Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-23-2021, 03:02 AM   #15
FrickingReallySlow
Drives: 2015 FR-S
What I want to see is if the timing cover is the same. Cams are different. I didn't check the cam gears. I looked at a lot of internal parts but a lot of it is incomplete.
I've been waiting for the same thing. FA24/20 frankenbuild from a rod knocked engine or If only the timing cover being able to also fit the STI FA24 shortblock would be so sweet.. oh wait i'm in california.
Since the header gasket is the same as FA20... so lots of implications there. I'm surprised they didn't open up exhaust ports more
FrickingReallySlow is offline   Reply With Quote
Old 09-23-2021, 05:19 AM   #16
PulsarBeeerz
Drives: JRSC BRZ SOLD
Kinda disappointing the exhaust isn't opened up tbh. I think the larger IM will fit for those of us FI.
You won't be able to do a frankenbuild as the bore is alot larger on the FA24. The k20/k24 works because the K24 bottom end bore is only 1mm larger. Its gets its displacement from the stroke.
PulsarBeeerz is offline   Reply With Quote
Old 09-23-2021, 06:03 AM   #17
Hudzoyne
Drives: Turbo GT86 - Fensport Performance
Have a look at EJ20 heads on EJ25 blocks. Very common and a 92mm Vs 100mm bore sizes IIRC. As long as you cut the chambers in the head it should work.
I plan to try building one as soon as I can get a short block sent over
Hudzoyne is offline   Reply With Quote
Old 09-23-2021, 09:59 AM   #18
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by trippinbillies40 View Post
RLCA's all show same parts as before.
Unless you're seeing something I'm not, this is not true.
13-20 is: 20250FG042
2022 is: 20250AL011
If those parts are cross compatable, I don't know. They very well may.
dragoontwo is offline   Reply With Quote
Old 09-23-2021, 10:05 AM   #19
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
2022 is: 20250AL011
You're correct. Different part numbers but the '22 part lists as cross compatible.
https://parts.subaru.com/p/Subaru_20...0250AL011.html
Just going off of the "What this fits" tab.
trippinbillies40 is offline   Reply With Quote
Old 09-23-2021, 10:11 AM   #20
dragoontwo
dragoontwo's Avatar
I did hit that tab on both parts, and they do not list all BRZs. Its one or the other in that tab.
Old 09-23-2021, 10:12 AM   #21
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Don't see that the tab shows the 13-20 BRZ in there.
Dzmitry is offline   Reply With Quote
Old 09-23-2021, 10:14 AM   #22
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
"Does it fit" is not the same as "has the part changed". Keep this in mind
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 09-23-2021, 10:16 AM   #23
trippinbillies40
Drives: '22 WRB
Welp.... Either I'm smoking crack or they updated it overnight lol. I swear I saw that it was cross compatible yesterday.
Sorry, all!!!
Old 09-23-2021, 10:17 AM   #24
Dzmitry
Dzmitry's Avatar
True, but that doesn't really matter in this context. Subaru parts can change and still fit various models, but it would list which models and years those were if that were the case.
Old 09-23-2021, 10:20 AM   #25
dragoontwo
dragoontwo's Avatar
Sorry, all!!!
But they still might be cross compatible as I stated. They also are both shared with different year WRX, so if there are WRX arms that fit all those models(I'll have to do a little digging) they may very well work.
Old 09-23-2021, 10:25 AM   #26
trippinbillies40
Drives: '22 WRB
IIRC correctly, 13-20 BRZ shared a RLCA with the 08-14 WRX which is ::puts on glasses, double then triple checks:: not currently listed as cross compatible with the '22 BRZ.
This also correlates with a post from Motomiwa stating the rear hubs are out further just a bit from prior gen. Gen 1 suspension still fits though, personally verified that.
Old 09-23-2021, 10:33 AM   #27
dragoontwo
dragoontwo's Avatar
The Whiteline KTA216A is listed as fitting 2008-2021 WRX.
Source
Old 09-23-2021, 10:34 AM   #28
dragoontwo
dragoontwo's Avatar
I also plan to keep my SPC RLCA and will compare when I get the new car.
TRD Catalogue Salemate Canada Classifieds 14 12-26-2015 01:15 AM
Definitive JDM AERO Catalogue (updated frequently) BPAuto Exterior Parts - The Rest 414 12-02-2015 03:53 PM
Hyper Rev magazine - basically a massive parts catalogue. diss7 Scion FR-S / Toyota 86 GT86 General Forum 21 01-18-2014 01:26 PM
KT Auto Works - Grazio & Co Catalogue - Coming Soon m0nty Australia Classifieds 27 09-15-2012 09:14 PM
