Old 10-22-2012, 07:47 PM   #15
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
I just had this issue today. I think it happened because I kept trying to fill it after the pump automatically shut off. In order to resolve the issue I had to disconnect the negative terminal of the battery to reset the car. This did fix it, though it issue is quite concerning.
SkitterSkotter is offline   Reply With Quote
Old 10-22-2012, 08:43 PM   #16
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
I had this issues as well... SkitterSkotter is right, if you pull the battery it is fixed. I believe I did the same thing he did by over filling. I was just in doubt because sometimes the gas pump stops for no darn reason when I know it is not full... Haha. Just try not to overfill... It can backup into the charcoal cannister in the Evap system and that won't be good. :P
Surakusa is offline   Reply With Quote
Old 10-22-2012, 09:13 PM   #17
Skye
Drives: TR2,CooperS,BRZ
If you've had a Subaru you know never top up the gas tank after the auto shut off.
Skye is offline   Reply With Quote
Old 10-22-2012, 09:51 PM   #18
SkitterSkotter
Yeah you are totally right on that, I'm glad to hear that I'm not the only one who had this issue.
Thanks for the advice, I've never owned a Subaru before...noted!
Old 10-22-2012, 09:59 PM   #19
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Depends on the pump.
Fast pump, you can hit it a couple of times.
Slow pump, no.
Metro areas generally have slow pumps to reduce escaping vapors.
TheRipler is offline   Reply With Quote
Old 05-20-2013, 07:08 PM   #20
Scionshaun
Aloha!
Drives: Whiteout
Yup it's you disconnect the negative and reattach. Fixed!
Scionshaun is offline   Reply With Quote
Old 05-21-2013, 08:38 PM   #21
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
The reason the gauge does this is the tank is more like two separate tanks, one on either side of the driveshaft connected by a transfer tube, like a bloated n. Each side of the tank has it's own sending unit and fuel pump (primary & secondary). The ECU takes the resistance from each sending unit and uses a predetermined formula to calculate the actual fuel level. Since the filler only goes to one side of the tank, especially if the pump is a fast pump you can potentially have more gas in one side of the tank than the other, and then you'll get a funky reading. As the gas settles, from driving or over time it should correct itself. Filling with more gas just confuses it more.
Hope this helps.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 05-22-2013, 09:00 AM   #22
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Typical of most RWD cars (and most trucks) today. Tanks are mid-way under car (each side of driveshaft) to minimize the old 'Pinto' problem of the single rear-mounted tanks exploding when rear-ended.
My Mustang, MX-5 and now the FR-S often mis-read immediately after filling. After sitting a while, all is fine as everything comes back into equalibrium.
Nothing to worry about unless it never corrects itself.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 05-22-2013, 10:10 AM   #23
Mikem53
Drives: FR-S 6MT
Originally Posted by FR-S Hot Lava View Post
I did go to the dealer and they did not have an answer, they said that the electronic sensors act up sometimes.
I had this issue with my vette... Would get false reading or no reading on the gauge.. Was told to switch brands of gas.. Which I did... And the problem never reappeared.. Was told that some additives mess up the sensor reading.. Never had an issue after that even going back to the same brand..
Mikem53 is offline   Reply With Quote
Old 07-03-2013, 10:53 PM   #24
BRZnut
Drives: BRZ DGM Limited
I just had this tonight...wanted to top off for trip..gauge was between full and 1/4 down. Added 2 gallons and gauge did not move.
Old 07-03-2013, 11:02 PM   #25
chate
Pharmasaurus Magnificus
chate's Avatar
C5, yup mine also...scared the s*it out of me driving down the freeway and seeing gas drop to E and the *ding* sound warning me of low fuel...hope it doesnt happen as commonly to the FRS too :/
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85
2015 Nissan GTR
chate is offline   Reply With Quote
Old 07-04-2013, 12:49 PM   #26
FR-S Hot Lava
FR-S Hot Lava's Avatar
Drives: FR-S Hot Lava (AT)
I have found that if I top off the car and the gauge is reading just above the 3/4 mark it will not move, but if the gauge is reading after the 3/4 mark then the gauge will move to full.
FR-S Hot Lava is offline   Reply With Quote
Old 07-07-2013, 11:02 PM   #27
BRZnut
Just returned from the trip and gauge came down normally and at the following fill ups from nearly empty went up to full as it should
Old 10-29-2014, 11:33 AM   #28
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Thanks for the help folks. My gauge maxed out at 3/4 full for the last two fills and so i reset the ECU and now it is reading spot on
2superblus is offline   Reply With Quote
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:23 AM
How To Properly Carve a Canyon S2KtoFT86 Other Vehicles & General Automotive Discussions 64 05-21-2012 03:17 AM
... reading the reviews? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 6 04-26-2012 10:08 AM
