Old 06-24-2020, 07:24 PM   #3613
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
Originally Posted by BR-ZED View Post
Oh. I definitely will bleed it now with the SC off.
I was more curious about
1. Can it be bled again in case I do it wrong and only notice after I drive the car, and
2. Can it still be done regularly, as needed,after the install.
Sounds like it can, which makes me relieved.
Now, to find an 8mm wrench, and maybe more brake fluid (only have 12 ounces)
You can bleed anything as much as you want as long as you have the fluid to replace it
AKITA is offline   Reply With Quote
Old 06-24-2020, 08:39 PM   #3614
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Does anybody know the product number and way to order the coolant reservoir and bracket? I was thinking of adding that to my Harrop kit.
I emailed Edelbrock, and they gave me their phone number to call. I called and was on hold forever, so I did the callback. I played phone tag like three times where I missed their call then called them back, got on the list then four hours later I missed their call. There has to be an easier way.
Old 06-24-2020, 09:33 PM   #3615
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
Was referring to clearance and access. Due to the supercharger practically touching it.
BR-ZED is offline   Reply With Quote
Old 06-24-2020, 09:38 PM   #3616
BR-ZED
BR-ZED's Avatar
According to my install manual,
Surge tank bracket 38-0360
Cap, surge tank 51-0154
Surge tank 51-1550
2 bolts m6 10mm, 36-1552
Old 06-24-2020, 09:47 PM   #3617
Z06ZN6
Drives: 2017 Toyota 86
With the parts numbers in hand I would call their sales line. I bet they answer that a lot faster. I am passing by them this Friday so let me know if you have trouble and maybe I can rattle their cages a bit. Lol.
Z06ZN6 is offline   Reply With Quote
Old 06-24-2020, 10:06 PM   #3618
Irace86.2.0
Surge tank 51-1550
Thanks. I saw the bracket part number but not the other stuff. I must have been blind.
Old 06-24-2020, 10:09 PM   #3619
BR-ZED
BR-ZED's Avatar
It's in the manual, but surprisingly the manual online is older than the physical one they mailed me, which really surprised me
Old 06-24-2020, 10:22 PM   #3620
AKITA
AKITA's Avatar
Honestly don't know that (I will by Sunday or Monday) but if you look at the pics and from what others have posted, it's still doable with the SC on just a bigger PITA, I would imagine the hardest is securing a line to drain through but it could be just as hard or harder to get a tool on that bleeder.
Old 06-24-2020, 10:39 PM   #3621
Irace86.2.0
That’s what I was looking at—the online one.
Old 06-25-2020, 08:38 AM   #3622
BR-ZED
BR-ZED's Avatar
So last night I'm working on step 93 (installing LTR), thinking, "wow, this step was a lot easier than I was expecting, without having a second pair of hands".
And just as I thought that I was tightening one of the bolts and it snapped. So now the stud is broken off inside the OEM air conditioning condenser bracket.
Fortunately it's one of the bottom holes, so easier access.
Has this happened to anyone? I feel like an easy out screw extractor should work well since it's a tiny bolt, but haven't had the pleasure of needing one before... so, suggestions?
Old 06-25-2020, 08:18 PM   #3623
Irace86.2.0
I got the order placed. Much faster.
Old 06-25-2020, 09:01 PM   #3624
Z06ZN6
No surprises there. Everyone wants to make money. Glad you got through.
Old 06-25-2020, 09:39 PM   #3625
jmai
jmai's Avatar
Drives: 2019 PP BRZ
Hi guys, I’m planning on purchasing this kit used through a reputable shop and will also having them install the kit as well. Just curious, how reliable has the kit been to you guys? Looking to do about 290-300whp with FF kit. Car is 2019 with about 13k miles as well
jmai is offline   Reply With Quote
Old 06-25-2020, 09:47 PM   #3626
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Without the head on the screw, just the act of drilling the pilot hole for an easy out may just drive it thru. You may even be able to get to the bolt from the back side if enough threads has poked thru and grab it with vice grip and "un-screw" it. Otherwise, time for some easy outs.
BirdTRD is offline   Reply With Quote
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
