#15 |
Drives: AE86, 2x GT86, TE27
If I sent you my flash, would you be able to make this modification, and then send it back to me to reflash?
Would certainly appreciate it if you were able to! Have another event on Saturday that I'd much rather do with this problem sorted. Thanks in advance. |
#16 |
Drives: '24 GR86
In all reality, if you're pegging rev limiter super hard you can either modulate throttle more or upshift.
Feathering throttle more will keep you off the rev limiter but there's more of a chance for you to grip up again. Upshifting is the best idea. If you're smacking the hell out of the limiter in 2nd, go up to 3rd. You won't be at super high rpms but chances are you'll still be able to spin the tires easy (kick the clutch once or twice to help if you have to) and just keep the throttle pinned. The higher wheel speed from being in 3rd will help with angle and generate more tire smoke as well
#17 | |
It's more a case of wanting to fix it so I don't have to worry about it. |
#18 |
@diss7 - you should be able to talk to your tuner to set the field that was shown above.
I'm not that smart, but I think you would want set it to the same value and then you can use pedal modulation with predictability. If you're drifting, you're bouncing off the rev limiter all the time, you want predictability all the way up and not have a dead spot up top in which its waiting for RPMs to fall lower. |
#19 |
Drives: 2013 FRS
Only your Ecutek dealer can modify your ecu tune. So I can't be any help if you want to retain the ecutek flash. My suggestion is to make the jump to OpenFlash tablet so that these changes can be made without restriction at no cost. And more importantly, no license to fiddle with.
#20 | |
#21 |
Just paid $1300 for an ecutek licence. Makes you wonder what the point is when you can just go openflash :/
#22 | ||
Drives: 2013 FRS
But I recommend flashing back to stock with your Ecutek cable, plugging in the OpenFlash Tablet and running our off the shelf maps as the rest of our customers. As long as you aren't turbo/supercharged (not supported yet), I think you'll be happier than you are right now. Quote:
But then again, the OpenFlash Tablet was just released last week so this option may not have existed when you made your purchase.Shiv |
#23 | |
I'll contact the guys in Australia and see if they can make the adjustment for me, and report back. |
#24 |
So I managed to get the guys in Australia to make these changes.
But the problem is not really fixed. When it hits rev limit now, the revs drop slightly, but the throttle is still pulled right back. It basically has enough throttle left to keep the revs just below rev limiter, then after a good couple of seconds, I get full throttle back and it surges forward until it hits cut again. The whole time my foot is flat down on the throttle. If I hit rev limit during a drift, it dies and I lose my slide. What it feels like is happening, is there is another parameter that times out the throttle after rev cut, and only allows you 5 or 10%. When grip racing, this is enough to keep the revs high, albeit at a cruise. However, when drifting/skidding, its not enough to keep anything going, so the rear grips up. Any thoughts? |
#25 |
Bump. Any tips / ideas?
The silence from my tuner, tells me they are stumped. |
#26 |
Drives: Whiteout FRS
I know what your talking about cuz sometimes comeing off base I am an ass and forget how short 1st is and it just falls on its face... But when at 1/4 and even when i went to a drift event I had traction control off and never had it happen...(yes i should shift before it hits it at the 1/4 but it only happened a couple times)
#27 | |
| Ways you COULD get of out a ticket | Muskokan | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 09-10-2013 07:42 AM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 11:15 PM |
| Stock rev limiter. Mine seems to be different. | Thorpedo | Engine, Exhaust, Transmission | 10 | 06-13-2013 10:21 PM |
| Stock rev limiter. Mine seems to be different. | Thorpedo | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 05-30-2013 04:04 PM |
| anyone running the HPs with a pressure less than 35 to soften the ride? | BRZnut | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 11-26-2012 01:36 PM |
