Old 06-16-2019, 08:50 PM   #3641
hukdizzle
Drives: 2013 Subaru BRZ (WRB)
Hi RCE/CSG!
Recently installed RCE Tarmac 2 coils and I am looking to get into a lighter/wider wheel and was hoping to get some input on the tire/wheel clearance for the following.
RCE Tarmac 2 (Raceseng Cascam Top Mounts)
17x9 Enkei RPF1 +45mm Offset
245/40/17 DOT Tire (Likely an RS4 or something along those lines)
Installation wise, the car has a crash bolt installed up front from prior classing and since the top hole of the strut mount on the tarmac is slotted I will be maxing out the static camber via that, and then adding additional camber via the top mounts to achieve necessary track oriented camber. I am looking to achieve the following alignment/ride height with adequate strut/tire clearance.
Camber F : -3.5'
Toe F : 0" Total
Camber R : -2.5'
Toe Rear : 1/16" Total
Caster F : 7.0'
Ride Height : Approx 13.56" from top of fender to center of wheel hub. Slight rake with the rear being a 1/16" higher than the front. Car will be corner balanced so static corner heights may change slightly.
Would perhaps a +35 offset RPF1 be the better choice here? It seems like per the ft86motorsports wheelfit calc if I go with the +45 I am going to be extremely close to the damper assembly. If I go with the +35 there is a chance of it rubbing on the fender/liner possibly on the outside shoulder.
Thanks for the help!
hukdizzle is offline   Reply With Quote
Old 06-17-2019, 10:43 AM   #3642
Racecomp Engineering
Originally Posted by MaverickMonk View Post
Thanks Andrew, I'll have to take you up on that, even if it means crossing the DC Area Supercollider / Capital Beltway. I'm doing my best to get in deep as far as understanding all this stuff, but reading books is no substitute for experience.
Cheers
The amount of traffic at any time of day, any day of the week is infuriating.
Right now I've got a bit of an experimental set up on my SS1s (softer spring rates) but I do plan to return them to the standard 6 kg/mm springs at some point this summer. Just give me a heads up and we'll work something out.
I also really want to host a meet and suspension tech info day sometime!
- Andrew
Old 06-17-2019, 10:52 AM   #3643
Originally Posted by hukdizzle View Post
Hi RCE/CSG!
Camber F : -3.5'
Toe F : 0" Total
Camber R : -2.5'
Caster F : 7.0'
Are you set on the RPF1s? You could consider the Weds TC105X in 17x9 +35 as that is a confirmed easy button fitment for track cars with 245s and camber (and clears more brake calipers). I'm not a wheel fitment wizard, though, I just have my fitments that I know work and stick with them.
The rest of your set up sounds great! Yes get as much camber as you can at the lower mount (safely). Ride heights sound good too. Definitely do some test and tuning since depending on your final tire choice you will want to dial in front camber with a pyrometer if you can. Keep us posted.
- Andrew
Old 06-17-2019, 02:12 PM   #3644
hukdizzle
Originally Posted by Racecomp Engineering View Post
Are you set on the RPF1s? You could consider the Weds TC105X in 17x9 +42 as that is a confirmed easy button fitment for track cars with 245s and camber. I'm not a wheel fitment wizard, though, I just have my fitments that I know work and stick with them.
- Andrew
Thanks for the recommendation Andrew, I will take it into consideration!
Old 07-08-2019, 11:46 AM   #3645
Icecreamtruk
Drives: Track preped NA FRS
@Racecomp Engineering
Can I get an idea of what the stiffness of your sway bars are, if possible by adjustment position (sku BSK020) and also, would they work with endlinks that currently work on my stock bars? I have the rear stock endlinks but front ones are shortened (non ajustable) that came with my coilovers. Thanks.
Old 07-08-2019, 12:39 PM   #3646
Front is 25mm hollow, which comes out to be roughly equivalent to 22mm solid. This means on the soft setting, it's roughly 2x stiffer than stock.
Rear is 18mm hollow, roughly equivalent to 16mm solid. It's about 1.75 x stiffer than stock.
Remember that rear swaybar motion ratio is not the same as stock, so increasing bar rate by the same amount front and rear does not translate to the same amount of wheel rate increase front and rear. This is true with all swaybars, not just ours.
Adjustable endlinks do help with adjustable bars, but you would be able to reach the soft settings fine with OEM endlinks.
- Andrew
Old 07-10-2019, 12:19 AM   #3647
Infinity
Drives: 2016 Scion FR-S
I have seen people mention damage to rear axles from lowering the car. I believe this is caused by the diff being too low relative to the wheels.
The only solution seems to be solid sub-frame and diff risers from PBM. This is not ideal because it is not a simple mod to install/uninstall and solid bushings will increase NVH.
1. How low do you need to be for this to become an issue?
2. Do rear lower control arms that lower the shock mounting point like PBM or Stance keep the diff higher and help preserve axle life? If yes, what are the downsides of lowering the shock mounting point like this?
Infinity is offline   Reply With Quote
Old 07-10-2019, 12:45 AM   #3648
1. It's not how low, but the range of motion you're using. A low car with very little roll won't be stretching the axles.
2. They do not affect the axles.
Old 07-15-2019, 03:28 AM   #3649
blown
Drives: ft86
what do you suggest for stock ride height, street/track driving. I have the ohlins road and track, and looking for something different. Need coilover for the extra space for wheels.
blown is offline   Reply With Quote
Old 07-15-2019, 01:13 PM   #3650
Vital
Drives: 2015 BRZ
RCE SS1 Coilovers or the CSG Tein Flex A.
Vital is offline   Reply With Quote
Old 07-15-2019, 01:43 PM   #3651
Stock ride height is tough. You can't really get to stock ride height with SS1s or many other coilovers. A 15-20mm drop is about the highest you can go.
- Andrew
Old 07-27-2019, 04:24 PM   #3652
OwlDance
Drives: Halo 86, '19
Hey guys, can't seem to find OEM alignment for 2017+ refresh cars between documents and searches. Would anyone happen to know them for a base model Toyota 86? I assume there are slight variations between Subaru and Toyota's iterations.
OwlDance is offline   Reply With Quote
Old 08-04-2019, 12:20 PM   #3653
rustymuffler
Hi @Racecomp Engineering
I have Koni sports with OEM 2017 springs on my '13 BRZ. It has removed the harshness of the stock setup. Now I am looking for a modest ~1" drop while also reducing roll for spirited driving. Would the Racecomp Yellow, or Tarmac springs be a good fit with the Koni dampers without making the ride as harsh as the stock '13 setup?
rustymuffler is offline   Reply With Quote
Old 08-05-2019, 11:28 AM   #3654
OEM alignment isn't very good anyway.
Is your car stock? What kind of tires do you have? How would you describe your driving style?
- Andrew
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
