Old 06-30-2020, 02:33 AM   #3655
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by aKaGorganZola View Post
Quick question for you guys. Any tips on which coolant to use in the SC loop? All I've seen is the recommendation to use a different color than the vehicles coolant. The Subaru super coolant or whatever is blue so I've been looking around for a good coolant for the SC that's not blue. Engine ice is blue as is the mishimoto liquid chill. The Evans waterless coolant is yellow but I have no experience with it so I don't know how well it cools or if it would agree with the Edelbrock internals. Any help or tips are appreciated!
I've got a Mishimoto radiator and 165 stat and run a 50/50 Prestone green in the car year round not too far from you, including track days, and not a single hiccup. If you go with that for engine cooling then you can use whatever blue you like for the SC.
Conversely, you could use the Prestone orange "any car" in the SC without having to change the engine coolant but I haven't seen anyone do that yet. They all seem to be running blue.
Uplink is offline   Reply With Quote
Old 06-30-2020, 02:51 AM   #3656
Uplink
Uplink's Avatar
Originally Posted by BirdTRD View Post
As for oil, you will be fine as long as you don't immediately take it to the track and thrash it. Some people (including myself) run 5w-30.
Edelbrock does not supply you with any tools and the only "special" tool you will need a fuel line release tool like model 545 from www.company23.com. You can disconnect the fuel line with zip ties or other thin, stiff plastic but the actual tool makes it easier and it's cheap. (I might even lend you mine if you're close enough to the White Marsh area )
$15 for one size?!
I have this set: https://www.amazon.com/Performance-T.../dp/B000N37D7W picked up ages ago from I think Advance or Autozone or something with any size you could need. It's either the 5/16" little blue or 3/8" little grey one, I forget. @BR-ZED Just go easy and there's no issue with damaging the fuel line or seals. Had no problem whatsoever after an engine swap. Definitely don't mess around with using screwdrivers or anything makeshift to disconnect the lines.
Old 06-30-2020, 03:25 AM   #3657
Uplink
Uplink's Avatar
Originally Posted by jayjay06 View Post
Yeah, 60-80lb range I think.
Edit:
60lbs manifold
81lbs total parts
Per:
https://www.ft86club.com/forums/show....php?p=2406569
Sent from my Pixel 3 XL using Tapatalk
Out of curiosity, that's 81lbs added, but how many lbs removed? I'm guessing the earlier style plastic intake manifold is probably lighter than the 2017+, but how many stock components are permanently removed in the conversion?
Old 06-30-2020, 03:30 AM   #3658
Uplink
Uplink's Avatar
Originally Posted by BR-ZED View Post
Which one did you order? I want to make sure I get a different one then lol. Saw a handful on Amazon. If the one I get fits I'll report back here
This is the one Michele Abbate recommended: https://www.amazon.com/gp/product/B01I40ZQWE
Old 06-30-2020, 09:19 AM   #3659
BR-ZED
BR-ZED's Avatar
Drives: 2014 WRB BRZ Limited
That's actually the one I ordered since @jayjay06 got the lisle one and it didn't fit the Edelbrock reservoir. I'll try this one and let you know if it fits. Haven't gotten there yet.
I also got the company 23 fuel line tool. Read bad reviews on the generic sets and wanted something that I knew would work. I've owned nothing but Subarus for the last 16 years, so shouldn't be an issue. Except for my wife's cars but that's because Subaru made the base impreza so underpowered.
Delta is 62.5 according to the link below, considering all the stuff coming off the car. I'll try to find a link.
Edit
https://www.ft86club.com/forums/show...&postcount=124
http://www.ft86club.com/forums/showp...&postcount=146
BR-ZED is offline   Reply With Quote
Old 06-30-2020, 11:06 AM   #3660
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
The Lisle did fit when it was the old style skinny surge tank...
BirdTRD is offline   Reply With Quote
Old 07-01-2020, 09:05 PM   #3661
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Add another one to the owners list. Ordered my kit last night! Today was tough knowing it's just a waiting game until it shows up lol.
aKaGorganZola is offline   Reply With Quote
Old 07-01-2020, 09:27 PM   #3662
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Finally got the bypass valve upgrade ordered through Superchargers Online. Now to find time to install it. Any updated tips on the install guide?
Sent from my Pixel 4 XL using Tapatalk
Mad1723 is offline   Reply With Quote
Old 07-02-2020, 12:26 AM   #3663
BR-ZED
BR-ZED's Avatar
I posted a pretty long video that discusses it.
Old 07-02-2020, 12:59 AM   #3664
Z06ZN6
Drives: 2017 Toyota 86
Congrats! Good luck with the install.
Z06ZN6 is offline   Reply With Quote
Old 07-04-2020, 09:33 AM   #3665
BR-ZED
BR-ZED's Avatar
For the brake booster line, for the life of me i could not get one of the edelbrock hose clamps on the vacuum line, let alone clamped to the nipple. Seemed the hose itself was a little thicker on the OD compared to other hoses. Same clamp fit no issues on the rh Pcv line...
The instructions actually don't mention using clamps here. But there are enough in the kit.
The Titan Motorsports install video on you tube has been helpful as a reference. They mention using a zip tie ( so I did that, see pic). Is this a bad idea or should it hold?
Old 07-04-2020, 11:39 AM   #3666
rixon
Drives: Subaru 2020 BRZ
Don't know where you ordered from but edelbrock has 10% discount you may still be able to get
rixon is offline   Reply With Quote
Old 07-04-2020, 11:44 AM   #3667
rixon
don't know where you purchased it but edelbrock has 10% discount. You may still be able to get discount.
Last edited by rixon; 07-04-2020 at 11:49 AM. Reason: sorry about double post at beach in sun
Old 07-04-2020, 12:05 PM   #3668
Mad1723
Mad1723's Avatar
Just saw that. Missed it on my first skim through!
Will use it for sure when I install mine!
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
