Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-09-2023, 04:30 PM | #15 |
Drives: '22 BRZ
Kyle's car was an autocross car for years at 7800-8000 RPM rev limit depending on the event... Doesn't help the rockers, even being a 2016
I just picked up a baffled pan for my car, I'm not sure an accusump is in my future or not. I'll need to work on an oil pressure logging solution in the near term though. I don't think the oiling suffers *that* much from having more load. There's already a lot of load on the rods just from G-force.
The Following User Says Thank You to DocWalt For This Useful Post: | autoracer86 (08-09-2023) |
08-09-2023, 04:50 PM | #16 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | autoracer86 (08-09-2023) |
08-09-2023, 05:17 PM | #17 |
Drives: Toyota GT86
What would those supporting mods be ? :-)
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
08-09-2023, 05:52 PM | #18 |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | autoracer86 (08-09-2023), DocWalt (08-09-2023) |
08-09-2023, 06:38 PM | #19 | |
meow
A smidge loose and shit starts bouncing around. Sweet spot is +/- 0.0002 in :/
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (08-09-2023) |
08-09-2023, 10:20 PM | #20 |
Drives: 2014 Toyota 86 GTS
To add to the cooling stuff, I’ve read that the Toyota team participating in enduros in europe try to keep their oil temps below 115c. Wouldnt hurt to aim for that I reckon. Also I happen to have handy a parts list that @CSG_Mike posted a few years ago when a similar discussion took place, so I will just chuck it here for convenience to give you an idea of what to look at, keeping in mind this is an older post.
“ Powertrain: 4700 GReddy turbo kit 950 JDL intercooler upgrade 990 GReddy oil cooler 870 CSG ceramic on all new piping Thermal dispersant (coating for intercooler, oil cooler?) 200 DEI wrap on all new exhaust piping area 200 DEI turbo blanket on turbo 45 Cool tape on all line-of-sight plastic surfaces 180 reflective thermal wrap on all line-of-sight lines and wiring 200 CSG fan shroud 450 CSG SPAL fan setup w/ relay 330 Trackspec hood louvers 99 JR MAP sensor 745 DT ff kit w/ MK1+ upgrade 350 Injectors 190 Fuel pump 400 custom shrouding (material cost only)” |
The Following 2 Users Say Thank You to halfwaytobedlam For This Useful Post: | autoracer86 (08-10-2023), CSG Mike (08-11-2023) |
08-10-2023, 06:45 AM | #21 | |
Drives: Toyota GT86
08-10-2023, 10:21 AM | #22 |
Drives: '22 BRZ
Yeah, the OEM style cooler isn't really adequate. It's wayyyyy better than not having one, but yeah...
@M0nk3y has had great success keeping his car cool on track even with FI with a fairly basic cooling setup. Hood vents, JR dual cooler, ACE ducting.
The Following User Says Thank You to DocWalt For This Useful Post: | autoracer86 (08-10-2023) |
08-10-2023, 11:12 AM | #23 | |
Drives: Toyota GT86
The Following User Says Thank You to autoracer86 For This Useful Post: | DocWalt (08-10-2023) |
08-10-2023, 12:33 PM | #24 |
Drives: '22 BRZ
Even being in a garage I'm going to design some covers for my hood vent to direct the water away from sensitive electronics
08-10-2023, 12:53 PM | #25 |
Drives: Crapcan
I've had an open hood duct in the PNW for 5-6 years now. The only thing I noticed from it is the idler pulley failed early.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | DocWalt (08-10-2023) |
08-10-2023, 01:17 PM | #26 | |
Drives: '22 BRZ
Good to know!
08-18-2023, 09:59 AM | #27 | |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
I have AC removed, vented hood, high pressure cooling system, aux coolers, etc and my EOC gets to about 240, 245 if it's really hot out. Now you're adding 30% more power, an FI system and intercoolers in front of the radiator/EOC. I'd imagine you'll start needing coolers for the trans and diff at some point too. FI and road racing don't mix well. There's a reason that even Porsche doesn't do it. They not only "dont" do it, they take a FI car and take the FI off of it for the track variants. Corvette tried and failed miserably with the C7 Z06 and is kinda sorta fine with the ZR1 (with a lot more frontal cooling area). I'm sure there are some, but I can't think of any true track worthy cars that are FI from the factory. But it's definitely a problem money solves.
2014 BRZ: WRL Build (GP3) Gutted, caged, coilovers, AP enduro, etc-
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2022 CT5 Blackwing: Stock. |
08-18-2023, 10:45 AM | #28 | |
If you do it right it's really not that complicated. FWIW this is cooler oil temps than what I ran NA
Kyle H. - #89 STX
Similar Threads | ||||
Oil for track usage? | Sean 86 | Tracking / Autocross / HPDE / Drifting | 11 | 11-09-2020 06:58 AM |
Best Diff Fluid & ATF for Track Usage? | Tristor | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-23-2019 04:52 PM |
Oil Weight Poll For Track Usage | brillo | Tracking / Autocross / HPDE / Drifting | 49 | 07-01-2015 06:34 PM |
Custom tunes safe for track usage? | Sleepless | Tracking / Autocross / HPDE / Drifting | 46 | 10-29-2014 09:52 PM |
Best kit for occasional track usage | yomny | Forced Induction | 14 | 02-06-2014 09:10 AM |
