#15 | |||
Apostle
Drives: Fast Microwave
It's hard to track revisions. Toyota has some vague explanation of an Entune/ Entune Plus/ Entune Premius / JBL Entune Premium. http://www.toyota.com/entune/ Quote:
I kept my entune extension box. I haven't use an Aha box so I don't personally know what the difference is. I think most of the functionality is identical, like the entune apps, but you may not need to run a phone app anymore for it to connect. Can anyone else chime in? Quote:
I would watch to see if there is an updated unit put into the Prius C. It should be due for a mid model update in a year or two. I don't know if they will keep the dash the same, or switch over to the integrated design like the Rav4/Camry/Corolla. Scion would probably get it a year later. I think this is a major failure on Toyota's part; how can Scion be your youth division if it keeps getting last gen HMI/Telematics ? Then again, Toyota products have been gutting Scion for a while now; cars like the Yaris (xA, xD, iQ) and Corolla (sort of tC) have been directly competing with Scion's lineup for a while now. |
#16 |
Drives: 2013 Hot Lava FRS
Subbed for later use!
#17 |
Drives: 2015 Scion FR-S
2015 Scion FR-S
Hi everyone...hopefully someone here can answer this question.
I just bought a 2015 Scion FR-S....it came with a Pioneer BeSpoke. It has Bluetooth...But I guess it's just the basic package because it doesn't have the navigation or backup camera. My question is this: what exactly do I need to do to add a backup camera and navigation on the unit that is already there? All I really want is a good sounding system with backup and navigation. Thanks. |
#18 | |
Apostle
You buy a camera, there's a bunch of options on the forum. I bought the beatsonic: http://www.ft86club.com/forums/showthread.php?t=41673 . You will need to buy extra wires, some crimps, and have some soldering stuff. It takes a while to run the cable all the way to the back but it's not too bad and will teach you stuff about the car. If you want nav, you need to buy a nav module (bespoke or entune), gps antenna, and brackets. There are some people already selling assembled kits, like this: http://www.ebay.com/itm/2014-Scion-b...ed1e41&vxp=mtr |
#19 |
Drives: scion xb
scion 14 head head
I need some help i have a 14 scion Xb head unit and toyota extension box PT296-47120 EA. I can't get it to work, i don't know if it is compatible or if i need to reset the radio, Thanks
#20 |
Drives: 2013 Fr-s Firestorm 2013 Fr-s 10ser
I did same Setup from audio sound wise. i believe the amp is not turning on that is why its does have a louder volume.
#21 |
Confirmed that this radio has nothing coming out of pin 9 on 10 pin harness. which is brown on main harness. just spliced it together with acc wire on top of it and all is good. small red wire
#22 |
Radio wiring harness guru
Drives: 1996 SVX L AWD
Because the OP had to slightly modify the plug on the 'for Toyota' GPS antenna he found on eBay, I'm guessing that this HU actually has the same kind of socket as on all of the BRZ Fujitsu Ten nav HUs. I can't say for certain, because I didn't find a good picture of the back of this HU (hint -- could somebody post one?).
BRZ (and other recent Subarus) use a socket that Fujitsu Ten has been using on many of their Eclipse HUs (both aftermarket and OEM). There are eBay vendors selling GPS antennas with the proper plug. Here's one with good close-up pictures of the plug (I have no relation to, nor do I know anything else about that vendor). You could also go with an OEM GPS antenna from Subaru -- ones intended for BRZ or most other 2008-2014 models (Impreza, WRX, STi, Forester, Crosstrek, Legacy, Outback). All of those have the same Eclipse-style plug. Subaru did change to a different connector on the latest models (e.g, 2015 Impreza, Crosstrek, Legacy, Outback).
#23 |
Professional Smartass
Drives: White Out FRS
#24 |
Drives: Thunderbolt Grease Slapper
If anyone wants to go with the Scion HeadUnit, pm me. I have one available that came from an FRS. I'm currently playing with the Scion AHA Nav module and comparing it with my Entune 5.2 unit. I should be deciding shortly which I will keep.
#25 | |
Drives: Scion
I've been digging into the code (I have many years experience as a software developer) but no luck so far. Simply firing up the 'ol hex editor to change the version from number is ineffective, as I believe there is a checksum validation on the image file taking place; any modification, no matter how slight, results in an immediate "authentication error" when trying the update. I'll keep hammering away at it - I don't see any reason why it wouldn't be possible. |
#26 |
Drives: Scion
Let me update my efforts with a bit of information:
1. Virtually all Harmon devices have identical hardware. In theory, *any* module can be flashed to any other module (Bespoke, NAV only, Entune with or without other apps, etc). 2. A process known as "authenticationService" is kicked off to verify the installation; if this process does not somehow agree that the software you are trying to update is unmodified (you can change minor things, but not the version, which is the big one), the authentication process returns an error and blocks the update. With that being said, I have no visibility into this authentication process, and it's probably crossing some legal lines to start modifying it (if I can even get that far), so I'm halting efforts. Maybe someone with a bit more familiarity with the code will eventually step in, but since this is a low volume/specialty item, I don't see that happening
#27 |
Apostle
Interesting. Thanks for the update.
Has anyone seen the new 2016 touchscreen unit? I'm curious about how that turned out, may just be a higher resolution screen. |
#28 | |
Apostle
| FS: 2013/2014 Toyota Display Audio | defylogik | Audio/Visual, Electronics, Infotainment, NAV | 28 | 09-11-2013 05:32 PM |
| FS: Scion Display Audio HU ($350 shipped) | SpeedLab | Audio/Visual, Electronics, Infotainment, NAV | 0 | 09-06-2013 01:13 PM |
| Scion Display Audio: New Base Unit | DieselxIndustry | Electronics | Audio | NAV | Infotainment | 21 | 08-14-2013 04:21 PM |
| 2014 Display Audio | SleePi | Electronics | Audio | NAV | Infotainment | 1 | 08-13-2013 11:21 AM |
| WA Next meet Sun 30th June - Sprintex Test Drive AND A One Audio display plus special | invisage | Australian Meets & Events | 2 | 07-22-2013 04:20 AM |
