Old 12-15-2017, 02:11 AM   #15
Lust
Drives: 2017 Subaru BRZ
Originally Posted by ShibusaTouge View Post
Not talking about me in this instance. Just curious as to what everyone prefers.
I personally went with 18x9.5 with a 265 wide tire to accommodate for more power. It also looks better in my opinion
Lust is offline   Reply With Quote
Old 12-15-2017, 04:33 PM   #16
jamal
jamal's Avatar
Drives: Legacy GT
The other tire option is 255/40-17
I can't say for sure, but in the same tire the 265/35-18 will probably be a bit faster.
However, the 18s will be more expensive. Looking at stuff like a re71, rt615, rs4 etc, it's like 40-50% more.
So you spend a lot more money for minimal gains. Unless you are trying to race time attack competitively, in which case you should probably use all the tire the rules allow, I think I'd stick to the smaller wheels.
jamal is offline   Reply With Quote
Old 12-15-2017, 04:43 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I'm stuck between the benefits of each tire. The 18x9.5s can fit a 265, but weigh a tad more. The 17x9s are lighter, but are usually ran with a 245. Which is more important to you, lighter weight or more tire width?
So you aren't talking about yourself in this instance but you want our opinions about the difference between the two?
Are we having a conversation for the sake of conversation or an actual discussion about pros and cons to help you make a decision?
Old 12-15-2017, 05:28 PM   #18
Icecreamtruk
Drives: Track preped NA FRS
Every time I've gone wider I've gone faster thru the corners. It usually end up in faster lap times as almost all of the tracks (with the exception of 1) I run at are small and twisties with almost no straight whatsoever. The widest I've gone is 245 in 9". Im going to 255 in 9" this year because the tire I want is either 235 or 255.
So in my experience, all the way to 245, wider = faster around the track. YMMV.
Old 12-15-2017, 06:22 PM   #19
Racecomp Engineering
What kind of tire?
- Andrew
Old 12-15-2017, 06:28 PM   #20
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
Originally Posted by Racecomp Engineering View Post
What kind of tire?
- Andrew
200tw. This is mainly for the sake of general comparison, not for me necessarily. I'm interested in the extra width vs less weight debate
ShibusaTouge is offline   Reply With Quote
Old 12-15-2017, 08:51 PM   #21
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I'll jump in the muddy water...
255/40 is the largest recommended 17. And because there is no 265/35/17 Or 275/35/17, getting a wider tire means getting larger wheels.
It's been discussed, but street tires are terrible for AutoX. R compound is the way to go, and may have a lower utqg than 200.
Big money has to be spent to get better wheels for competition than the RPF1. 17's seem like the logical conclusion.
17x9.5 forgestars are available for 335 each. Which is half way to a rays or volk wheel.
And in conclusion: Weight vs width. You have to have a reason to care about grams and tenths of seconds. To many variables here to have a real debate. You do not need extra width till you have extra power. A 255/40 Toyo r888 weighs 26lbs, a 265/35 18 weighs 28lbs.
I LIKE TIRES!
Old 12-16-2017, 05:07 AM   #22
MyGT86Yas
Drives: 2017 WRB BRZ
Had a set of 245/40/18 on my stock power 86 with suspensions before, really didn't like it. Yes it gives a lot more grip compare to the stock tires, but I felt like I couldn't turn the car using the throttle anymore (not sure if this make sense).
MyGT86Yas is offline   Reply With Quote
Old 12-16-2017, 07:44 AM   #23
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Personally... I’d choose weight savings every time.
I like driving!
86 South Africa is offline   Reply With Quote
Old 12-16-2017, 08:54 PM   #24
wparsons
wparsons's Avatar
Any street tire class in autox requires a 200tw tire... even if they're not really 200 in reality (like the RE71R, Rival S 1.5, etc).
True r compounds put you in a class that requires a ton of other mods to be competitive, and if you're in that type of class you'll want to be on Hoosier's.
flickr
Old 12-16-2017, 11:36 PM   #25
mav1178
mav1178's Avatar
So this is not for you, but a general discussion.
All else being equal, 18x9.5" will net you ZERO benefits on the track, because the tire you run will be way too much grip for track.
The only reason to go that wide and large is if you have a brake kit requiring 18" wheels for clearance, and you make enough power or have enough aero enhancements to take advantage of 255+ width tires. Otherwise, 17x9" is plenty width for a NA powered car. Hell, with stock engine you should basically max out at 225 or 235 width tires.
The only type of track you will see benefits from running 18x9.5" is if you are running Ebisu-type circuits where it's a glorified karting track.
-alex
Old 12-16-2017, 11:56 PM   #26
churchx
churchx's Avatar
Drives: 2014 GT86
I sometimes wish for brake and wheel manufacturers to decide on some common standards for brake clearance. It would have SO simplified wheel choice if there had been some known index specced for both brakes & wheels instead of current situation, where one can at most use fitment templates, if such exist (for example, i since long wanted to find nice set of 15 wheels that would fit over stockers, but of course, no one had made such template for stock brakes).
Old 12-17-2017, 01:48 AM   #27
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I went from 18's staggered to 17's squared and was a huge difference on track and day to day driving. I ended up going with wedssport tc105n which is one of the lightest 17x9 on the market. would highly recommend those wheels with 245/40 or if you want more tire you can run a 255/40
Instagram: trevor.parque
Old 12-18-2017, 09:52 AM   #28
ZDan
ZDan's Avatar
Drives: '23 BRZ
http://www.roadandtrack.com/car-cult...ransformation/
FR-S tire test
215/45-17 Michelin Primacy HP: 1:29.3 lap time
215/45-17 Dunlop Z1 *spec: 1:27.0 lap time
235/40-18 Dunlop Z1 *spec: 1:27.6 lap time
17x9, 18x9.5, tire size, track, width
WTB: RPF1'S 17x9 or 18x9.5 ReeceR34 Want-To-Buy Requests 1 02-09-2017 12:48 PM
17x9 and 18x9? Higher Being Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 05-28-2015 02:45 AM
WTB: 18x9.5/ 18x9/ 17x9/ 17x9.5 Square With or without tires loogs Wheels and Tires 11 12-08-2013 04:40 PM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 02:35 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 02:52 AM
