Old 08-12-2015, 01:16 PM   #3557
Wingnut537
Drives: 2015 FR-s RS1.0 0186/1500
That was FAST! CJ just emailed me and said that he has fwd all the info to their tuner to have the tune written and he will email it to me ASAP.
Thank you CJ! faith restored
Wingnut537 is offline   Reply With Quote
Old 08-13-2015, 12:00 PM   #3558
rj101592
Drives: 2013 scion frs
Hey guys, so I thought my cam plate seal was bad.. turns out its the KW oil reservoir leaking oil somehow.. the bottom of the reservoir is soaked in oil... any ideas?
rj101592 is offline   Reply With Quote
Old 08-13-2015, 12:09 PM   #3559
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I had some initial leaking issues with the oil reservoir. Check to make sure you've torqued the banjos down to the correct torque and that washers were used. My leak was from the top and was caused by a banjo bolt that I had tampered with leaving some grooves on the banjo surface that comes in contact with the washer. I got the banjo and washer replaced and the minor leak I had went away.
mit_peid is offline   Reply With Quote
Old 08-13-2015, 12:15 PM   #3560
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
^^^^ what mit_peid said
Freeman is offline   Reply With Quote
Old 08-13-2015, 12:19 PM   #3561
rj101592
Yeah, it looks like it was coming from the top originally until someone had placed blame on the cam seal plate.. turns out thats fine and it is actually coming from that reservoir. Thanks for the help!
Old 08-13-2015, 12:43 PM   #3562
rj101592
The rotrex oil level is at half point right now.. its suppose to be maxed, correct?
Old 08-13-2015, 12:44 PM   #3563
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
I have mine just above the half point on the dip stick
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 08-19-2015, 11:10 PM   #3564
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
We're gonna start sounding like broken records, but... Kraftwerks, CJ in particular, have by far the best customer service!
It's almost a pleasure when something goes wrong... almost
KW V3
Old 08-19-2015, 11:11 PM   #3565
Freeman
Freeman's Avatar
Haha, I told him his boss should give him a raise. He's incredibly helpful
Old 08-21-2015, 02:19 PM   #3566
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I would stick to the Kraftwerks' instructions about the Rotrex's oil level, it's really hard to anticipate exactly how much oil you'd require when priming the Rotrex ..
so it makes sense using a bit more oil to be on the safer side IMO.. mine also leaked a bit since I probably used a bit more than advised, but it never gave me an issue after I cleaned the reservoir
glamcem is offline   Reply With Quote
Old 08-26-2015, 12:22 AM   #3567
Dadpool
Drives: 2001 Audi A4 (B5) & 2015 FR-S RS1
Hey guys, just got my kit put on last froday/saturday on my RS1, its been down ever since waiting on a tune from moto-east.
Just curious, what internals should be my next step? I'm sitting on a moto east flex fuel kit, 900 dw injectors, 255 lph walbro fuel pump, mpx uel headers and overpipe, and the c38 kit. What do you think my next purchases should be, priority given to reliability?
Dadpool is offline   Reply With Quote
Old 08-26-2015, 12:26 AM   #3568
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
Oil cooler. Radium dual catch cans. Pulleys. 90mm High boost. Check out my build on YouTube name is AZBRZ520
AZbrz89 is offline   Reply With Quote
Old 08-26-2015, 12:27 AM   #3569
Freeman
Freeman's Avatar
Forged pistons and rods.
Old 08-26-2015, 12:32 AM   #3570
Dadpool
Thats what I was thinking was most important for reliability
my next steps being these, cooling and AOS/catch cans.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
