Old 02-03-2014, 04:21 PM   #3137
TemeCal
Drives: 86
Originally Posted by Ryan86 View Post
I mentioned this problem awhile back, got told I over tightened.
I replaced all the bolts with black high tensile as Boxer 486 picture. Especially the pulley nuts, which I've snapped 2 with changing pulleys.
My mechanic used a hex head, knocked into the broken bolt and came out easy.
Thanks! So, I'm trying to understand how you (or your mechanic) removed the broken bolt (head missing).
I was planning to use an extractor. I have this tool kit, which has worked well on other bolts where the heads broke off:
[ame="http://www.amazon.com/Irwin-Industrial-53227-Multi-Spline-Extractor/dp/B0002SRG66/ref=pd_sxp_grid_pt_0_0"]Irwin Industrial Tool 53227 Hex Head Multi-Spline Extractor Set, 25-Piece - Amazon.com[/ame]
Did your mechanic use something similar? How'd he "knock into the broken bolt"? I've always had to drill a hole into the bolt, tap in the extractor, then unscrew.
Edit: It's a bit disheartening that Innovate is saying we "overtightened" them. I bought mine 2nd hand, so it was preinstalled. However, I'm pretty sure the bolt heads were there when I did the install. They seemed to pop off after a few thousand miles. The guy I bought it from, is a very competent, honest, good guy and I'm confident he torqued them to spec (everything else he did on this kit was properly done by the book). Looks like I'll be replacing them with higher quality bolts.
TemeCal is offline   Reply With Quote
Old 02-03-2014, 05:35 PM   #3138
sw20kosh
Drives: 2013 Black FR-S
I am shocked to hear the bolts have broken! I never over-tightened them. I was always worried that I hadn't tightened them enough actually...
Old 02-03-2014, 05:40 PM   #3139
TemeCal
Drives: 86
Trust me, I would never put the blame on you! I know you too well, and have talked with you enough to know everything was properly torqued. It's an easy fix.
...not to mention, several others have experienced the exact same thing and they properly torqued theirs as well. No worries. I'll replace them soon with better hardware!
I'm still loving the kit. No leaks that I know of. No belt issues. No hesitation now, runs silky smooth. Very happy!
Old 02-03-2014, 07:53 PM   #3140
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
@TemeCal
We used the exact same method you described above to remove the broken thread of the bolt.
We did have the kit off the car, which made it easier.
Good luck.
Ryan86 is offline   Reply With Quote
Old 02-03-2014, 08:17 PM   #3141
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I'm consistently getting the check engine codes P219A and P2096. I've checked and have no boost leaks and my o2 sensors are screwed in nice and tight. Thoughts?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 02-03-2014, 08:36 PM   #3142
Calum
That Guy
Drives: 2013 asphalt FRS MT
What do the codes mean?
Old 02-03-2014, 08:48 PM   #3143
xxscaxx
Drives: 2013 SWP BRZ
I have two that broke off as well. In fact, one of them is the same bolt you had snap.
Let me know how successful you are extracting the bolt. I've been putting off extracting them.
two broke on me as well, on the left (passenger) side. I had no issues until I put the intercooler in.
Extracting them is easy. Just use a pick and a magnet. Fortunately the bolts spin so freely, you can get them out very easily.
xxscaxx is offline   Reply With Quote
Old 02-03-2014, 09:03 PM   #3144
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Originally Posted by Boxer486 View Post
Ouch! They should be supplying those higher grade bolts with the black oxide finish at a minimum. Thermal change and vibration must be too much.
Do you have the length, thread, and top hex size and everything so I can go to the hardware store and get enough to replace all of them? I guess I could just take one off after parking and walk in with it if I need to.
Also what's the torque as i bought mine used.
stockysnail is offline   Reply With Quote
Old 02-03-2014, 09:13 PM   #3145
CK_Bladesmith
Drives: Raven FR-S
P219A = Bank 1 Air-Fuel Ratio Imbalance and P2096 = Post catalyst fuel trim system too lean bank 1
Old 02-03-2014, 09:35 PM   #3146
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I'll leave this here.. after 800 miles in the winter.. driving nice..
I left the cheap clear tube on the outlet so I could see if any oil was getting past the can.. It's actually really clean.. Cleaner than I thought it would be..
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 02-03-2014, 10:05 PM   #3147
xxscaxx
Damnit I need a catch can. Thanks @calispec.
Tune date is set for the 15th. Flex fuel/70mm/intercooled
Old 02-03-2014, 10:39 PM   #3148
TemeCal
Drives: 86
So, I just took one off and matched it at Ace Hardware. I matched it to be M6 x 20.
Extracting the bad ones was VERY easy. I was actually shocked how little force it took to back them out. I used a hand center punch to create a small indentation on top of the broken bolt. Then I used a pick, and wiggled/scraped it out.
I do need the torque spec, if someone has that (I'll look in the manual to see if it is there).
Edit: Page 18 of the install shows they are indeed M6 x 20. Torque to 12Nm.
Old 02-03-2014, 10:42 PM   #3149
swift996
swift996's Avatar
97 lb ft
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-03-2014, 10:46 PM   #3150
xxscaxx
Told ya Glad they came right out.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
