Old 03-03-2013, 09:43 PM   #15
Xdragonxb0i
Drives: ex500r
What did you install a Header and front pipe? thankx for the right up/
Xdragonxb0i is offline   Reply With Quote
Old 04-24-2013, 06:21 PM   #16
swift996
swift996's Avatar
For the front pipe, how much torque should be applied to the nuts?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-17-2013, 05:09 PM   #17
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Overpipe to Front pipe - 31.3 FT LB
Front pipe to Exhaust Pipe - 14.3 FT LB
Old 08-28-2013, 03:34 PM   #18
86KEEBS
DRIFT
Drives: Raven FRS 6mt
What about header torque?
86KEEBS is offline   Reply With Quote
Old 08-29-2013, 10:53 AM   #19
Mikee_FR-S
Drives: Firestorm FR-S
You're my HERO!!!! Thanks!
Mikee_FR-S is offline   Reply With Quote
Old 10-26-2013, 07:37 PM   #20
no chrome
She said member
Drives: fr-s firestorm
Having just done the header swap in my driveway, I have a note about O2 sensors
The rear sensor is easier to remove on the car with wire harness intact
The front sensor wire is easier to unclip and then remove sensor while header is off the car
Especially if you don't have a O2 socket handy
no chrome is offline   Reply With Quote
Old 12-15-2013, 07:44 AM   #21
subwaynm
subwaynm's Avatar
Drives: Scion FR-S Coupe
Thanks much for posting this DIY
subwaynm is offline   Reply With Quote
Old 04-28-2014, 05:31 PM   #22
benlaz88
Drives: 2013 Asphalt FRS
what are the easiest way to take out the front flange bolt that connect to the overpipe? Its too tight, couldnt loosen it I try and no luck so far.. suggestion would be great. I'm installing my front pipe/test pipe from MOtiv Concept.
Problem solve
benlaz88 is offline   Reply With Quote
Old 04-28-2014, 06:10 PM   #23
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
@GrimmSpeed, I found when putting in my manifold that I needed a deep socket 14mm to tighten down the header nuts, so that's a necessity. Never found a need for a deep socket 10mm in this installation.
^GT5 Replay Photo Mode^
Old 07-04-2014, 06:28 PM   #24
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Is the only way to install an over pipe seriously to jack up the engine?
Nevermore is offline   Reply With Quote
Old 07-04-2014, 08:32 PM   #25
Venator
Venator's Avatar
Drives: Asphalt FR-S
NO! I was able to do it by taking the heat shields off first.. Check out steps 11 and 12.
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 07-04-2014, 08:35 PM   #26
cnk
Drives: '13 DGM BRZ Limited
^+1 take the heat shields off and it's easy to snake the OP towards the rear.
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Old 07-05-2014, 12:19 AM   #27
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
We did get it out that way. I was asking about putting an aftermarket one back on. We did finally get it in without moving the engine.
Old 07-05-2014, 12:22 AM   #28
cnk
Yeah. . aftermarket OP is even easier to install since you don't have to deal with the heat shields. Just have to twist it around until you get the right angle.
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 06:50 PM
T1R exhaust for the FRS/BRZ ! AJ PwR Engine, Exhaust, Transmission 57 06-22-2013 11:39 PM
AVO Exhaust Blaaaack-BRZ Engine, Exhaust, Transmission 22 10-17-2012 12:28 AM
HKS Exhaust 01s0uljah Engine, Exhaust, Transmission 1 05-18-2012 10:15 AM
Exhaust system: dual or single KiingDavid Engine, Exhaust, Transmission 162 05-04-2012 02:33 AM
