#15 | ||
Drives: 2013 Asphalt FR-S
~Namaste~ Last edited by mad_sb; 02-21-2014 at 09:41 AM. |
#16 |
King of Kiwi Palace
Drives: Faster than you
Im not familiar with the robi setup. Some oil coolers have a thermostat built into the oil plate sandwich. If you're not seeing above 170 I would check the thermostat there.
Well I just took another look at your pictures. I don't think your oil cooler sandwich block has a thermostat in it, so it's basically sending oil 100% of the time through your oil cooler. I would look into buying a different adapter block. The FBM one I have now includes a thermostat. I don't know if FBM sells just the thermostat sandwich block. @FullBlown
#17 |
Drives: 2015 WRX
You guys missed one important fact in the very first post. He's running 5w40 instead of 0w20. That alone could account for the lowered oil temperature.
#18 |
Site Moderator
Drives: Stuff
Thicker oil will increase oil temps generally. They absorb heat more slowly from the engine.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#19 |
Fiebru
Drives: Scion FR-S and Integra Type R
I also have the Robispec radiator, I DD my car (which is turbo) and I usually see between 175-180 Oil temps and 190-195 water temps.
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
#20 |
Trust me, I'm the Doctor
Nice! Now if only the Robispec wasn't a full grand to buy!
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#21 |
Site Moderator
Drives: Stuff
That's not really bad when you look at the price of a quality oil cooler setup and the price of a quality radiator. I haven't seen the Robispec setup in person so I can't comment on how good of quality it is but I haven't seen anything bad (haven't searched either).
-Dave
#22 |
True. I agree it's probably worth the cost, but man that's expensive.
I guess I'll just have to consider it if I end up seeing an issue with heat levels. I probably won't until I go FI, and if I stick with going SC, it may not be as big of an issue as I think it might. I'll just have to keep an eye on coolant temps.
#23 |
Fiebru
Agree with Dave-ROR, the price will be similar if you get a quality oil cooler and radiator. As for the quality of the Robispec setup it is good but fitment is tight.
Current Cars:
#24 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I'm surprised by the low oil temps discussed above. In what general range should the oil be operating at (assuming the same viscosity as came stock in our cars)?
I started to log my engine oil temps since I'm planning on installing a KW S/C within the next week to get a baseline of what temps I get stock in different scenarios: 1.) freeway cruising, 2.) city driving/work commute, 3.) spirited canyon driving, etc... I was a tad surprised to see the oil get to 220F in some of my logs yesterday - just cruising ~70-75mph on the freeway in L.A. with 70F ambient temps. I wonder how hot it will get with the S/C installed without a oil cooler in city driving and driving it hard. Log/Graph below captured by the Torque App. |
#25 |
Drives: 2013 FRS / 2013 427 Vert
I haven't checked in here for a while so let me update and clear up some misconceptions. For clarification all the readings are taken from a scanguage.
I switched to a 5w 40 before the install after seeing ultra high oil temps at the track in May. Daily driving oil temps went from ~208 to ~216 probably due to the increased friction with the heavier weight oil. Three track weekends later, I have not seen the oil temp exceed 220 during 20 - 30 min sessions at 5 to 7.5K sustained. Daily driving oil temps have continued to run in the 170's. The oil does heat up fairly quickly but peaks at that temp. Hard driving may see 200 tops. Gas mileage is down a couple mpg's consistently I believe due to the heavier oil running at a lower temperature. I am planning to switch to 5W 30 now that my inventory has been depleted. There is no issue with the thermostat. The coolant temp stays rock solid at 190 and peaks at 200 during track duty. This radiator has massive cooling ability compared to stock. Again, I am over the top satisfied with this product and how well it keeps maximum temperatures down. I am still concerned about the daily oil temps running in the 170's although I don't have a scientific basis for the concern. It may be that a hardwired temp guage would read higher temps as the ECU info may not be completely accurate.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#26 | |
170 F oil for normal driving does seem a little bit low though. Have you thought about blocking off some airflow?
2022 BRZ Build 2013 FR-S Build |
#27 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
I had a Scangauge before I installed a set of gauges. I am taking my oil temp from a spacer located at the oil filter. I left the Scangauge plugged in for a day or two to see what kind of variance there was. I didn't see more than one or two degrees difference from eachother. I'm not sure what size of variance you'd see by taking temps from the galley or pan.
#28 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Drive it harder. Made for track. Works great as intended IMHO.
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
| HKS Oil Cooler Kit - Keep those oil temps down. - Photos | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 23 | 08-10-2015 04:08 PM |
| Help! Oil Cooler Install | brillo | Tracking / Autocross / HPDE / Drifting | 13 | 07-17-2013 05:55 PM |
| Perrin Oil cooler install review | LeeMaster | Engine, Exhaust, Transmission | 3 | 03-14-2013 11:41 PM |
| Any Portlanders bored tonight? Help install oil cooler? | stockysnail | Northwest | 2 | 03-14-2013 01:15 AM |
