#15 |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
General consensus is UEL more low mid torque, EL higher up top. So get the one that produces the sound you want. Personally UEL better for DD, EL for the track where you will spend more time in the higher rpms.
#16 | |
Drives: Crapcan
ELI5: Why do I need to delete the cats to get rid of the dip?
It’s myth dude. Look at the torque curves on the ace 350 and JDL 4-2-1. They far out preform any UEL. You just need a tuner that knows on to work with them. Go look at the dyno mike_zn6 just posted in his build thread. Sent from my iPhone using Tapatalk
#17 |
Señor Member
Looks like you have the answers here already. The cat is not the cause of the torque dip. The headers that eliminate the torque dip don't come with a cat generally, this will be for packaging reasons, cost reasons and general market demands. If you really wanted the cat in the header with no torque dip I am sure some one could make it for you. It would be expensive and you would want a good quality cat which will make it more expensive again. The most cost effective option would be the JDL catted UEL or FT86 Speedfactory catted UEL. I believe neither of those will fully eliminate the dip tho.
1974 TA22 Celica
2013 86 GT |
#18 |
Personally I think it has more to do with the collection and geometry of those headers, then whether it is UEL or EL. Plenty of dynos showing the general consensus for UEL and EL for WRX and STI. But I agree the tune is a huge factor.
#19 | |
Drives: Crapcan
At lower to mid RPMS we need that stronger scavenging pulse to help evacuate the cylinder of exhaust gasses and improve volumetric efficiency. This is why catless helps so much, you are alleviating excess back pressure caused by the cat and allowing improved scavenging since the pulse doesn't have to pass through a medium weakening it. EL is more efficient at scavenging then UEL, but really getting rid of the cat is 90% of the gains.
#20 |
Drives: 2016 Scion FRS
#21 |
TRACKBREAD
I think @ meant the diameter/length of the primaries and secondaries if applicable, and the collector angle.
#22 |
#23 | |
#24 | |
Drives: Crapcan
The primary runner lengths on the tomei EL are very short. Tomei EL ![]() Tomei UEL
#25 |
Drives: 17 Asphalt 86
Seems like it's worth pointing out there are two variations of EL headers to choose from. 4-1 and 4-2-1. More extreme being the Ace header which incorporates the overpipe onto the design with different configurations for different goals.(I heard through FT86MS that ace is discontinuing their header.
)4-2-1 require specific custom tuning but all the info buried in the forum suggest they make most power everywhere. Talking about dollar to performance ratio in my opinion a cheap UEL like gruppe-s and a good tune is hard to beat. 90% gains for considerably less money. Money no object I would be running a ace or JDL 4-2-1 right now .
#26 |
Drives: 2017 GT86 + 2005 C2VTS
I am new to the forum, and allready ordered my UEL header. decated, bigger front pipe, will be putting magnaflow 200cell cat in the first tube
Also, from my point of view (based on internet research and real life experience with inline 4 engines) ; 4-1 headers have more top end power then 4-2-1 headers in an inline engine, basically because of longer primary tubes, short tubed 4-1 is inferior to 4-2-1. 4-2-1 also produces more midrange torque then.... Stock cats are ceramic, and restrict alot. For emissions and flow, go 200cell SS cat For FA20, EL beats UEL in topend power, and max numbers. For street use, UEL is enough because untill 4500 produces almost the same, with better torque curve. I bet 4-1 EL with long primaries will make the most power, but be very expensive https://www.supersprint.com/ww-en/to...verter.aspx#!/ Also, it is not all about SS material, in header construction, aftermarket headers are larger piped, longer runners when possible, and bends are smoother, welds also. That's what provides the flow. And for somebody that commented , yes, big companies on cars cut costs when possible, and 50usd cast iron header is not the same as 800usd SS bent handmade header, and it does make a difference, and it provides significant cost on thousands of cars sold |
#27 | |
| Passing emissions in CO cats or no cats? | xZAMx | Rocky Mountains / Great Plains | 4 | 05-25-2021 01:16 AM |
| Cats | suzyj | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 01-31-2019 03:13 PM |
| Ecutek - ELI5 | Kerber23 | Software Tuning | 2 | 08-06-2017 03:33 PM |
| ELI5 | Icanfaptothis86 | Other Vehicles & General Automotive Discussions | 3 | 09-17-2015 07:30 PM |
| OEM cats only ? | 350matt | Engine, Exhaust, Transmission | 7 | 11-26-2013 08:30 PM |
