#3599 | |
Drives: 2015 Subaru BRZ
Would a slightly higher spring rate increase the threshold for added weight affecting height? If so, is that a silly thing to pursue? It's definitely a touch too low, especially in the rear (where it rubs). I don't have any issues up front anymore. |
#3600 | |
But for our cars, minimizing the amount the suspension moves is not a good idea for a car that's driven on the street. ![]() - Andrew |
#3601 | ||
Drives: 2014 FR-S MT
Thought I'd provide an update on this front-end bobbing/jiggliness with my MCS 1-way non-remotes, in case someone else with motorsport-type dampers encounters a similar issue: I wound up removing all of the forward rake by lowering the rear 6 mm, because I've been finding the car too loose at auto-x in transitions and on corner exit. I found this to be the case even with a front-biased spring setup, and after adding a bigger front swaybar (replaced the TRD with the Perrin 22 mm set on stiff). To my surprise, the zero rake made an already very good ride noticeably better. The car breathes with the road now, and rides flat over long stretches of bumpy and broken pavement. And those sections of local roads that used the get the nose bobbing -- no more. Not completely, but I'd say almost. And whereas the nose used to bob up and down continuously over these sections, now the front and rear feel like they're breathing simultaneously with the undulations. A couple of oscillations and then it settles, whereas before it was continuous bobbing at the nose. I'm not sure if this is what flat ride feels like, but I can't believe how calm the car is now over these sections. I wouldn't have guessed that the ride could be so sensitive to a small forward rake, but apparently in my case, with my setup, it is. I'm looking forward to auto-xing with zero rake this weekend in our pretty bumpy local lot. I'm hoping and expecting that the rear will be more settled, and that the car will overall maintain more grip over the bumpy sections of the lot. |
#3602 |
Drives: 2017 Subaru BRZ PP
Is it worth corner balancing a car if you're going to be adjusting rake and ride height after the fact?
Has anyone just carefully adjusted their ride height at all corners and gotten remotely close cross weights? |
#3603 | |
Corner balance isn't that sensitive on a big car like this as long as you're in the ballpark you'll be fine, kind of a 'once a year' check imo unless it's convenient or if you're tearing the car apart and putting it back together. |
#3604 | |
Good to know it won't be as sensitive on this car |
#3605 |
#3606 |
Drives: 2016 Asphalt FR-S
I'm experiencing what I think is very excessive body roll. KW V3's, 6kF/7kR, ride height is 13 1/4" from hub center to wheel arch, 215/45r17 Nexen SUR4's, whiteline bolts with -2.5F/-2.3R (as much camber in the front as I could get, no rear correction) 0 toe. What would be the best way to reduce this? Stiffer springs, sway bars, or have I lowered the car too much? Picture from deal's gap for reference, I don't have any pictures from track days.
![]() Sent from my SM-N950U using Tapatalk |
#3607 | |
Drives: 2017 BRZ
Excessive by what measure? What's the handling characteristic you want to change?
#3608 |
The car actually feels fairly neutral in steady state cornering; slightly understeer biased, which I suspect could be aided by more front camber. When the car has taken a set to one side, and transitions back to the other side, there is a lot of body movement that I think is detrimental. I also feel like I'm reaching the point in the front camber curve where it starts to go positive. Maybe I'm wrong.
Sent from my SM-N950U using Tapatalk Last edited by WVAsphalt; 11-15-2018 at 12:28 AM. |
#3609 | |
Andrew, I didn't want to clutter up your Superstreet-1 thread so I thought I'd ask here: do you know why most Twins' LR corner sits lower than the RR? I've never corner balanced; I just measured the threads on the shock bodies and set them equal L to R. I always thought it was because of my uneven garage floor, but then I noticed that the RR corner always looks a bit higher no matter the surface. I haven't gotten around to correcting it, but I've spent a bit of time looking at my top mounts to see if they were somehow different from side to side -- so I found it interesting that you've observed this rear height discrepancy in many Twins. |
#3610 | |
- andrew |
#3611 | |
Total waste of time to corner balance it if you're going to adjust the ride height or rake right after. Even ride height != even cross weights, so you'll need scales (or a lot of luck) to get them close.
#3612 |
Drives: 2018 Subaru BRZ TS
What is the length of the oem strut compared to the KW v3? I've been looking online and the forums and haven't found anything solid as to the OEM strut length measurement.
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
