Old 05-23-2012, 02:21 AM   #15
ttknf
Drives: 350z Nismo, CBR1000RR
Quite a few modern cars come with forged pistons; the GT-R being one of them. It wouldn't be a terrible surprise if the FA20 came with forged pistons, but only if the overall price of the car was higher.
ttknf is offline   Reply With Quote
Old 05-23-2012, 02:55 AM   #16
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
The Evo X has forged Mahle pistons. Yum. But I'm pretty sure these are just cast. However, I know I saw somewhere that the rods and crank are forged steel...
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 05-23-2012, 08:42 AM   #17
powertrip
Drives: Mercedes C320, S2000
OEM cars with forged pistons are generally forced induction from the factory. It's more common to see forged con rods & crank on an N/A car than forged pistons.
powertrip is offline   Reply With Quote
Old 05-23-2012, 09:45 AM   #18
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
I just wish Toyota surprises us with this engine, and we discover that it holds boooost!
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
Old 05-23-2012, 10:23 AM   #19
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Senior Scion rep here when asked said that a S/C would not be a simple bolt-on, because of the high compression ratio the pistons would have to be changed. Sounds like mucho $. He did say Toyota has plans though.
Sport-Tech is offline   Reply With Quote
Old 05-23-2012, 10:36 AM   #20
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Not enirtly true, most trd superchargers run low boost, 5-6 psi is expected, 250 hp...
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 05-23-2012, 11:59 AM   #21
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by Exage View Post
Perhaps the question would be better suited on the con-rods and crank...
Tip: Better to beef up the bottom then waste time at the top. More likely to throw a con-rod out the side of the block then melt a hole through the piston (unless you do something really stupid with the fuel).
But if you have weak ringlands on the piston it's another story.
djdnz is offline   Reply With Quote
Old 05-23-2012, 12:19 PM   #22
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Interesting. If it's a dealer install, I assume it will not void our warranty?
Of course depending on where the added 50 or lbs go adding a S/C may require re-optimization of springs/shocks, so that would get expensive too.
Old 05-24-2012, 08:56 AM   #23
Pplater
Drives: Driving mums Q7 3L TDI
http://www.ft86club.com/forums/showthread.php?t=6840
im pretty sure they are cast, they look cast in this picture
Pplater is offline   Reply With Quote
Old 05-24-2012, 12:01 PM   #24
catharsis
Drives: honda civic si 08
most likely cast, the car is the too cheap for it to have forged.
catharsis is offline   Reply With Quote
Old 05-24-2012, 02:23 PM   #25
Matador
hashiryu
Drives: Mk4 Supra
Probably cast, however most if not all modern Toyota 4's (yes yes, I know, Subaru, blah blah blah) come with forged cranks. I don't expect this to be any different.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 05-24-2012, 02:57 PM   #26
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
Nothing voids a warranty, however, the dealer may elect not to perform a warranty repair based on perceived abuse and/or modification.
Whether a supercharger carries a warranty depends on a few factors: if it only requires a re-flash of the stock ECU, doesn't use an external intercooler, doesn't require modification/replacement of stock exhaust manifold, and passes California Air Resources Board (CARB) certification, it will be included in the powertrain warranty. If it doesn't, it'll be a "race-only" part for off-highway use only and not carry a warranty no matter where it is installed.
However, if they say it won't be a simple bolt-on, they might as well release it as a separate model.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 05-24-2012, 03:08 PM   #27
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
C'mon. This kinda talk is getting silly.
chulooz is offline   Reply With Quote
Old 05-24-2012, 03:57 PM   #28
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
Just Aluminum Alloy cast.
Side skirts have a resin coating.
The Top ring groove has a alumite coating.
The crankshaft is forged steel
Ishii
Ishii Motors is offline   Reply With Quote
Early proposal: FA20 with a FB25 shortblock, .5l more displacement anyone? Kostamojen Engine, Exhaust, Transmission 90 03-20-2022 07:05 PM
Turbocharged FA20 targeted for 270hp. Confirmed for next gen WRX Hachiroku Engine, Exhaust, Transmission 50 12-10-2011 02:23 PM
FA20 for sale coyote AUSTRALIA 1 12-01-2011 01:53 AM
Any Disney Cast Members here? MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 9 11-18-2011 02:48 AM
BBQ @ Forged Performance Sunday July 31st EVAN&MONICA Northwest 10 08-23-2011 04:04 PM
