Old 01-08-2018, 06:28 PM   #15
Byron8805
Byron8805's Avatar
Drives: 2013 BRZ Limited - Galaxy Blue
Interior Work
Did a little blacking of the interior with an MT shift knob, Perrin drift turn knob, door, vent, and wheel trims.
Byron8805 is offline   Reply With Quote
Old 01-08-2018, 06:30 PM   #16
Byron8805
Byron8805's Avatar
Garage Space
This is about as good as I get at garage space utilization.
Old 01-08-2018, 06:45 PM   #17
Byron8805
Byron8805's Avatar
Dipped the Wheels
I performed the oft-derided procedure of dipping my wheels. Clearly, if you know the twins then you know its a cheap mod and maybe that colors how you see it (or maybe not). In any case, I like the way it looks and its stuck fine for almost two years now. I used a satin paint over the dip to give it a bit of a different look (an idea stolen from another member). I didn't perform it at the same time but by now the car is wearing B2 wheel spacers (20/25). Also, right before dipping I got the Prius tires changed out (finally wore them down) for Sumitomo HTR-Z III's. Cheap tires but I like the feel over the stock tires for sure. Also, I had apparently installed my Berk muffler delete as well. Again, a suitable exhaust mod to run for a while if you just want more grunt and decibels and don't intend to pair it with anything else. I may get a catted UEL header in the future but I'll probably swap the catback at that point so it's not obnoxious.
Old 01-08-2018, 06:47 PM   #18
Byron8805
Byron8805's Avatar
Copilot
I got me another fur baby! Everyone needs a copilot.
Old 01-08-2018, 06:55 PM   #19
Byron8805
Byron8805's Avatar
Around Town Shots
Some random shots around town.
Old 01-08-2018, 06:58 PM   #20
Byron8805
Byron8805's Avatar
Wet day
Baby you make me so wet!!
Old 01-08-2018, 07:06 PM   #21
Byron8805
Byron8805's Avatar
Rear Sway Bar
Swapped out the stock rear sway bar for the 08 (iirc) WRX bar. I think its a 14-15mm jump, maybe 16. I was pretty happy with the car's handling before but would get the rear end to roll on sharper, faster turns. This bar is a very good match for the stock suspension system and stock front bar. Now I am very happy with handling and don't really see a need to upgrade either bar in the future for daily driving or light canyon/trackday purposes.
Old 01-08-2018, 07:12 PM   #22
Byron8805
Byron8805's Avatar
Velox Cam Plate
Well, after five years I finally noticed the cam plate leaking a bit. Not terrible, but enough for me to shell out for the Velox cam plate with the little plugged up hole to allow connection to their AOS kit. Very happy with the product and no more leaks as of yet.
Old 01-08-2018, 07:21 PM   #23
Byron8805
Byron8805's Avatar
Radium MC Brace
This quick little mod really stiffened up the brake pedal. Highly recommended for the price.
brz, build thread, daily driver, limited
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
SWP's 13' BRZ Build Thread SWP BRZ Member's Car Journals 2 01-16-2015 02:23 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
