Old 07-19-2018, 10:48 PM   #15
steve99
Originally Posted by jtz54 View Post
I verified the comms is working. Was able to read realtime info using an ODBII reader and also with the OFT. Trying to read ECU using OFT still does not work.
I ordered an ECU off eBay that matches my car. I hope it isn't flashed. When I swap in the ECU do I have to change VIN# or mess with immobilizer system or is that info in a different place?
no you don't have to change VIN its just a reference, not used for security sync. The vin is in different chip in ecu , imobilier doent care in vin different
Car will start and run fine with different vin.
just do the 30 minute (at least 30) loop 4-13 with ignition FULL on not accessory. CEL light should flash entire time
Old 08-20-2018, 11:41 AM   #16
jtz54
Drives: 2015 Scion FR-S
Bought an ECU off eBay. Noticed it is an "HE" vs an "HY" unit and my FR-S is the 6 speed automatic (Seller didn't say what car except 2013-2015 FR-S). Swapped the units with the battery disconnected. Now the car starter won't engage??? Was wondering if the unit was from a manual car and it was looking for a clutch disengagement signal. Anyone know about this and how to correct it (swapped the original back in and it starts fine)?
jtz54 is offline   Reply With Quote
Old 08-20-2018, 01:49 PM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
Did you follow Steve's procedure?
Old 08-20-2018, 02:27 PM   #18
jtz54
Was Steve's procedure just turning the ignition to on for 30 minutes without starting it? All the lights came on but wouldn't engage the starter.
Sent from my SM-G955U using Tapatalk
Old 08-20-2018, 03:57 PM   #19
Ultramaroon
not playing cards
No. Read again. Did the CEL flash for that 30 minutes? You have to jumper a couple leads before turning on the ignition.
Old 08-20-2018, 04:31 PM   #20
jtz54
"just do the 30 minute (at least 30) loop 4-13 with ignition FULL on not accessory. CEL light should flash entire time"
So......short pins 4 & 13 then turn on the ignition without starting and watch for CEL light to flash for at least 30 minutes?
Is there a pinout of the ECU is this covered in another thread? Thanks for the info and patience!
Old 08-20-2018, 04:50 PM   #21
Ultramaroon
not playing cards
No offense but take some time to read all of Steve's responses to you in your own thread. In post 4 he linked you right to his procedure which includes all those details. He's done a shit ton of work to help us all. We just have to dig a little.
ecu, flash
BRZ locked me out while running Brooklyn Issues | Warranty | Recalls / TSB 16 12-15-2017 09:32 AM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 03:26 PM
Threads locked Wonderbar Site Announcements / Questions / Issues 4 02-11-2016 11:42 AM
To replace rims or not replace? unlimited86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 09-21-2015 01:12 PM
car locked me out grodenglaive Issues | Warranty | Recalls / TSB 29 02-22-2013 09:24 PM
