| View Poll Results: Have you had an issue with your Direct Injection System? | |||
| I have had a DI issue and was fixed under warranty (Subaru) |
10 | 12.35% |
| I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) |
2 | 2.47% |
| I have had a DI issue and was fixed under warranty (Toyota) |
31 | 38.27% |
| I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) |
3 | 3.70% |
| I have had a DI issue and denied warranty by (Subaru) |
7 | 8.64% |
| I have had a DI issue and denied warranty by (Toyota) |
14 | 17.28% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) |
8 | 9.88% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) |
6 | 7.41% |
| Voters: 81. You may not vote on this poll | |||
#15 |
Now with Boost!
Drives: 2013 SWP BRZ Ltd.
OK, I haven't checked my injectors yet but I am getting some backfiring/popping between aggressive shifts occasionally on my BRZ w/ AVO Stage 1 turbo kit. During my major cam issues and an idle stall/shudder event, I did throw a P0300 misfire, but it hasn't done it again since the cam repairs and I have not thrown a single code since then.
Is the slight popping/backfiring between shifts normal with a high-flow cat and engine back exhaust, or should I start worrying about replacing injectors etc? |
#16 |
Is there any correlation to VIN#s or manufacture dates?
Some backfiring popping from the exhaust on throttle/RPM transition is not a sign of preignition/knock/ping/detonation, especially with aftermarket exhaust, FI, tuning, etc. |
#17 | |
Drives: A lot of supercars.
#18 | |
I Love custom Turbo kits
Drives: Limited BRZ
#19 |
Now with Boost!
My VIN is **2379 (BRZ).
@wheelhaus, thanks for the response all the injector failure threads are making me paranoid. @Carwhisperer, we may be experiencing different things but I don't know. The main analogy I can make is to my old 2.5 RS which had headerback exhaust with Borla UEL's, under shifting there is a slight burble or rasp, or occasionally a single muffled pop as you describe between shifts (mostly when driving aggressively). But no CEL's or DTC's when it occurs and my Ecutek logs do not show me running lean...if anything Paul says I'm running rich. @Sportsguy83 David I have a full recirc BOV, but you are correct that Paul has advised I am running a bit rich. I suspected this was unburned fuel but again, am just paranoid and better safe than sorry! After the misfires I'm still a bit concerned but I'll just monitor and keep an eye on it. |
#20 | |
Drives: Limited BRZ
#21 |
Drives: SWP BRZ
poll!!!! yeah like others said we need "don't have issue yet!" on choices
#22 |
Drives: '13 Black Subaru BRZ Limited
I've heard the popping from directly under neath the car (almost right below my butt it feels like) but I have not thrown any codes yet and it's only happened twice. I'm waiting for the injector tune fix from FA20club to see if it happens after I flash the update.
Running slighlty modded. FA20club CAI and Tune. VIN # *******5563 |
#23 |
Drives: SWP BRZ
if Toyota/Subaru doesn't come out with solution for long time, other alternative is getting ECU flashe through Tuners
#24 |
I'm hoping just an ECU flash can be the remedy. From what I've read it looks like it is a heat issue with the injector seals so I'm not sure if new calibrations can fix this. Anyone who knows that they are talking about want to chime in?
#25 |
Grip>Slip
The heat issue is caused by the ECU mapping resulting in detonation. Fix the ECU, fix the problem (in theory.)
#26 |
Beautiful! I'm tempted to stop driving and just hitch rides to work until I get the update in my inbox. Especially since it just keeps getting hotter around here.
#27 |
Hey take off the bottom "I do not have an issue" pole. It's going to throw everything else off once there is a good amount of feedback. Unless if you know how to do conversions well.
#28 | |
Track Junkie
Drives: Faster than the Stig!
Just sent a pm to a moderator.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
| Tags |
| direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 07:54 AM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 09:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 01:25 PM |
