Old 02-03-2015, 09:54 PM   #15
kodyo
Drives: Scion FR-S
Originally Posted by trsiidno View Post
I dont get how any of this works but i have a guy that sells the diff for that car do i just say i need the m85 differntial and thats it?
M85 is a sticker that should be on the diff itself. If it has fallen off, you can still tell if it's an LSD based on the door jam tag. M98 will also work, but has a higher gear ratio than the M85. See my pic below.
From an IS300 forum:
"How to tell if my IS300 has LSD?
Look at the sticker on your driver door sill/jamb, look for the area that reads "A/TM"
You'll see numbers such as B02A, B02B, B02C
A=no LSD
B,C = LSD"
Here's a great DIY on how to swap it yourself.
http://www.ft86club.com/forums/showthread.php?t=54054
It's a pretty easy swap. I got so good at rebuilding it I could do the whole job in my parking lot in 2 hours (including jacking up the car). But that's after doing it at least 4 times.
I recommend replacing the axle seals when you swap, it can be done without much pain and cost about $10 for the seals (save yourself the headache of a diff leak). Make sure you put multi purpose grease on the axle seals too before install.
kodyo is offline   Reply With Quote
Old 02-03-2015, 09:57 PM   #16
Dipstik-sportech
Dipstik-sportech's Avatar
U can also weigh it, non lsds only weigh 50ish pounds, while the LSD onesr over 90
Old 02-04-2015, 10:41 AM   #17
xwd
Is there anything special about the non LSD vs the LSD one if you are going to install an aftermarket LSD? I plan on using an OS Giken LSD.
Old 02-04-2015, 07:58 PM   #18
Dipstik-sportech
You'd be better off going with the open diff then because you'll be paying more for something you aren't going to use. As far as I know there is zero difference between the two other than the LSD itself.
Old 02-05-2015, 12:32 AM   #19
Poodles
Drives: 2015 Series.Blue
How do you correct the speedo after doing this swap? Just trying to put this info away for future upgrades.
Old 02-05-2015, 07:36 AM   #20
Dipstik-sportech
The speedo stayed the same, it takes it's reading from the abs sensors not in the trans like most older cars so the gear ratio doesn't affect it.
Old 02-05-2015, 03:07 PM   #21
UtahSleeper
UtahSleeper's Avatar
Drives: 80 Corolla 88 Celica Alltrac 13 FRS
Pardon my noobness. How much would this slow down a stock car? I am not a fan of the gearing of the trans for my commuting and wondering if getting this diff would yield better MPG's.
I know most people are out for power, but I have other cars for that lol.
UtahSleeper is offline   Reply With Quote
Old 02-05-2015, 05:27 PM   #22
Dipstik-sportech
It might work for a stock car but you might be to low in the rpm band for a stock engine.
Old 02-06-2015, 03:55 PM   #23
UtahSleeper
I guess I would need to figure out what power levels would be needed to make it all feel good. Down the road I plan for the simple EL headers and exhaust, tune and drop in filter with maybe the power blocks. I just hate being at 70 mph and sitting at 3k when just cruising.
Old 02-06-2015, 04:06 PM   #24
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
I feel ya @UtahSleeper. I am going to do the swap simply because of that reason. Needs a lower cruising RPM in 6th gear at 80 mph. I would like to see 2,500 RPM at 80 mph.
AVodka14 is offline   Reply With Quote
Old 02-07-2015, 11:02 AM   #25
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Lower RPM doesn't always equal better fuel economy. Your powerband also plays into fuel economy.
If the lower RPM band requires more load on the engine (more throttle = more fuel) to maintain speed, you will lose fuel economy. If your RPM band is slightly higher than that, but reduces that engine load requirement, your fuel economy increases.
Sure higher RPM will have more combustion, however, notice how at lower RPM you have to really floor it compared to the higher RPM (powerband).
If you're going for economy only, keep your FD in there. I'm 100% positive that the engineers designed it properly in that way. I mean, I had mid-30 MPG on a 1500 mile road trip in mine. That's calculated by fuel receipts, not the gauge.
slicktop is offline   Reply With Quote
Old 02-07-2015, 12:13 PM   #26
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I usually cruise at around 3k rpm in 6th and i can barely get 30mpg.
Muaddib is offline   Reply With Quote
Old 02-07-2015, 12:24 PM   #27
Malt
Drives: 2015 WRX
How you drive while you are not cruising has just as much effect on total MPG. Air resistance increases at the square of speed so traveling faster nets increasingly lower MPG. Jack rabbiting starts and stops also kills mpg.
Malt is offline   Reply With Quote
Old 02-07-2015, 12:59 PM   #28
Muaddib
Mentat
Muaddib's Avatar
My commute is 220km. I just set it on cruise control. So i am not flooring it like a retard.
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 01:48 AM
You know what really grinds my gears...... z3ro Off-Topic Lounge [WARNING: NO POLITICS] 7 10-10-2013 02:55 PM
Smoothing out 1st and 2nd gears BRZerk Engine, Exhaust, Transmission 33 02-26-2013 06:30 PM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 06:09 PM
Changing Gears Naughty AFRICA 10 01-09-2013 01:30 PM
