Old 02-17-2016, 10:30 PM   #281
eddieflyinv
eddieflyinv's Avatar
Originally Posted by ZHoward View Post
well i open stg 2 file and there are no 176 option and no overrun option....
[IMG][/IMG]
i just checked an OFT 700C Stage 2 rom and its there,
make sure to use the appropriate OFT Defs from here for your calid
http://www.ft86club.com/forums/showp...&postcount=411
the OFT Zip files is what youre looking for, and just the right one for your calid.
just confirming you do use OFT to flash ? and what is your calid?
eddieflyinv is offline   Reply With Quote
Old 02-18-2016, 02:28 PM   #282
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
did you guys change the values for 7600 rpm? My 91 only went up to 7400. now my e85 goes up to 7600
shaynek is offline   Reply With Quote
Old 02-18-2016, 02:33 PM   #283
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
Just test stg2 UEL on my car, there are pops between 2500 to 3000rpm, but if I go over than that, no pops... Borla v2 UEL, Motiv HFC front pipe, invidia N1
ZHoward is offline   Reply With Quote
Old 02-18-2016, 03:55 PM   #284
_gt86_user
Inactive
Drives: .
Yup that sounds about right, as I recall a few people saying they couldn't get anything above 3500rpm usually.
_gt86_user is offline   Reply With Quote
Old 02-18-2016, 04:18 PM   #285
Maggie_Mullen
Drives: Subur / Scion
that really great man thanks for the info and video. Great stuff really.
Maggie_Mullen is offline   Reply With Quote
Old 02-18-2016, 10:47 PM   #286
eddieflyinv
Same here so far.. Probably gotta play with either the resume setting or the counters... Havent gone into it much yet, but on shifts I get some decent crackles above 3500 rpm
Sent from my LG-H812 using Tapatalk
Old 02-22-2016, 02:19 PM   #287
denso
Drives: 86
Hi, what about this?
Overrun Fueling RPM Resume Threshold will rich out the AFR from 7000rpm.
Base Timing Idle (In-Gear)(Above Threshold) will retard the ignition until 1000rpm.
This should bang-bang until 1000rpm if you just lift your foot.
denso is offline   Reply With Quote
Old 02-22-2016, 03:16 PM   #288
ort895
ort895's Avatar
Hmmm
Try it out
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 02-22-2016, 03:19 PM   #289
denso
Drives: 86
Yea I will but my car is logged out atm until march.... damn winters in germany
Old 02-22-2016, 07:00 PM   #290
ZHoward
ZHoward's Avatar
Is that safe?
Old 02-22-2016, 07:19 PM   #291
denso
Drives: 86
I dont know, I didnt test it yet.
This should be the tables we are looking for in my opinion. It seems logical.
I'll try it if I get my car back out of its sleep.
I talked to a friend of mine (MTR Performance, check out at facebook!)
Hes very good at VAG Software (Audi TTRS, Golf 6R/7R,...)
VW Golf 7R e.g. are using this kind of overrun settings and the cars are sounding great at decelleration.
Old 02-22-2016, 08:12 PM   #292
ort895
ort895's Avatar
Go go go, make it sound like an f type
Old 02-27-2016, 01:28 PM   #293
VeilSide
Drives: GT86
The overrun function is working perfectly. Just set the RPM delta to -10 or whatever and set a desired angle in the Base Timing Idle (in gear) table.
Unfortunately it seems that the pops and bangs trigger the knock sensor and the IAM is constantly kept at 0
VeilSide is offline   Reply With Quote
Old 02-27-2016, 08:01 PM   #294
eddieflyinv
Weird, i never had any knock due to this, with all kinds of different setting combos :/
IAM steady @ 1 after a couple hundred kms
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 05:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-18-2014 12:07 AM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
