#15 | |
Drives: 2017 toyota 86
also anecdotally when i had them custom tune my ace header it took 7 revisions to dial in, and it made a drastic night and day difference in not only overall power, top end pull, torque dip etc..., but also a huge improvement in driveability. I think it would have taken less revisions and i would have noticed much less improvement if the OTS tune was designed around a 4-2-1 design. Last edited by 86TOYO2k17; 05-14-2019 at 06:48 PM. |
#16 |
Good Job Subaru!
Drives: '18 440i GC, '24 CX-50 Meridian
Ace 350 vs JDL 4-2-1
Some in this thread have already made good points which I won't repeat. At the end of the day, the only way to truly compare the two headers on a level playing field would be same car, same dyno, same conditions.
From my own experience being in Canada (where the weaker Canadian dollar, shipping fees and taxes/duties are the enemy), the JDL 4-2-1 was much more cost effective for the gains I was after compared to getting an Ace A350 here. Compared to the ACE A350 (non-coated) and a Delicious Tuning remote ECUTek tune, it cost me over $1000 less to get the JDL 4-2-1 (w/ full cerakoting) and a custom dyno tune with OnPoint Dyno. ![]() Sasha said that it’s one of the highest HP NA BRZ’s he’s ever had. Car pulls strong right to redline and the torque dip is all but gone. These numbers are a 5th gear pull, with the stock intake, stock overpipe and stock front pipe still in place. For reference, this dyno is a bit of a heartbreaker... stock BRZ’s typically make anywhere from 140 to 155hp on this dyno. For more reference (and to contradict a bit on what I said above, but reference is reference), a 2014 FRS with a catless JDL UEL header made 166whp on the same dyno. Do I think that the Ace A350 could have provided even bigger gains? A little bit more most likely, but I don't know for sure at this point, at least without seeing the results back to back on the same dyno. Also, for the extra cost, would it have been worth it? I personally don't think so based on my experience. However, YMMV.
#17 | |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
#18 |
Drives: GTS 86
Ace header + OFT tune here. Recorded the highest HP on 98 and E85 petrol in Australia. Like someone mentioned here, OFT can do 90% of what the Ecutek tune can, it is all in finding the right source. Wayno and Steve to name couple have developed some really good tunes for different types of headers and intakes. it also come down to price as well.
#19 |
I made 198 from a full decat OEM header and 2.5" over pipe back, only other mods were intake tube and snorkle mod.
All my power came from Ecutek and the abilities and knowledge of Paul Fisher from Pulse Racing here in Sydney, Australia. There are no magic parts really needed to get up to around 200. Disclaimer: although my peak is quite good, and it has had gains all through the rev range a different header may give me more down low and keep or improve my gains at the higher RPM. Is the outlay worth it though? For me, when I'm up it the car never gets lower than 4.5k rpm so for me it isn't, and when I'm just plodding along in traffic, it doesn't matter how much torque I'm making at 3.5k rpm. The other benifit is the OEM heat sheilding which negates alot of long term issues. The 17+ 4-2-1 slightly UEL OEM header is actually quite efficient for what it is. If any Sydney based people want to hit WSID for a laugh one Wendsday night I'm all for it. IMO the 1/4 is the only place to test for power gains, dynos are brilliant tuning tools but inherently inaccurate for gauging "real" power through the rev range. Winner of the night (NA) gets free donuts, I'll buy.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#20 | |
But you are right at the end of the day a HP number is irrelevant. What matters is what times you put down from a roll or a set speed to speed. Like 40-80 or 60-100 or any two points where traction isn’t a factor. |
#21 |
Drives: JRSC BRZ SOLD
#22 | |
Drives: 2013 FR-S Argento
Sent from my SM-G965U using Tapatalk |
#23 | |
This would also explain why your 4-1 header ran very well and made a big difference with the OTS tune and my 4-2-1 ace header felt like it ran worse and lost power with the OTS tune. |
#24 | |
#25 |
Drives: Q5 + BRZ + M796
This thread is comparing the 4-2-1 el headers from each manufacturer, right, the ones that are actually a 4-2-1 header with a 1-1 overpipe, right? Doesn’t ace make a 4-2 header with a short or long 2-1 overpipe? Aren’t those headers better? Maybe I haven’t seen pictures and prices of each of these headers.
#26 | |
Good Job Subaru!
![]() JDL’s 4-2-1 is a full 4-2-1 on the header portion, with a 1-1 overpipe (I’m using the stock overpipe in my case) ![]() ACE A350 is a 4-2 on the header side with an included overpipe which brings it down from 2-1 at the front pipe location. Given the different shapes of the two headers, JDL was able to keep the secondaries as long as possible with the packaging restriction they imposed on themselves. IIRC it’s longer than the A150 at the very least; I’ll update with pictures and confirmation shortly. EDIT: ACE A150
#27 |
Drives: brz 2017 hksv2
the 2 fotos of JDL 4 2 1 seem different to each other?
#28 | |
