#15 | |
Drives: MY13 86GTS
Wondering if you made any progress with this? I'm running a Sprintex 210 supercharger, ID1050x, DW300c on E85 and am having exactly the same issue on Ecutek. After one day of sitting, car is a pig to start. Cheers.... |
#16 |
#17 | |
Drives: 2013 Subaru BRZ and 2012 Toyota 86
Hello all. Did anyone get to a solution here? we having the same issue. We have DW 900's as Port injectors and i have sent the Latency/dead time according to 3bar base pressure. I have been hunting around and cannot find a conclusive answer to what the base pressure is, logging the car with ecutek the Fuel pressure - PI (Bar) has zeros throughout the logs.... We having the same issue around nasty start and initial idle and as per Steve99 you can see the PI are at 100% for a period and then it flips over to DI. at WOT it is fantastic and when you get going it is also good but occasionally idle is iffy at best and cold start is terrible. i've removed the Close loop fueling Racerom addition to see what affect this will have if any. |
#18 | |
| Took my car in for rough idle... | Da Brz | Issues | Warranty | Recalls / TSB | 34 | 10-29-2016 01:57 AM |
| (Spark?) Knock on cold start idle | nickw14 | Software Tuning | 0 | 04-07-2015 01:41 PM |
| '14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) — General Topics | 20 | 05-22-2014 07:40 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
| Rough Idle & CEL *video | JiB | Issues | Warranty | Recalls / TSB | 5 | 10-04-2012 11:28 PM |
