Old 07-04-2020, 01:14 AM   #15
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Got the wiring bulkheads installed today. Happy with how it turned out.
kask2_6.0 is offline   Reply With Quote
Old 07-05-2020, 10:24 AM   #16
Greenbean
Drives: 2017 series yellow BRZ
Originally Posted by kask2_6.0 View Post
I will be using Vorshlag mounts and headers. Would love to do a dry sump but thats just not in the budget at the moment. For now I will have the baffled pan with an accusump.
Actually the headers just showed up today! Overall fit and quality is pretty good. Clearance between the header and oil ports is pretty tight so I will need to get 90 degree ORB to hose end fittings. Using an ORB to AN adapter will not fit.
From what i hear the Sikky kit is the best thing to buy, and their header design is amazing by keeping the headers away from you plug wires and also fitting perfectly around the steering rack but I cant speak for it personally. Just from what I have heard. Build looks high quality I love it I will be starting mine soon.
Greenbean is offline   Reply With Quote
Old 07-23-2020, 01:09 PM   #17
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Both Vorshlag and Sikky swap components seem to be very high quality. There are pros and cons to both of them but I don’t think you can go wrong either way. I spent a lot of time going back and forth between the two but ultimately decided on Vorshlag for my build.
Old 07-23-2020, 01:20 PM   #18
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Was able to get enough header clearance using a xrp ultra low profile orb fitting (pn: 989110). Have almost 1/2” clearance now.
[IMG]https://uploads.tapatalk-cdn.com/20200723/d6e663a54256b568aac294c9ff5***9f.jpg[/IMG]
Also got these super trick stage 8 locking header bolts
Old 07-26-2020, 07:10 PM   #19
Greenbean
Ill be honest and say i have not heard one complaint from the sikky kit besides maybe when running the tr6060 and how you have to massage the tunnel and if you use their relocation shifter the amount of material that needs to cut off. If you dont mind sharing your cons im open ears
Old 11-26-2020, 11:44 PM   #20
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Finished the dash assembly today. I’m using the Aim pdm32 with 6” dash.
Also made a new mount for the remote battery terminals and upgraded to Motorsport grade 1/0 cable from cheaper grade 2 ga. Battery located in the trunk with msel master relay.
Previously had battery grounded in the trunk but now the grounds runs up to the terminal post. My car has always cranked a bit slow since the battery relocation and the ls3 would be even worse.
Old 12-01-2020, 01:42 AM   #21
J-Kite
J-Kite's Avatar
Drives: 2014 BRZ
Sub'd
J-Kite is offline   Reply With Quote
Old 12-01-2020, 02:04 PM   #22
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Really amazing work. Excited to see more.
DustinS is offline   Reply With Quote
Old 12-06-2020, 01:52 AM   #23
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Needed a new project... LS3 soon!
Got some arp bolts and a bunch of parts back from cerakote today. Really liking how everything came out. Wanted to go with a color a bit out of the ordinary. Kinda looks brownish in a couple of the pics but the color looks really good in person and especially so in direct sunlight.
Old 12-21-2020, 12:47 AM   #24
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
eBay subframe modified for Vorshlag mounts. Dropping it off for powder coat tomorrow.
PDM and ECU mounting.
Old 12-22-2020, 11:18 PM   #25
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Very slick setup. What is the box in front? It looks like an airbag by the circular shape and connectors.
Old 12-23-2020, 02:59 PM   #26
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
You’re correct. Motec mounts under/behind the passenger airbag. Not a ton of options under the dash there it’s pretty tight.
Old 12-27-2020, 11:16 AM   #27
all4spl
So did you get rid of the engine bay harness that goes through the firewall on both sides to make your own harness?
all4spl is offline   Reply With Quote
Old 01-12-2021, 01:21 AM   #28
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Not yet.. still driving it with the fa20 in it. My car basically has two sets of wiring in it right now.
What is needed for Aluma007 Engine, Exhaust, Transmission 9 11-25-2018 03:20 PM
Electric Power Steering Adjustment Project - Help Needed brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 12-07-2015 08:34 PM
Logged Track Time Datasets Needed for my Web Project! :) Zamyatin Scion FR-S / Toyota 86 GT86 General Forum 7 02-11-2015 02:59 PM
HELP NEEDED!!!! sklimo Issues | Warranty | Recalls / TSB 26 06-14-2013 12:48 PM
MOD's Needed. Help Please! GT-ROKIN Cosmetic Modification (Interior/Exterior/Lighting) 17 10-06-2012 02:18 AM
