Old 05-04-2021, 12:22 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
I was thinking that after he said to replace the tensioner
Right?
Old 05-04-2021, 08:44 PM   #16
Devmeup
Drives: 2016 Scion- FRS
RZNT4R might have a good point about a sloppy engine mount. After going to a different mechanic today and trying to figure out what the issue might be they said its 80% an engine/transmission mount issue. They said everything else was fine with the car. I’m paying a big amount so I hope this is truly the problem. I will update you guys after the parts come in and get installed. It should be about 2 weeks. Thank you again for all your help guys. I really hope this is the problem.
Devmeup is offline   Reply With Quote
Old 05-05-2021, 02:23 AM   #17
Ultramaroon
not playing cards
Were they actually able to reproduce the sound and isolate the source? Keep us posted. Good luck!
Old 05-05-2021, 05:50 AM   #18
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
80%?
Ultramaroon asked and I don't think it was clarified, but from the sound, I'd wager it can be reproduced with the car at a standstill... If I could have the car on a lift doing the noise, I'd be damn well more than 80% sure. I mean, you can't ask for an easier noise to find, you can probably actually put a finger on it.
Old 05-05-2021, 11:00 PM   #19
Devmeup
Originally Posted by RZNT4R View Post
80%?
Sorry I missed that question. To answer that question, yes the car was in idle it was not moving when I recorded that sound. I was just on drive and holding down on the brakes in one spot. Also, I think they said 80% because they don’t want to tell me they are 99% sure or something incase it doesn’t work. It’s literally the only problem they found so I really hope this is it. Thanks again for all your help guys.
Old 05-05-2021, 11:01 PM   #20
Devmeup
They put it on a lift and inspected it and noticed small sound changes that led to thinking it might be the mounts. I will for sure keep you posted. Thank you!
Old 05-18-2021, 09:21 PM   #21
Devmeup
After getting new transmission mounts the sound has went away and everything sounds normal. Thank you everyone, I truly appreciate your help! Happy this is finally fixed.
help needed, scion fr-s
Popping sound from front passenger side tire while braking. jinnis31 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-13-2020 11:16 PM
Sound from front driver side area, need advice spike021 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 05-21-2018 09:39 PM
Rattling sound from front right side of car. vramsaran Issues | Warranty | Recalls / TSB 14 05-07-2018 10:09 PM
LOUD TICK-TICK-TICK sound on right hand side PoRco Issues | Warranty | Recalls / TSB 16 07-28-2014 01:55 PM
Creacking sound from front corner? (Where side marker is) l0aded Issues | Warranty | Recalls / TSB 11 03-14-2013 04:52 AM
