Old 06-07-2023, 01:32 AM   #267
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
So stock trans? What clutch are you running?
Old 06-07-2023, 12:04 PM   #268
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Yes, stock trans. I have a spare ready to go whenever 4th decides it's ready to change state. Running a Southbend Stage 3 daily clutch w/ a Fidanza lightweight flywheel, I am amazed that this clutch is holding and suspect "how long" is the next logical conclusion.
To be honest, I like this clutch so much that if it won't hold more, I will back it down. I am also hopeful that the carbon fiber driveshaft is helping to reduce shock load and "extend" the life of whatever the weakest link ends up being.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 06-12-2023, 05:04 PM   #269
DarkPira7e
DarkPira7e's Avatar
Got tired of the black hood, I emailed PTP to see what their thoughts are on the turbo blanket getting soaked once in a while. I imagine it should be ok until it gets so crispy it comes apart, we'll see what they say.
Everything gets so heatsoaked without the vents, I don't want to cook more coilpacks. Bring it on, rain.
Old 06-12-2023, 06:37 PM   #270
Joveen
Joveen's Avatar
Drives: Bone stock
Nice!! Unfortunately for me the shop I brought my car to said that I need a new trans but I honestly think they messed up installing my clutch. Can't wait to get boost going to drive up to meet you bruh.
Sent from my SM-F936U1 using Tapatalk
Joveen is offline   Reply With Quote
Old 06-12-2023, 07:01 PM   #271
DarkPira7e
DarkPira7e's Avatar
I would definitely fight them on that... There was nothing wrong with it before, right??? Don't take it lying down
Old 06-13-2023, 11:34 AM   #272
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
rain-guards from Verus Would these solve it?
Old 06-13-2023, 01:53 PM   #273
DarkPira7e
DarkPira7e's Avatar
It'll help a little bit not mitigate the issue. They want way too much for shaped aluminum so I'm reluctant to try. I drove today with everything saturated- it all dried off and the texture/pliability of the material was not changed in a way I could detect
Old 07-02-2023, 11:17 AM   #274
DarkPira7e
DarkPira7e's Avatar
First road trip! 315 miles, no stops, lots of hills. Very impressed!
Old 07-03-2023, 01:50 PM   #275
Teseo
Drives: frs
Had a change of heart, instead of getting quieter I went louder. It's actually quieter inside the car at cruising speeds.
Wanted the weight savings and the quad just wasn't JDM enough
May ask you what catback was there in this picture? Fitment was on point and very 90's jdm vibe
Old 07-03-2023, 02:49 PM   #276
DarkPira7e
DarkPira7e's Avatar
Greddy Revolution RS
Old 08-24-2023, 03:58 PM   #277
DarkPira7e
DarkPira7e's Avatar
Long time no update! Car is running well. In the process of fitting a resonator onto the Remark x ft86speedfactory catback.
The data was nice from the GM IAT but we're going to put the MAF back on the fix idle stumbling and just get some drivability back. The intercooler performs well enough that there's not really a need for a higher poll rate sensor anymore.
Old 09-09-2023, 04:02 PM   #278
DarkPira7e
DarkPira7e's Avatar
Nick got some shit done while I was at work today!!
Return style fuel setup with a Walbro 450!
Now we don't have to worry about boost leaning out the fuel pressure.
Nick is 99% sure he was able to keep the Venturi functional - I guess we'll find out!
Old 09-09-2023, 04:06 PM   #279
Joveen
Joveen's Avatar
Drives: Bone stock
I thought you went a single exit.
Old 09-09-2023, 04:40 PM   #280
DarkPira7e
DarkPira7e's Avatar
Hey Jovi! I switched back, just way too loud outside the car. Quieter inside, which is odd...
brz, frs, iag, jdl, turbo
Joel's BRZ - Low Budget Time Attack Build DIY Member's Car Journals 403 11-19-2024 08:39 PM
Cxracing turbo problem Kalebhall Forced Induction 10 11-16-2017 08:57 AM
Tony's Budget Turbo Build glorydays Member's Car Journals 22 01-26-2015 12:02 AM
My boosted build...on a budget PineappleFriedRice Member's Car Journals 95 08-17-2014 10:29 PM
Aznsky's budget STX build Aznsky Tracking / Autocross / HPDE / Drifting 13 05-12-2014 09:44 AM
