Old 10-25-2014, 04:10 PM   #15
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
From the limited information posted I get the impression they are not after big power. Stg 1 is limited to less than 8 psi.
One aspect I can see from the pic that I am not crazy about is how uneven the air intake box lines up with the snorkel. The weight of the tubing is pulling it to the left causing the box not to line up flush where the snorkel pipe meets with the air box.
Similar thing happened to me when I had the phantom. The compressor weight pulled the box out of position. Nor that it hindered performance but still.
This thing is selling for $3300. If the install does not require bumper removal and is ez to install I may consider. Personally I like that it comes across as a safer, lower powered turbo than some others. Supporting mods can get expensive when you command more power
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline
Old 10-25-2014, 11:15 PM   #16
brianhj
Drives: 2017 Camaro 1SS
I love that you made it look stock and didn't use retarded colors with flashy logos all over it
brianhj is offline
Old 10-25-2014, 11:27 PM   #17
xwd
It looks like no IC period. Has one of those "heat sink" pipes but that's it.
xwd is offline
Old 10-26-2014, 01:29 AM   #18
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I remember another turbo kit that was very simliar (pre-intercooler cooling pipe) that was posted about a year ago? Can't remember if it was a one-off or another company's offering that failed..
Anyways, good to have another [what appears to be] quality turbo kit option. Curious on results, especially when boost is turned up a little.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline
Old 10-26-2014, 02:33 AM   #19
nonicname returns
Drives: 4 wheels
so does it works?!
nonicname returns is offline
Old 10-26-2014, 03:32 AM   #20
woode
Boosted Member
woode's Avatar
Originally Posted by nonicname returns View Post
so does it works?!
Does it _____________?
You might get better results in regards to answers for your questions if you ask them in entirety.
My big criticism would be the pre-turbo MAF sensor. It's good that its a BPV vice BOV, but I'd personally prefer to have the MAF showing true IAT - especially without a true intercooler.
woode is offline
Old 10-26-2014, 08:24 AM   #21
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Light weight smaller battery should do the trick for this bad boy aha
Carlitoz3 is offline
Old 10-26-2014, 08:53 AM   #22
raven1231
It was supposed to be a pun I think.
raven1231 is offline
Old 10-26-2014, 08:56 AM   #23
raven1231
[QUOTE=Boofneenee;1998216]From the limited information posted I get the impression they are not after big power. Stg 1 is limited to less than 8 psi.
This thing is selling for $3300. If the install does not require bumper removal and is ez to install I may consider. Personally I like that it comes across as a safer, lower powered turbo than some others. Supporting mods can get expensive when you command more power[/QUOTE
Yeah not a bad price. Not sure if I'm really sold though. Curious to see how the install is and how the stage 2 is going to be
Old 10-26-2014, 11:03 PM   #24
RosarioBRZ
RosarioBRZ's Avatar
Originally Posted by WORKS View Post
We will be ready to ship our first batch of WORKS Stage 1 Turbo Kits early November after SEMA!
To aid in the finalization of installation instructions and documentation, we are offering our Stage 1 Turbo Kit, installation labor and custom in-house dyno tune at a substantial discount.
We are looking for 1 to 2 individuals who meet the requirements listed below.
1. Your vehicle is preferably completely stock, but we can work with a vehicle that has a cat-back and/or drop in air filter (must at least have stock air box, headers and injectors).
2. You are willing to let us have your vehicle for 4-5 days.
3. You have one of the following: Open Flash Tablet, brzEdit license or EcuTek license; OR are willing to purchase one these.
4. Your vehicle is equipped with a manual transmission.
These kits will be in complete production form (in the same form that the kits sold publicly will be).
Visit our web-store listing here (http://store.worksmotorsports.com/WO..._p/142.211.htm) to see an in-depth description and Q&A of our Stage 1 Turbo Kit.
Some highlighted features of our kit are:
  • Genuine Garrett GT28 JB water cooled turbo
  • Ceramic Thermal coated up and down pipes
  • Proper heat protection
  • Retains the factory air box, exhaust manifold and front pipe
  • Does not remove or compromise the factory emissions components
  • ~7.4psi peak boost @ ~3100RPM
  • ~70HP, ~48ft./lb. gain at the flywheel using 91 octane
Someone who can take advantage of this offer before next Tuesday (the 28th) will save over $800!
Please PM for specific pricing and additional questions.
Cheers!
Will definitely be interested!
Just a clean BRZ
RosarioBRZ is offline
Old 10-27-2014, 11:26 AM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
so does it works?!
It doesn't WORKS for me.
King Tut is offline
Old 10-27-2014, 01:56 PM   #26
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
They still didn't list anything for an intercooler...
hmong337 is offline
Old 10-27-2014, 02:04 PM   #27
xwd
Because it doesn't have one. You can see all of the piping right there. It has one of these things:
http://www.siliconeintakes.com/produ...32da4664707a9f
There is a reason why the kit is running 7.4psi.
xwd is offline
Old 10-27-2014, 02:16 PM   #28
themajesticone
themajesticone's Avatar
Drives: '13 UM86
This kit doesn't seem like a bad alternative if you want a modest power upgrade without spending $2,000 or more on top of their starting price for some other kit. If you're looking for big power then clearly this isn't the kit to go for right? This seems like it competes with the Innovate S/C and Jackson S/C kits
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 08:24 PM
Hello from WORKS Motorsports! **10% discount for FT86club Members!** WORKS Announcements, Contests, Giveaways 1 04-16-2014 11:04 PM
Full Blown Stage 2 Turbo Kit Official Release!! FullBlown Forced Induction 53 11-18-2013 12:58 PM
Discount offer on Tirerack zoomzoomers Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-01-2013 06:45 PM
Subaru $50.00 test drive offer/ $500.00 discount card terrypm BRZ First-Gen (2012+) — General Topics 7 08-24-2012 12:33 PM
