Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-04-2022, 06:58 PM   #351
Fletch
Drives: 2022 BRZ Limited
Originally Posted by slipstream8 View Post
Alrighty folks. Time for some photos of bad fitment for the sake of education (and I thought it was worth seeing how this style of wheel looked on the new generation BRZ.)
These are Wedssport TC105N 17x9 ET35 with Yokohama AD08R 245/40R17 at stock ride height. It seems like there wouldn't be any rubbing at maximum compression, but the poke looks terrible.
The last photo is the clearance for the front shock.
How close is it on the inside? Enough room that maybe ET45s (17x9) could fit?
Fletch is offline   Reply With Quote
Old 02-04-2022, 09:44 PM   #352
slipstream8
slipstream8's Avatar
Drives: On order: 2022 ISM BRZ Ltd
If that measurement to the front shock perch is accurate enough, you'd have about 0.20" of clearance (10mm closer = 0.394" closer). Adding camber might close the gap? I don't have a strong grasp of suspension geometry.
slipstream8 is offline   Reply With Quote
Old 02-04-2022, 09:47 PM   #353
slipstream8
Originally Posted by 86 & Co. View Post
Got my new wheels on so figured I would share.
18x8.5 +45 Wedsport SA77R with the oem 215/45 Michelin PS4. OEM suspension/alignment.
Do you have any good photos with the wheels facing the sun? The fit looks good, I'd just like to see the design more clearly.
Old 02-04-2022, 09:54 PM   #354
MMoore4545
Drives: 2022 BRZ
Looking back through the thread. Coilovers are required. If still on stock struts you'll need a spacer
Sent from my SM-G981U1 using Tapatalk
'91 Fc3s Turbo
'22 Brz Limited MT
Too Many motorcycles.
MMoore4545 is offline   Reply With Quote
Old 02-04-2022, 11:16 PM   #355
86 & Co.
Drives: 22 WRB BRZ Limited
I'm going to get some better shots this weekend and will share
Sent from my KB2005 using Tapatalk
86 & Co. is offline   Reply With Quote
Old 02-05-2022, 01:49 AM   #356
Chris_f
Drives: 2022 GR86
Keen to see more pics. I think your size and offset is about perfect.
Chris_f is offline   Reply With Quote
Old 02-05-2022, 11:16 AM   #357
CZ6T
Drives: 2022 crystal white BRZ
I have arc-8 17x9 et 45 with some skinny Sumitomo P03 245/40/17 tires and they fit on stock suspension with no clearance issues.
CZ6T is offline   Reply With Quote
Old 02-05-2022, 12:30 PM   #358
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Pretty sure they are not 45.
timurrrr is offline   Reply With Quote
Old 02-05-2022, 01:24 PM   #359
CZ6T
you're right, they're ET42.
That's what I get for replying before coffee.
Old 02-05-2022, 11:54 PM   #360
Fletch
Thanks thats great info. Are you on stock suspension?
Old 02-06-2022, 11:01 AM   #361
CZ6T
I was for a little bit and I had no rubbing, even over bumps and rough pavement, but as pointed out above I misquoted the specs of my wheels. They're ET42, not ET45. You can run a 3mm spacer to bump them out though and the effect should be the same. 3mm is about the most I would run with the stock wheel studs, as that would only give about 7 turns of engagement on the stud.
This is anecdotal evidence, but I ran a 1st gen hyperblue for 20,000 miles on 17x9 ET45 Enkei RPF1 wheels with a 3mm spacer up front and had no rubbing issues either.
Old 02-15-2022, 02:35 PM   #362
razgriz12345
Drives: 2022 brz limited (WR Blue)
So I'm thinking this is the setup I want to go with for stock suspension no chamber adjustment square setup.
18x8.5 +35mm
Michelin Pilot Sport 4 S 245/35ZR18
will this work? I used will they fit and to my eyes it looks like it should fit but I wanted some unbiased opinions on it.
razgriz12345 is offline   Reply With Quote
Old 02-15-2022, 03:27 PM   #363
MikeNSX2
Drives: Ice Silver 2022 BRZ Limited
18x8.5 +35mm
When I was buying wheels and tires from Tirerack, my salesperson recommended that if I did an 8.5 inch wide wheel with 245/35-18 tires, that I should do a +45mm offset wheel.
MikeNSX2 is offline   Reply With Quote
Old 02-15-2022, 03:41 PM   #364
razgriz12345
hmmmm that's interesting was that for the all around or just front or rear? I got my combo from fitment industries I haven't bought them yet but they said it was within safe margins. What was the reasoning the salesperson gave for the +45mm? Would a 10mm hub centric spacer work on it? would changing it to 40r change that? im not questioning the sales person just trying to understand as i dont know much about wheel fitment.
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 11:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 07:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 08:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 05:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 04:34 PM
