIU would be covered by that warranty.
You can also rewire the "door" circuit so that it is powered by the light that illuminates the ignition. I think somebody once posted how to do that, but I can't find it. Just consult the wiring diagram. Also, make sure you disconnect the battery before doing anything.
Chaetagnath is offline   Reply With Quote
Old 07-25-2017, 12:02 AM   #17
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, with modern technology he certainly has the power to change that.
Old 07-25-2017, 02:45 AM   #18
humfrz
would DIY maintenance void the warranty szjalo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 02-11-2017 01:07 AM
Will this void warranty? Ymerej Issues | Warranty | Recalls / TSB 16 02-13-2014 02:01 AM
Will e15 void the warranty? dawnst3ar Scion FR-S / Toyota 86 GT86 General Forum 5 12-05-2012 02:59 PM
What Will Void My Warranty ? ScionFR-S Issues | Warranty | Recalls / TSB 6 11-10-2012 12:36 AM
Will This Mod Void My Warranty? Apex Chase Engine, Exhaust, Transmission 7 07-17-2012 12:38 PM
