#295 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Here the addresses dump for B01D:
Code:
RaM_Fuel_Type FFF8DC2A RaM_LTFT FFF8DB90 Ram_AFR_Sensor_Heating_Limit_Result FFF88478 Ram_AF_Correction_3_32bit_ECU FFF8A900 Ram_AF_Learning3_Percentage FFF8DC10 Ram_AF_Learning_3 FFF81640 Ram_AF_Sensor_1_Current FFF8932C Ram_AF_Sensor_1_Resistance FFF89344 Ram_Accelerator_Angle? FFF8B5B8 Ram_Accelerator_Pedal_Angle FFF89230 Ram_Accelerator_Pedal_Angle_0 FFF8DC14 Ram_Accelerator_Pedal_D FFF8DC00 Ram_Accelerator_Pedal_E FFF8DC04 Ram_Alternator_Duty FFF884A4 Ram_Ambient_Air_Temperature FFF8DBF8 Ram_Atmospheric_Pressure FFF8DBCC Ram_Atmospheric_Pressure_1 FFF89B94 Ram_Auxiliary_input_output_supported FFF8DC2B Ram_Base_Pulse_Width FFF89744 Ram_Base_Pulse_Width_times_100_0.84 FFF89CC0 Ram_Battery_Voltage FFF87C6C Ram_Battery_Voltage_0 FFF8DBD8 Ram_Brake_Switch FFF89393 Ram_CPC_Valve_Duty_Ratio FFF89CD0 Ram_CPC_Valve_Duty_Ratio_0 FFF8BD28 Ram_Calculated_Base_Pulse_Width_ FFF8A058 Ram_Catalyst_Temperature_Bank_1_Sensor_1 FFF8DBD4 Ram_Clutch_Switch FFF893A7 Ram_Commanded_Secondary_Air_Status FFF8DC29 Ram_CoolantTemperature FFF890A4 Ram_Coolant_Temperature??? FFF87C74 Ram_Defogger_Switch FFF8939F Ram_Distance_Traveled_since_DTCs_cleared FFF81CBA Ram_Distance_Traveled_with_MIL_On FFF81CB8 Ram_EVAP_Commanded_Purge FFF8DBC4 Ram_EVAP_System_Vapor_Pressure_Absolute FFF8DC0C Ram_Engine_Load_Absolute FFF8DBDC Ram_Engine_Load_Calculated FFF8DB84 Ram_Engine_Oil_Temperature FFF8DC20 Ram_Engine_Speed FFF89570 Ram_Exhaust_VVT_Retard_Angle_Left_ FFF8C148 Ram_Exhaust_VVT_Retard_Angle_Right_ FFF8C144 Ram_Fuel_Air_Commanded FFF8DBE8 Ram_Fuel_Injector_1_Pulse_Width FFF887D8 Ram_Fuel_Injector_1_Pulse_Width_4byteExt_E60??? FFF887F0 Ram_Fuel_Injector_2_Pulse_Width FFF887DC Ram_Fuel_Injector_Pulse_Width? FFF88810 Ram_Fuel_Pressure_MPa FFF89378 Ram_Fuel_Pump_Duty FFF8B1B4 Ram_Fuel_Rail_Pressure_direct_inject FFF8DBB8 Ram_GDI_Flow_Rate FFF88844 Ram_Gear FFF895E5 Ram_High_Low_Load_0_L_1_H FFF8A0F8 Ram_Idle_Switch FFF8B5C6 Ram_Ignition_Total_Timing FFF8AE0C Ram_Intake_Air_Temperature FFF8DBA4 Ram_Intake_Air_Temperature_0 FFF87C64 Ram_Intake_OCV_Current_Left FFF891B8 Ram_Intake_OCV_Current_Right FFF891AC Ram_Intake_OCV_Duty_Left FFF8C20C Ram_Intake_OCV_Duty_Right FFF8C218 Ram_Intake_Temp FFF890B8 Ram_Intake_VVT_Advance_Angle_Left FFF8C100 Ram_Intake_VVT_Advance_Angle_Right_ FFF8C0FC Ram_Map FFF8DB94 Ram_Map_Delta? FFF8A234 Ram_Mass_Airflow FFF89118 Ram_Mass_Airflow_0 FFF8DBA8 Ram_Number_of_warm_ups_since_DTCs_cleared FFF826CE Ram_O2_currrent FFF8DBD0 Ram_O2_volt FFF8DBC0 Ram_Per_Injector_Pulse_Width_Compensation_A FFF8AB44 Ram_Per_Injector_Pulse_Width_Compensation_B FFF8AB4C Ram_Per_Injector_Pulse_Width_Compensation_C FFF8AB54 Ram_Per_Injector_Pulse_Width_Compensation_D FFF8AB5C Ram_Per_Injector_Pulse_Width_Compensation_E FFF8AB64 Ram_Per_Injector_Pulse_Width_Compensation_F FFF8AB6C Ram_Per_Injector_Pulse_Width_Compensation_G FFF8AB74 Ram_Per_Injector_Pulse_Width_Compensation_H FFF8AB7C Ram_Rear_O2_Sensor FFF8DBB0 Ram_Roughness_Monitor_Cylinder_1 FFF8CEDD Ram_Roughness_Monitor_Cylinder_2 FFF8CEDE Ram_Roughness_Monitor_Cylinder_3 FFF8CEDF Ram_Roughness_Monitor_Cylinder_4 FFF8CEE0 Ram_Run_Time_Since_Engine_Start FFF84DB4 Ram_SI_Drive_Mode_I3_S1_SSharp2_ FFF88999 Ram_STFT FFF8DB8C Ram_Throttle_Opening_Angle FFF8DBAC Ram_Throttle_Opening_Commanded FFF8DC08 Ram_Throttle_Position_relative FFF8DBF0 Ram_Time_Run_since_DTCs_Cleared FFF81CBE Ram_Time_Run_with_MIL_On FFF81CBC Ram_Timing_Advance FFF8DBA0 Ram_Transient_Threshold_Testunk FFF89240 Ram_Vehicle_Speed FFF8DB9C Ram_Vehicle_Speed_0 FFF893D0 Ram_coolant_temp FFF8DB88 Ram_fuel_level FFF8DBC8 Ram_lambda FFF8DBBC E_AF_Correction_1_4byteExt_E81 FFF8A5EC E_AF_Learning_1_4byteExt_E48 FFF8A774 E_AF_Sensor_1_4byteExt_E91 FFF89330 E_CLOL_FuelingExt_E33 FFF8DC26 E_Closed_Loop_Fueling_Target_4byteExt_E121 FFF8A6D0 E_Engine_Load_4ByteExt_E32 FFF8914C E_Engine_Speed_Delta_E157 FFF89408 E_Feedback_Knock_Correction_4byteExt_E39 FFF8B0C4 E_Final_Fueling_Base_4byteExt_E123 FFF8A01C E_Fine_Learning_Knock_Correction_4byteExt_E41_ FFF8B160 E_Fuel_Injector_1_Latency_4byteExt_E50 FFF8A05C E_Fuel_Injector_1_Pulse_Width_4byteExt_E60 FFF887C8 E_IAM_4byteExt_E31 FFF816F0 E_Idle_Speed_Map_SelectionExt_E49 FFF8B748 E_Ignition_Base_TimingExt_E53 FFF8AE88 E_Knock_Correction_Advance_4byteExt_E43 FFF8B0C0 E_Knock_Correction_Advance_IAM_onlyExt_E40 FFF8B134 E_Knock_Correction_Advance_Max_PrimaryExt_E118 FFF8B12C E_Manifold_Relative_Pressure_4byteExt_E113 FFF88F78 E_Manifold_Relative_Sea_Level_Pressure_4byteExt_E52 FFF88F74 E_Primary_Open_Loop_Map_Enrichment_4byteExt_E84 FFF8A988 E_Requested_TorqueExt_E56 FFF8B4A4 E_Target_Throttle_Plate_PositionExt_E57 FFF8B58C E_Throttle_Plate_Opening_Angle_4byteExt_E38 FFF89030 E_Tipin_ThrottleExt_E54 FFF89038 |
#296 |
Right on
![]() What data are you generating these from? I can infer some of the info from what others have posted, but is there a document that shows the data types and units of measure of each address?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#297 | |
unfortunatly no doco, if you find some post it up
#298 |
That's why we need to get these into standard notation sooner rather than later - your best bet is the logger.xml file from the Romraider Logger, combined with a look through the other logcfg.txt files users have put out there.
#299 |
#300 |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
I have version 1.59 OTS maps for OFT with the latest rom file listed as B01C. That means that all files are B01C calID? Also has anyone tried to log a ECUTEK tune with OP2?
#301 | |
NO !!! it does not you have to check with hex editor. or check table integrity. see first post. Also has anyone tried to log a ECUTEK tune with OP2? It should work if you match the RAM addresses with the tune calid, have not done it though. I believe they just change seed keys to prevent reading/writing of rom but RAM addresses for log parameters are likely the same. |
#302 |
Calle Atun
I am getting close to figuring out logging with the tactrix OP2 but I keep getting a logcfg.out file and red with flashing green lights. Any ideas?
#303 |
Calle Atun
Ha I got it. It was the Triggers. I remove the defrost trigger and it work. Steve99 also said he had a problem with the defrost trigger. Any one else have a trigger that works well I could use.
#304 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I couldn't get any triggers to work so I just plug mine in when I want to log and pull it out when I'm done (lol). Much easier with an obd2 extension cable.
#305 | |
Calle Atun
#306 | |
Drives: frs
so let's say you have: ---------------------- paramname = Manifold_Relative_Pressure paramid = 0xFFF88F78 isfloat = 1 paramname = Direct_Ijector_PW paramid = 0xFFF887E8 isfloat = 1 paramname = Direct_Injector_PW_Ram paramid = 0xFFF887F0 isfloat = 1 The memory addresses above in bold are numbers, so sorted numerically in asc order would be: ----------------------- paramname = Direct_Ijector_PW paramid = 0xFFF887E8 isfloat = 1 paramname = Direct_Injector_PW_Ram paramid = 0xFFF887F0 isfloat = 1 paramname = Manifold_Relative_Pressure paramid = 0xFFF88F78 isfloat = 1 |
#307 |
Calle Atun
Did you mix the triggers in with the rest or leave them at the bottom?
#308 |
Drives: frs
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 01:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 11:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 09:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 11:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 08:27 AM |
