#15 | |
Drives: sti 2012 sedan
I am having the same issues. I have a lean condition at low rpm (below 3,000). After I installed FI kit (Works) it would run rough on low rpm, just after 4k and between 5 and 6k. this is after I bought the "flash and go" tune. on works tune there was no issue. since I wanted more power via flex fuel route I went ahead and got an e-tune. on an up hill, from a stop, it would not go at all. I have to rev pass 3k then I could go. before reading your thread, I check for leaks, check fuel pump and installed check valves on EVAP lines and capped the evap line near under throttle body. but still it did not fix the problem. I even received a beta tune from Delicious tuning to fix the lean condition but still the same problem. I was thinking it could be the fuel pressure regulator located in the fuel pump canister.
But since your Fullblown was able to fix it with a tune, it really gives me hope that it could be a tuning problem and not mechanical. So, are you still good with the tune that you got from fullblown? Quote:
#16 |
Drives: Late 2014 Subaru BRZ
LJ's tune that shipped with the kit afr and response is spot on. I think when it's time to tune for more boost. I will have to ship my car to him as I don't trust remote tunes or any local tuners.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#17 |
Drives: toyota 86
From the logs- I think ur issue is the Maf scaling, need way more fuel down low. about 15-20% more during idling . glad u fixed it
| OFT Issue | HotRodPA | Software Tuning | 19 | 10-13-2014 02:00 AM |
| A/C Issue? | FUN BRZ | Issues | Warranty | Recalls / TSB | 5 | 02-08-2014 03:34 PM |
| LED DRL issue | CaptainSlow | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 08-12-2013 06:15 PM |
| TCS Issue | subaruatheart | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 04-26-2013 02:28 PM |
| Anyone has the same issue like me? | ShowTime_DW | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 04-16-2013 11:23 PM |
