#15 | |
Drives: 2017 Subaru BRZ
#16 |
No, I never had time to look into it further due to another project car.
I have custom tune, so was going to try a base FBM tune to see if it does the sane thing. Also, was thinking if could something with MAF settings. What’s your specs and are you using a FBM base tune or custom?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock |
#17 | |
I'm running their premium kit with a gtx3076r, fx400 clutch, fbm walbro 485lph pump, id1000 injectors, motoeast flex fuel kit, etc... |
#18 | |
#19 | |
I would not recommend running a basemap for any longer than necessary. They're really only designed to get your car to the shop for a custom tune |
#20 |
Drives: 2014 86 GTS
fellas its your base idle in gear timing, set too high. return to stock timing for these tables to resolve
#21 |
Drives: 2017 WRB BRZ
Had the exact same issue. The car was running fine and one day it just stalled on the freeway and wouldn't start. Car would only started with little gas and I had to keep revving the engine. But then I notice when stop and left in gear the engine rev up to 3000rpm by itself, and went back to normal idle when in neutral. The problem went away after a day or two, still kind of worry about it tho.
Mod: Edlebrock supercharger with dbox( maf sensor), straight e85, Sent from my Pixel 3 XL using Tapatalk Last edited by MyGT86Yas; 01-13-2020 at 11:11 AM. |
#22 |
Drives: 14 BSP Edelbrock BRZ
#23 |
#24 | |
I also have a base FBM tune which I will test just low speed to see if it’s a tuning issue or something else
| Super High LTFT +36.77% at idle? (E85 with OFT tune) | D4FD | Software Tuning | 11 | 09-05-2017 03:24 PM |
| Power lag in 2nd gear. Sporadic revs at idle | Norinradd | Issues | Warranty | Recalls / TSB | 22 | 06-09-2016 04:14 AM |
| high ltft at idle, my how to fix it(not fixed yet) | trdric | Software Tuning | 16 | 06-18-2015 11:27 PM |
| Buzzing/Humming sound at high idle | DGM.BRZ | Issues | Warranty | Recalls / TSB | 5 | 04-08-2015 09:04 PM |
| High coolant temp at idle with A/C off | extrashaky | Issues | Warranty | Recalls / TSB | 11 | 11-11-2014 05:50 PM |
