Old 11-03-2017, 02:28 AM   #15
humfrz
Well, OK, now it looks like the engine needs some work to seal the head(s) to the block.
They might as well do both sides while they are at it.
What a pain for you.
Keep us posted.
humfrz
Old 11-03-2017, 12:46 PM   #16
exE36M3
In case you guys want to see what a blown head gasket look like - this is where mine started to leak. And before ANYONE says ANYTHING - my engine is 100% stock.
Photos on Google Photos...
https://photos.app.goo.gl/KVVRlENs8wQ26a2r2
exE36M3 is offline   Reply With Quote
Old 11-05-2017, 05:28 PM   #17
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I'm at 88k and I have oil in that spot as well. Wonder if PCV?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 11-08-2017, 11:15 AM   #18
exE36M3
Yeah, I inspected the PCV, the fitting was bone dry. If you run your hand under the intake runners and surrounding wiring, it's all wet with oil. So looking like oil is spraying or squirting. The paper towel test in my case also followed the seam of the head gasket. If it was the PCV, it would soak that portion of the towel. It didn't.
Driver side valve cover gasket leak solidONE Issues | Warranty | Recalls / TSB 59 02-22-2021 01:52 AM
Hole in valve cover burdickjp Issues | Warranty | Recalls / TSB 25 11-29-2016 10:37 PM
JDM Subaru Blue Valve Cover switchlanez Exterior Parts (Aero, Lighting, Etc.) 0 01-03-2016 12:37 AM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 09:31 AM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 10:42 PM
