Old 04-20-2021, 02:35 PM   #15
Azzudien
Drives: 2017 Series Yellow BRZ
You sure you didn't do something wrong on the tranny when you did the TOB? Does the car actually go in neutral and roll when the clutch is pushed in?
Azzudien is offline   Reply With Quote
Old 04-21-2021, 10:42 AM   #16
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Originally Posted by LowKeySlow View Post
Correct, I plugged in the two connectors and bolted down the ground wire. I'm still having issues. this weekend I'm going to pull the harness that connects to the starter and I'm going to continuity test each individual pin on it to find out if there's a short in the wiring.
Could you not test the starter while it's installed by bypassing the starter signal circuit and using a remote starter button? That would help you immediately localize the problem.
sharpsicle is offline   Reply With Quote
Old 04-22-2021, 10:43 PM   #17
LowKeySlow
LowKeySlow's Avatar
Drives: 2013 FRS
thats what i thought, car still goes into neutral tho. also we checked the transmission when we spun the crankshaft with a wrench.
LowKeySlow is offline   Reply With Quote
Old 04-22-2021, 10:50 PM   #18
LowKeySlow
LowKeySlow's Avatar
Drives: 2013 FRS
thats a really good idea! i'll try this and its super cheap!
issue, starter
Stall/No Re-start with push button start couver Scion FR-S / Toyota 86 GT86 General Forum 11 06-26-2020 11:32 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 03:12 PM
Replacement key for push to start cpamieta Electronics | Audio | NAV | Infotainment 0 05-09-2017 05:11 PM
STI Start button replacement acetothermus BRZ First-Gen (2012+) — General Topics 9 03-12-2016 05:09 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
