Old 02-12-2014, 02:02 PM   #3557
fenton
Originally Posted by WNDSRFR View Post
Just went out and took some more runs and noticed something really weird.
When under boost at about 6000 RPMs the traction control light comes on. You know, the light that comes on when your wheels are spinning. This is in third and forth gear! I doubt that my wheels are spinning in forth gear on dry pavement. This happens every time I hit about 6000 RPM. Has anybody else noticed this?
Also I have a question for Rob: What is that two conductor connector for that comes out of the motor controller?
Traction control comes on to tell you that you are getting another CEL if you CEL is already lit.
Basically you are getting that MAF code again
Get a tune on that sucker
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 02-12-2014, 02:04 PM   #3558
fenton
Originally Posted by Robftss View Post
For track testing guys I will have a simple DIY to enable/disable WOT operation. Stand by....
Playing off @Sojhinn theme it will be called 'Super Pursuit Mode'.
It will be a simple switch which allows you to activate SPM (Just like F1 detection zone for KERS) then use it on the straight, then switch the SPM off to use just DR mode.
Only testing will tell how long using only DR will last. It consumes 100-300 watts @ higher engine rpms and can be sustained using little to no dump battery capacity.
On the bench, 200 Watts can be maintained for 20 minutes straight.
Soon I will have a 'plug and play' aux charger upgrade which provides ~5:1
rob
This is awesome news.
Old 02-12-2014, 02:33 PM   #3559
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
All of that post is great news....but this is just friggin' cool.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 02-12-2014, 02:53 PM   #3560
HunterGreene
Hail Magnet
HunterGreene's Avatar
Thats it, I'm checking Zedge for Knight Rider notification tones
It has priests in it?
Old 02-12-2014, 04:57 PM   #3561
Robftss
Drives: VW
SPM mod. *this is for track KERS style testing, not needed for DD,AutoX,drag*
Left pic is stock WOT.
Right pic: de-solder exposed wire, solder wire extension (~24ga) to switch to 'open' circuit.
IMHO the SPM switch should be mounted near the gear lever center console...so when you shift the switch can be activated.
From my years of road course experience as a driver and instructor I suggest:
Just before entering braking zone, activate SPM and select gear for turn, heel toe, post apex hit full throttle, use TORQUE for exit and straight 10-45 secs?, turn off SPM near end of straight. Something like that.
Robftss is offline   Reply With Quote
Old 02-12-2014, 06:28 PM   #3562
mid_life_crisis
Drives: FR-S 10 #103 AT
Attachment 66949
How about tieing a sensor in that only lets it activate when the wheel is straight or close to it?
Old 02-12-2014, 06:31 PM   #3563
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Way more work than you think it is, and, you would need to have a working range on the rack or something.
A switch to change control from the pedal to a The Fast and Furious inspired steering wheel button
Luckrider is offline   Reply With Quote
Old 02-12-2014, 06:32 PM   #3564
fenton
Not necessary. Half the fun is controlling the torque at the limit.
Trust me its very very easy to control.
If you don't want the tires to spin just leave in vsc sport mode
Old 02-12-2014, 10:04 PM   #3565
stevo585
Drives: White 2014 BRZ
Just throwing this out there is it possible to run two (twin) ESC's?
stevo585 is offline   Reply With Quote
Old 02-12-2014, 10:19 PM   #3566
fenton
Yes you can run one into another and double the boost. We are going try a setup like this in the summer time.
Old 02-12-2014, 10:27 PM   #3567
stevo585
That sounds awesome! Keep us informed on the setup very interested. Not sure I can wait that long!
I effectively don't have a winter in florida lol.
Old 02-12-2014, 10:31 PM   #3568
Gums
Drives: SWP BRZ
Oh No! I was looking forward to being a user, now I can see myself being an addict!
Gums is offline   Reply With Quote
Old 02-13-2014, 12:11 AM   #3569
Thatruth2001
Drives: Raven FR-S
There is no reason for the Phantom ESC not to sustain any prolonged period of use as long as you are able to provide the 8:1 (or 4:1 for the dual charger) charge:discharge ratio.
Be careful with setting this expectation when summer heat comes into the equation. Based on the feedback provided to Rob the control unit has been redesigned to better manage both the unit's and engine bay heat.
Currently I believe PUG has been running the unit the past few months in Phoenix and I wonder if he has tripped the unit on a few occasions.
A real quick summer solution to provide the unit cold air ventilation is to remove the rubber lining affixed to the hood above the head light.
Also everyone new running the unit don't freak out when you eventually trip the. Olathe meter. It is a nice subtle reminder to back off the boost.
Have fun and congrats Rob on the release.
Thatruth2001 is offline   Reply With Quote
Old 02-13-2014, 12:40 AM   #3570
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Please enjoy this crappy cell phone video:
[ame="http://www.youtube.com/watch?v=cxT4EpK9f5c"]ESC - YouTube[/ame]
VR46 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
