#15 |
Drives: 2013 Subaru BRZ
Do you use lotion on your hands, or have you used leather cleaner on the steering wheel in the past? In my experience the cheap bonded leather they use in most cars doesn't like being exposed to certain chemicals.
#16 |
Drives: 2014 BRZ SWP LTD
In for pics
#17 | |
Pull my finger...
Drives: Silver Scion Slushbox
In my case, I was working in the shop of a printed circuit board manufacturer for a few months to cover a personnel shortage, and the one constant thing I was in contact with daily was copper dust. I had a wheel replaced under warranty as it was only 5 months old. It finally became apparent when I saw the steering wheels of some of the other workers that performed the same operations as I did at the facility with the same issue. |
#18 | |
what was the fix for the driver side window seal? mine window pinches the dang seal every time |
#19 | |||
Drives: Firestorm FRS
. I will be a little MORE OCD with the new one I guess haha. But I already tend to keep my car excessively clean, and usually try to avoid eating in the car so I don't get grease or stickies on the wheel and shift knob.Sorry that I have not posted picks yet. I went straight from work to grad school, and then was doing homework the rest of the night so it slipped my mind.
#20 |
Drives: 2013 FRS- Hot Lava
Not under warranty, as in the dealer is good-willing the replacement? Or as in you're paying for it out of pocket?
#21 |
Drives: BRZ Limited Manual CBS
My steering wheel started bubbling and peeling as well, but in the 12 o'clock position. I asked about a replacement and was given the wear and tear line. Even with turning, my hands barely ever hit that spot so I do not believe it to be my fault.
#23 |
Drives: 17 Alfa Romeo 4C
Yeah, makes sense ..... wear and tear items. Tires, brake pads, windshield wipers, batteries .... and add to that list: steering wheel. What a croc. Toyota must be pretty hard up to nickel and dime everyone. Congrats that you got it replaced .... for free ... as it should be.
#24 |
Just drive it
Drives: 13' FR-S
I just noticed that outer bottom of the steering is starting to peel a bit. I barely put my hands underneath but recently noticed while turning the wheel.
#25 |
Drives: Toyota 86 Silver
Mine also started to fade a bit at somewhere around 08:00, also because my jeans keep rubbing it when I go in/out from the car.
A bit of first world problem since I don't want to change the seating/steering position. |
#26 |
Drives: 2013 FR-S AT Argento
That does not seem healthy my friend. Was the personnel shortage due to the mysterious deaths of employees?
#27 | |
Pull my finger...
After drilling the copper clad laminates they would have to be deburred. Didn't always wear gloves. Really, exposure was nominal. |
#28 |
Drives: JRSC'd Asphalt FR-S
Sucks to hear about the steering wheel, good thing it is getting fixed.
Chirping isn't an issue, so no matter how many times you fix it, it'll come back since it is normal. |
| WTB: Stock steering wheel (wheel not airbag) | mobybrz | Interior Parts (Incl. Lighting) | 2 | 09-11-2014 03:23 PM |
| scion frs steering wheel air bag and steering wheel | Jhon19lopez | Interior Parts (Incl. Lighting) | 7 | 01-04-2014 07:04 PM |
| Swapping steering wheels with a new tC steering wheel. | jonathan9573 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-21-2013 12:45 AM |
| Different Steering Wheel?- NOT? | BRZfan | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-07-2013 10:01 PM |
| That steering wheel | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 12-04-2011 01:16 AM |
