#15 |
Drives: 2013 Whiteout FR-S
Optimistically minimal lag out of twins compared to a single, but the kinks can always be worked out.
~@SalMPhotography~ -Instagram -Facebook -Flickr.com/SalMPhotography ![]() |
#16 |
Subaru used to have a twin turbo setup in their JDM SUBARU EJ20 BOXER LEGACY B4
http://www.jdmracingmotors.com/engin..._EJ208_TY754VB
#17 |
Stig's dark passenger
The reason why its more difficult on a boxer engine is the engine pulses.
You would have to run the 2 fronts together and the 2 rears. This makes it a very complicated exhaust setup. |
#18 |
Junior
Drives: a car
Cant tell if serious or...
#19 |
Drives: A Potential Traffic Ticket
LOL
#20 |
Bro when it comes to laying down rubber I don't kid.... Live my life one fourth mile at a time
#21 |
The REAL way to do it would be a sequential...
#22 |
in orbe terrum non visi
Drives: violent
You couldn't put big enough tires on this car to ever need a sequential.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#23 | |||
Drives: 2015 Series.Blue
You're confusing compound with sequential. Also, both turbos on the Supra are the same size. Quote:
Possibly, but with modern turbo technology, it's pointless (better impeller and housing designs + ball bearing turboes = no lag) Quote:
You can fit tires and wheels as big as the stock setup on the MKIV Supra Turbo... So yeah, not an issue. |
#24 |
Junior
Drives: a car
As stated before, the high compression motor allows for larger turbos to spool rather quickly. The need for a sequential is when a larger turbo doesnt spool until the end of an rpm band, which is then aided by a smaller turbo to spool faster. Which is not needed in this case.
If someone were to build an 8:1 or 7:1 motor the a small TD05 turbo and a GTX35 or something would be a nice combo with high hp applications. That market would bo so limited to a very select number of people looking to spend 10k at a minimum on just a TT kit wouldnt be worth producing the cost IMO.
#25 |
Drives: violent
And I'm lighter than a TT supra and make more tq with only one turbo. So why again?
#26 |
Drives: violent
Crawford made 475tq with one twin scroll turbo and their driver said it was uncontrollable on the track. They ended up spending most of their time trying to tone it down.
#27 | |
Drives: white out project fr-s
Thanks for the correction on sequential vs compound, my mistake but also to clarify, both turbos on a stock supra are different sizes, well, maybe depending on generation....I'm referring to the mk4 52mm/44mm (inducer/exducer) 58mm/39mm (inducer/exducer) |
#28 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
Also: those measurements you listed are the measurements for the compressor and turbine wheels in the export spec (non-jdm) Supra, not two different turbos, just the two wheels in the CT12B turbo. The vast majority of them have identical turbos, I've never actually seen one that didn't have identical turbos, only seen somebody's evidence that they existed way back then... Last edited by Sellout; 04-20-2014 at 05:13 PM. |
| Twin Turbo FR-S/BRZ? | KidWonder | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 06-27-2014 02:22 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 03:36 PM |
| Twin Turbo BRZ | xn7485 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 10 | 08-23-2013 08:13 PM |
| Dealership twin turbo brz... | BRZ283 | BRZ First-Gen (2012+) — General Topics | 23 | 06-03-2013 11:59 AM |
| Twin Turbo kit? | enjoi23 | Forced Induction | 15 | 12-03-2012 08:53 PM |
