Old 04-02-2017, 10:09 PM   #29737
jeffsides
AZ FRS 86
jeffsides's Avatar
@AZFRS86
Old 04-11-2017, 11:01 PM   #29738
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Does anyone have a Release series they would be willing to Let us test fit a part on for 1-2 hours? We will compensate you for your time! Thanks!
JDLAutoDesign is offline   Reply With Quote
Old 04-11-2017, 11:07 PM   #29739
jeffsides
AZ FRS 86
jeffsides's Avatar
@AZFRS86
Old 04-12-2017, 12:56 AM   #29740
Gmo
Gmo's Avatar
Drives: 2013 Gray BRZ
What is a "Release" series? Please excuse my ignorance, but if I can help, I'd be more than happy to.
Gmo is offline   Reply With Quote
Old 04-12-2017, 01:03 AM   #29741
edgary
A special edition. See here (there's also a Release 1.0).
edgary is offline   Reply With Quote
Old 04-12-2017, 01:33 AM   #29742
alexjandro
alexjandro's Avatar
Drives: 2013 FRS
would a 10 Series work or just the Release 1/2s ?
alexjandro is offline   Reply With Quote
Old 04-12-2017, 08:45 PM   #29743
Timewizard
Drives: FRS
Is there an Instagram Page for the AZ-FRS club?
Besides looking for an instagram page for the AZ-FRS club, I have a question about UEL headers, I would like to install Borla UEL headers without purchasing an OFT or ECUtek ecu... at first (Mainly because I cannot afford both at the same time) what are the most likely out comes of me driving with UEL headers without a tune or stand alone?
Engine damage?
Fuel economy?
Air to fuel mixture?
Check engine lights?
Bad smell?
Timewizard is offline   Reply With Quote
Old 04-12-2017, 08:50 PM   #29744
Wyattkb
Drives: 2014 Whiteout FRS
Engine damage?
Fuel economy?
Bad smell?
Check engine light.
That's it.
Sent from my Pixel using Tapatalk
Wyattkb is offline   Reply With Quote
Old 04-12-2017, 08:52 PM   #29745
Token11b
What Wyatt said. I've been running with my CEL for about 4 months now.
Token11b is offline   Reply With Quote
Old 04-13-2017, 12:32 AM   #29746
renfield90
The Stig's German cousin
You won't make even close to all the power you could, due to EL valve timings on an UEL header.
The CEL may kick you to the safe backup tune. This is safe for the engine but gives up a little bit of power because it errs on the rich side. Over the long term, running rich can foul the plugs.
For $160 you can get a Tactrix and upload an OFT tune...be sure you do your research (see threads and posts from steve99).
Old 04-13-2017, 09:26 AM   #29747
Wyattkb
These are possibilities and worst case scenarios. I even ran at the track without a tune.
I can tell you I ran close to 10k miles without a tune on my JDL UEL header and when I changed my plugs at 60k they were fine. Only changed them because I had to change that coil pack on the driver side that burnt out from the heat.
Old 04-13-2017, 10:47 AM   #29748
leets4uc3
Drives: Sprintex carbon fiber wide body
Anyone have a hook up for AP racing rotors?
leets4uc3 is offline   Reply With Quote
Old 04-18-2017, 12:23 AM   #29749
renfield90
This guy might be able to help: https://www.fastbrakes.com/
He's local.
Old 04-18-2017, 02:59 PM   #29750
leets4uc3
He's local.
Awesome thanks!
