#15 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
lol |
#16 |
#17 |
Fanboy
Drives: 2013 ultramarine frs
potty mouth.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#18 |
Drives: GT86
Thank you very much!
#19 |
Drives: car
This is a good topic. While there isn't really a totally standard way to do this testing, the most common way is to run steady-state rpm and torque/load points with a loading dyno. An engine dyno is easier but that's not an option here.
As airflow increases, the localized pressure will drop. You'll see this on turbo cars especially--it's important for calculating pressure ratio on a compressor map. When you get a heavily boosted engine the restrictions get crazy and that's when rubber pipes on turbo inlets start to collapse and such. You can use different instruments and different measurements, like using a pitot tube instead of a manometer, or doing static pressure only vs taking into account dynamic pressure. What you'll end up with though is a chart like this: So x axis might in this case be 25 grams/sec increment. Y axis would be in 1 kPa increments for something like this. Each point is a steady state test from holding the dyno at specific torque points to capture different airflow. Then through the magic of Excel you put a curve fit in there. So at 100 grams/sec you could have atmospheric pressure be 98 kPa, measured pressure be 96.5, and your pressure drop would be 1.5 kPa. There's always an exponential relationship between mass airflow and pressure drop--when you change the intake pipe you change the shape of that line through the points. Then you can start comparing across different intake pipes or even across different engines if the measuring process is similar. Once you collect enough data trends you can place your intake within an upper and lower boundary line to see how good the design is. |
#20 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#21 |
Drives: waiting on a 2021...
Since it seems that the snorkel is an integral piece of the whole induction system(and not a restriction), it makes me wonder how these aftermarket(HKS, Zeek, etc.) intake ducts affect pressure, flow, and AFR's on these cars?
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
#22 |
Drives: FR-S Whiteout
Love the way Grimspeed does things. Science, fuk yea!
#24 |
A number of laws about the behavior and movement of gases come to mind... very interesting.
Thanks guys! |
#25 |
Coffee Snob
Drives: '14 SWP BRZ Limited
@GrimmSpeed - Thanks for your hard work and detailed explanation. This is the kind of stuff that will make me want to support you guys by buying your products, even if there are cheaper alternatives out there. Please continue to keep the community informed
#26 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#27 |
Thank you very much for the kind words everyone, it really means a lot to us as a company!
Chase Engineering |
#28 |
Drives: 2013 FRS
Awesome testing guys! Your results make sense. At speed, there will always be a positive pressure zone in the bumper opening of the car as the air rams against the radiator. Makes sense that the intake would be configured to pick up from there.
| Stock FRS air intake system | AG3NT_5CARFAC3 | Engine, Exhaust, Bolt-Ons | 0 | 02-26-2013 06:14 PM |
| WTS: Airaid Intake System, Stock Exhaust, Stock Radiator Hoses | Sony | Engine, Exhaust, Bolt-Ons | 0 | 11-21-2012 12:10 AM |
| INJEN and aFe Intake System, In stock and ready to ship!! | 10k Redline | Engine, Exhaust, Bolt-Ons | 5 | 10-03-2012 05:05 PM |
| GrimmSpeed BRZ Measuring Session - Anyone need any random measurements? | GrimmSpeed | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 04-19-2012 07:27 AM |
