Old 07-29-2014, 02:17 PM   #15
ddeflyer
Originally Posted by Sleepless View Post
This matches what I see with the Perrin cooler (which I believe is the same as the JR). I've seen others post the same temps for NA.
Ok, cool, err hot I guess
Reading about JR SC'ed engines hitting 245 in hotter weather yet got me a little worried. This last weekend was my first time getting really good data logging.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 07-29-2014, 04:07 PM   #16
CSG David
CSG David's Avatar
Originally Posted by ddeflyer View Post
I have the NA JR oil cooler (I am NA with stock tune, using 0w20 300V) on my car and have a max oil temp of 235F at Thunderhill in ~103F ambient. Is this abnormally high? In cooler weather before getting the oil cooler I was easily hitting 270F, probably peaking at or close to 280F (didn't have good logging then).
JR NA OC is the same size as FI. The brackets and lines are different. Max oil temp at 235ºF is actually very impressive. We have seen instances of potential 300ºF without oil cooler. This is very dangerous for the engine.
Perrin Oil Cooler uses a 6-series Setrab cooler I believe and the Jackson Racing uses a 9-series 15 row Setrab cooler. JR's setup has the largest volume oil cooler kit available on the market right now. The 6-series is rated to ~200HP and the 9-series is rated to around ~310HP. The ratings obviously have a safety factory built into it so it's a guideline, not an absolute.
We've hit higher than that, but know exactly what to do to bring the temperatures down further. It just goes to show that the oil cooler is a necessity with boost and/or tracking.
Old 07-29-2014, 04:10 PM   #17
CSG David
CSG David's Avatar
Originally Posted by wizzo View Post
Would benefits be had by using a larger setrab oil cooler possibly?
Larger is nice for cooling, but remember, too large means potentially too large of a pressure drop which is bad for the lubrication system. Larger Setrab oil cooler may require an external oil pump to maintain oil pressure and you may need to consider stronger/larger fans to pull air through the fins for proper cooling. Everything is a balancing act.
Old 07-29-2014, 04:11 PM   #18
235 is totally solid.
Old 07-30-2014, 03:53 AM   #19
wizzo
Drives: 2014 Toyota 86
http://www.setrabusa.com/products/oi...ine/index.html
If you look at the 9-series coolers which is what jackson racing use i believe, they use the 15 row, im thinking to step 1 size up to the 20 row, i would rather piece together a kit because it is much cheaper shipping wise, i can get a setrab cooler from a local dealer and all lines other than the mocal thermostatic plate can be done locally. If im not mistaken the pressure drop on the 20 row oil cooler is less than on the 15 row, and its dimension are decent
wizzo is offline   Reply With Quote
Old 07-30-2014, 01:06 PM   #20
CSG David
CSG David's Avatar
We've discussed using that too...
The 20-row is kind of the last resort before going custom (uber pricey). Since you have a relatively custom setup, don't forget to get some strong fans and vented hood to help improve the cooling efficiency!
Old 07-30-2014, 02:05 PM   #21
Sleepless
Drives: 2016 FR-S
@CSG David Is there a plan to offer more cooling for the JRSC given the high oil temps you've seen even with their current oil cooler? Their claim is that the current cooler keeps temps below 245F, but it seems that is a bit optimistic; yes?
Sleepless is offline   Reply With Quote
Old 07-30-2014, 02:46 PM   #22
sw20kosh
Drives: 2013 Black FR-S
Mind elaborating on this one? Or is it a secret?
Old 07-30-2014, 04:34 PM   #23
CSG David
CSG David's Avatar
We've actually hit 270ºF with the JROC kit. That's not to say that it's not working, but rather the mere fact that anything else will be yielding much higher oil temperatures. We also get the temperature that high by purposely driving behind cars (drafting), going to tracks that have ~110ºF OAT and minimal time for air to flow through the heat exchangers.
Keep in mind we are running a prototype radiator so the fin density is higher thus potentially providing too large of a restriction for air to pass through efficiently. We will look into a fan setup before going vented hood to collect more data on each setup and their effectiveness.
No secrets; just common sense. High powered fans and vented hood along with the mentioned setup we're using. Aftermarket radiator isn't necessary for our application, but we did it for the sake of data and science.
Old 07-30-2014, 05:11 PM   #24
Sleepless
Drives: 2016 FR-S
270F is not a big deal; I got the impression you hit higher.
Yes, I'm monitoring tracked FI kits for the possible future upgrade
Old 07-30-2014, 05:14 PM   #25
CSG David
CSG David's Avatar
Yea...it's not ideal, but you get the idea. Below 245ºF oil temp would be better obviously, and it's not hard to hit.
Old 07-31-2014, 02:01 PM   #26
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Great info here guys.
Subscribed for info and to add our results data...
So far we have for tracking our car in 75-85 ambient:
Stock:
Coolant- 215-217
Oil- 265-275
Modified:
Koyo Rad- 198-205
Oil- 265-275
We would like to see 215-220 on the oil temps.
Testing the OEM WRX 2015 cooler first, then on to OTS coolers and eventually probably a custom setup.
This is running 1:20-1:21 at NJMP Lightning course.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 07-31-2014, 05:57 PM   #27
We hit 270F without the OC, with only the SC on. Peak I have in our logs is 251F in 113F ambient, after 5 laps.
Old 07-31-2014, 06:02 PM   #28
Sleepless
Drives: 2016 FR-S
Interesting as it is common to hit 270F stock ...
HKS Oil Cooler Kit - Keep those oil temps down. - Photos FT-86 SpeedFactory Engine, Exhaust, Transmission 23 08-10-2015 04:08 PM
Robi-Cooler Install....Oil Temps under 180??? Deep Six Engine, Exhaust, Transmission 28 08-07-2014 01:30 PM
Oil Temps Fish Eagle AFRICA 13 07-22-2014 06:53 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 06:46 PM
