Old 09-05-2021, 12:08 AM   #309
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by PulsarBeeerz View Post
Ah, I was comparing power delivery to stock hence the dyno, where it clearly has plenty of power. Are you comparing to a turbo or roots SC? I missed the your post where you specify what you are comparing.
It was in response to somebody's post about the speed academy video where they put face to face their jackson racing supercharged FRS against their bolt-on S2000 and the S2000 did much better than expected. Just wanted to bring up the point that peak numbers are not everything and thats probably why they expected the FRS to destroy the S2000 (because peak numbers speaking, it had like 50-60whp more with the same weight and better aero).
Old 09-05-2021, 12:14 AM   #310
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by Icecreamtruk View Post
Yes, except that the S2000 from speed academy kept up at the track, AND on a rolling drag race, so yeah now, it was performing better, with less peak power.
Nah, don't try that.lol I saw the same video. Keeping up in a roll race does not included being left behind two bus lengths at the end of 4th..haha Also they freely admit the gearing advantage of the S2k and that its milder suspension setup favored the 340 tread wear summer tires where as the FRS was too stiffly sprung for them which you should understand.
PulsarBeeerz is offline   Reply With Quote
Old 09-05-2021, 02:56 AM   #311
steved
Drives: 2013 FRS
Not sure where all this is going with the SC FA20 vs F20C but gearing alone didnt make the FRS look bad, it's the gearing + a 9k redline that did the trick. If you can keep pulling in 2nd gear for another 10km/h when the other guy is forced to switch into 3rd that's a real advantage.
Having driven a JRSC FRS for the last couple years on track I can tell you I'd be much happier with a 8200rpm k24a2 making 250whp. At least I wouldn't overheat 4 laps deep and have an engine that feels worse than a stock FA20. Could an AP1 S2K keep pace? Likely as it still has more revs, better gearing, and better suspension characteristics but it would be fun to duke it out.
Maybe I can figure out how to mount my rotrex in this swap and still keep a/c, and that's where things could really start getting interesting around the 350whp range. Unfortunately the best track near by is an 800km round trip and a/c and reliability are paramount.
Personally I'm torn on whether to do this swap now. I was pretty sure this was a good move because like others I'm already pretty deep in with SC, Kw clubsports, bbk, wheels, and trying to figure out a way to maximize my investment but a Cayman S is looking pretty appealing and it has a good chance of retaining some of its value over the next few years. Who knows maybe even increasing.
One thing I'll note for anyone doing this swap who might want to compete in time attack or autocross at some point is check your local regulations carefully. Many of the classes prohibit cross manufacturer engine swaps and the classes that don't prohibit can put you in with much more capable chassis/cars no matter how much boost you throw at your twin.
steved is offline   Reply With Quote
Old 09-05-2021, 08:57 PM   #312
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I’m borrowing this pic from another forum member. The engine is probably slightly tilted forward here, but it shows the room the K24 motor has for being moved back. When they said it moved back 4”, it looks possible:
Old 09-06-2021, 01:28 PM   #313
Irace86.2.0
Just saying.
Old 09-06-2021, 02:27 PM   #314
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
GTA it is automatic bump to unlimited which is pretty lame, you can't swap engine from different manufacture. My car is Max 4 for SCCA time trial, it only bumps me up to Max 3.
8200RPM 250whp NA sounds like a party.
Old 09-07-2021, 12:18 AM   #315
Irace86.2.0
Personally, it is cool to compete, but the experience should be the same. In a field of mixed racers finishing slower and faster, if you finished 10th overall that could be 1st in one class or last place in the next class, but in the end, the person was still 10th overall and still drove the car the same, so what does it matter? Prize money? Sponsorships?
Old 09-07-2021, 12:16 PM   #316
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Just a waiting game now.
captain awesome is offline   Reply With Quote
Old 09-07-2021, 12:37 PM   #317
Irace86.2.0
Old 09-07-2021, 12:41 PM   #318
Irace86.2.0
What transmission are you going with?
Old 09-07-2021, 01:03 PM   #319
captain awesome
Wears Pants
Stock. I'm staying NA, unless I can manage to bolt in a Rotrex AND keep A/c. The other one in the pic is the automatic I pulled from the swap car. Shoulda started with a manual but I wanted a Whiteout FRS like my previous one.
Old 09-07-2021, 01:18 PM   #320
Irace86.2.0
Old 09-07-2021, 01:49 PM   #321
captain awesome
Wears Pants
I'm not too far from Humble so I may be using them to tune my setup including dyno time.
Old 09-07-2021, 02:08 PM   #322
Irace86.2.0
I’m trying to figure out how to pin or wire in other sensors that aren’t in our harness. I have a boost solenoid and flex fuel sensor. You would think there would be a tutorial or video somewhere on the internet, but I haven’t found anything. There will be a wiring diagram, but it would be nice to have a visual than just a schematic.
On the boost solenoid, the solenoid can be set up to bleed off boost pressure from opening the diaphragm until target boost is reached, or it can be set up to pressurize the top of the wastegate to resist the diaphragm from opening until target boost is reached. Seems like wiring could be different or maybe wiring could be the same, but the software runs the solenoid differently based on the setup parameters. I don’t know.
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 04:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 02:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 02:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 05:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 02:00 AM
