#15 | |
Purist
Drives: 2013 FRS - Hot Lava
Thrust angle is a term used for alignments. Simply put, its the permanent steering angle on either the front or back axle caused by toe angle. If you have positive toe on one side and negative toe on the other, you are steering that axle in one direction. Instead of helping achieve a general understeer or oversteer behavior in either direction.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#16 |
Drives: 2018 BRZ 50th Anniversary
Hey, did you ever solve this problem? It has just started to happen to me. Tires are 1 year old. Mostly noticeable on the freeway for some reason (e.g., over 60 and in 6th gear). Diff fluid was replaced 1-2 years ago. Tires were just mounted and balanced. I'm really confused.
#17 |
Drives: 1993 Caterham HPC Evo
As stated back in 2020 if the rear end moves one direction under acceleration and the opposite under deceleration something is lose/broken in the rear.
Get it up on a hoist and have a mechanic go over the rear suspension, differential and axles.
Living life on the edge, less crowded, better view!
2018 tS Still in the family. |
#18 |
Drives: 2013 frs red
Maybe trailing arm bushings
| Tags |
| differential, torque steer |
| Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 02:20 PM |
| Rear Differential Bushing Bolt Torque Specs? | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 11-06-2017 11:36 PM |
| Anyone else have torque steer while turning right? | babydriver | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 05-24-2016 09:45 PM |
| I don't believe that unequal shaft lengths causes torque steer | pushrod | Other Vehicles & General Automotive Discussions | 12 | 01-31-2016 10:32 AM |
| Enkei 17x8 RPF1 Gold with Hankook Ventus R-S3, Torque Steer?! issue solved | enginrd | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 11-08-2014 02:00 PM |
