#36877 |
Junior
Drives: a car
pink underglow. You have to do it now
#36878 | |
That which is forged in fire can be destroyed by fire. Now all that said. We all know powder coating is done all the time without issues so you just have to decide if the level of risk is acceptable to you. http://www.ephatch.com/forum/showthr...OT-recommended
#36879 | |
Drives: 2015 CWP BRZ Limited
I've seen in legit technical references that 6061-T6 aluminum should not be held at temperatures above 400F for more than 30 minutes (or you'll be reducing the strength by over 5%). This was in a civil engineering reference, since 6061-T6 is often used in building construction. 6061-T6 is also commonly used in forged wheels. How much loss of strength are you willing to concede? Do I have the actual Brinell hardness test results? No, but we stand on the shoulders of giants, so we don't make the mistakes of the past. tl;dr: aluminum industry experts say don't do 400F for more than 30 minutes. Powder coat requires 10 minutes. Watch your oven, yo. |
#36880 | ||
Site Moderator
Drives: ichi 86 Project
#36881 |
#36882 |
not playing cards
I approve this message.
#36883 | |
Site Moderator
#36884 |
Ah but see there is the twist. There is no such thing as an "aluminum" rim. There are aluminum alloy rims. Since all alloys are not created equal there is no absolute number or time that can be applied across the board as "safe".
I 100% agree that 400 degrees for 10 or so minutes is probably safe as a rule of thumb but what happens if your particular rim's alloy should only be heated to 380 for 5? You also need to consider the style and design of the rim. A heavier outer with thin inner spokes is going to have to heat longer to get it to an even temperature. This means the thin spokes can be exposed to a higher internal temperature longer that the outer rim. This is a big issued if using a gas fired oven but can be migrated a bit if they are heated in an induction system that heats from the outside in. I repeat, it is all a matter of risk management and what each individual considers acceptable risk. Powder/wet coating, heat treating and high speed machining (creating heat) in OEM parts manufacturing are all things I have worked with for the last 28 years and although I am certainly no expert I have picked up a thing or two along the way.
#36885 |
Member of the year - 2016
Drives: Scion FRS
You know it's starting to become nice outside when you hear the roar of accelerating bikes echoing at the local highway.
#36886 | |
Site Moderator
...but what I meant was, I like jawn's explanation cuz he had TLDR ver aftereard. lol |
#36887 |
not playing cards
I-4s screaming to 13K, glorious.
#36888 |
Wayward Member
Drives: Hot Lava 86
Today went from being amazing to just sucking pretty damn fast. Here's the rundown:
- Impatiently waiting for tire shop to call. - Stop by shop to check and pick up wheels mounted. (Super excited) - Go to hardware store and buy a good jack, a new torque wrench, and an impact wrench (for removal only) - Get home, jack is damaged. - Take jack back to replace it. - Get car washed. (also grab lunch) - Jack car up, take off a wheel and set the new wheel on - Lug nuts don't fit.
#36889 |
I drove my old Rav4 today. Felt like driving a Lexus in comparison. BOAT MODE.
#36890 | |
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-22-2014 12:46 AM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 03:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 10:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 08:59 PM |
